The front dial on my M5 is hard to rotate, is there a way to fix this?
Started Feb 13, 2020 | Questions
Wintereater Forum Member • Posts: 84
The front dial (the one that surrounds the shutter button) is occasionally very hard to turn. Since there's no sealing on the camera I'm afraid of applying lubrication or grease in order to loosen the dial up. Has anyone successfully fixed their front dials at all?
 Wintereater's gear list:Wintereater's gear list
Canon EOS M6 II Canon EF-M 22mm f/2 STM Sigma 150-600mm F5-6.3 | C Canon EF-M 15-45mm F3.5-6.3 IS STM +2 more
Icypeak Senior Member • Posts: 2,523
Re: The front dial on my M5 is hard to rotate, is there a way to fix this?
I have the same problem.  The control dial is so stiff that it can't be moved with my index finger.  I now have to take my right hand off the grip and pinch the dial with 2 fingers, to move it.  It came on after I hiked on a windy Oregon beach, so I suspect that some grit got blown under there.  I tried to clear it with blowing with compressed air, but no luck.  I actually ended up breaking the dial (came off the camera), when I finally tried spinning it while pressing it down, to try to grind up the grit.  $140 later, the knob is back on, but still too stiff to rotate with my finger.  Makes me not want to get another M series camera.
David
OP Wintereater Forum Member • Posts: 84
Geeze it actually fell off? I don't feel any grit under mine, it just feels like it's rubbing on plastic or something.
Mine didn't feel 'gritty' either, just like it was rubbing. It came right off, just held on with a little glue. Really looked cheaply made. I was hoping to upgrade to an M6 mkII, but now probably can't sell the M5, and having 2nd thoughts about getting another with the same button/dial combo.
David
(unknown member) Regular Member • Posts: 221
I'll chip in too as my friend also has the M5. And the same problem! The button; the knurled one, grinds when rotating and has done for a number of months. Great camera but still bothersome and concerning regarding build quality.
dpeete Contributing Member • Posts: 746
We haven't heard anybody report this on the M6... anyone?
I've been lucky enough to have no front dial issues with the M, M2, M6 or M6ii. Maybe just an M5 issue.
 dpeete's gear list:dpeete's gear list
Canon EOS M Canon EOS M6 Sony a7R III Canon EF 85mm F1.8 USM Canon EF 40mm f/2.8 STM +17 more
nnowak Veteran Member • Posts: 9,076
Floss
Try working some waxed dental floss around underneath the dial.  This can sometimes clean out any gunk and/or loosen up the interface.
Chrisinhouston
Chrisinhouston Contributing Member • Posts: 507
Funny but I have 2 M5 bodies that are pushing 3 years old  and get a lot of use and travel and neither has this problem.  I tend to keep them in neoprene slip over cases that helps keep dust off in my bag, maybe that helps.
“Which of my photographs is my favorite? The one I’m going to take tomorrow.” – Imogen Cunningham
 Chrisinhouston's gear list:Chrisinhouston's gear list
Canon EOS 7D Mark II Canon EOS M5 Canon EOS R Canon EOS R7 GoPro Hero5 Black +23 more
Re: Floss
On mine, the problem seemed to be within the 2 rotating cylinders that are inside the top plate of the camera, beneath the rotating knurled ring (the ring  is glued to one of them).  Even after having it cleaned and replaced, the problem remained.  Seeing how that ring is only held on by a little glue, I'd also be worried about someone pulling it off, if putting floss beneath it.
David
Do you remember what underneath the dial looked like? depending on how it's put together then lubrication might help without the risk of any of it seeping into the camera.
There were 2, vertically oriented, white plastic tubes, one inside of the other, with little space between them.  The control ring was glued to the top of the outer one, I think.  The inner one was probably for the shutter button.
David
I've seen one additional report of the same thing with an M5, so that makes at least 4 reports of this.  A bit reassuring that it hasn't been reported with any of the other models that use this dial setup.
David
Ah okay, I can picture that. I'm thinking that most of the friction we're feeling is the result of the outer edge of the shutter dial rubbing on the plastic, perhaps on the side towards the screen.
Makes me wonder what exactly they changed, because superficially the dial looks identical on the M50 and M6/M6 markII
Ricardo_Fon
Ricardo_Fon Forum Member • Posts: 59
My M5 also gets really tight sometimes. When I feel it I usually just turn it back and forth really quickly and it seems to loosen up, which lasts a few weeks. I don't have much faith in it to be honest. I keep expecting it to break off one day because of this (so far so good though). My wife has an M6 which she bought at the same time. That still feels great... but gets much less use to be fair.
 Ricardo_Fon's gear list:Ricardo_Fon's gear list
Canon EOS M5 Canon EF-M 22mm f/2 STM Canon EF 50mm F1.8 STM Canon EF-M 15-45mm F3.5-6.3 IS STM Canon EF-M 28mm F3.5 Macro IS STM +1 more
Hmm, well my dial is only stiff maybe 30% of the time, so maybe I should sell it now before it bites the dust haha. I don't know what I'd replace it with though; I don't want to go back to a traditional DSLR and I want to stick with APS-C, but m6II's lack of a built in evf isn't appealing to me. The m50 seem like a bit too much of a downgrade in aspects that matter to me (battery, number of dials + buttons). Cmon Canon I want an m5 mark II
Ricardo_Fon
I'm in exact the same boat. I figure I'll use the crap out of it till it breaks. If it does eventually break I'll buy another one the same with less miles on clock. This camera has a lot of quirks, but it's the closest thing to ticking all my boxes right now, except maybe an Olympus... But that switch would cost me in body and lenses. Not justifiable.
jcm65 Forum Member • Posts: 63
I also had the same problem.  In reading all of these postings I had to try something.  I had to use my left hand thumb and finger to try to loosen the dial.  After 10 minutes the dial started to move. After 20 more minutes the dial is almost in finger turning.  This morning I worked it a more and it is looser.   More work coming.
Mac4Berry New Member • Posts: 5
Dear All
My M5 developed same incredibly annoying fault!
The main dial (to be clear - the one around the shutter button) - got stuck and it was always in the most unexpected moment - obviously.
I remove the dial and found some debris under it - replaced it - no dice.
Then I started to search and could not find anything at the time.
In a meantime I tried to clean it, put some grease, machine oil, all sorts of stuff - and it was only worse.
Everything is caused by a tiny little plastic washer between the dial and camera body.
I am sure Canon knows about it and in my M50 which I got later - there is no problems whatsoever. The dial is slightly different and made of plastic.
Here is some help and that finally works for me:
1. Don't try to remove the dial - there is no point doing that and you may end up having problems with attaching it back properly - like I had.
2. Dental floss - use that to clean the gap between the dial and the camera body. Remember there is a thin white washer so the job should be done twice on both sides of it. Helpful tool might be a toothpick to lift the dial slightly.
3. Use one drop (or less) of silicone oil and try to inject it on the washer. This needs to be pure silicone oil (NOT WD40) and that can be bought in every bike shop - or online.
I used one toothpick to make a tiny gap and another for applying the oil.
Results: It works just fine - the dial rotates nice ans smooth now.
Last thing: If your dial pops out and you have problems attaching it back - try using a tiny drop of shoe glue. It makes it staying where it should and gives you a chance to eventually remove it if there is need for that.
Enjoy
Mac.
BruceBurbank
BruceBurbank Junior Member • Posts: 27
Hey, just wanted to chime in and say thanks for the instructions.
I picked up an M100 from Goodwill’s auction site for cheap. You’re always taking a chance buying stuff from that site, especially when it comes to electronics, because Goodwill doesn’t test anything, so we have no way of knowing if anything is even functional.
So it showed up in the mail, and fortunately it's 100% functional, outside of that front dial, which was completely locked up, frozen, seized, even if I tried to put a little bit of muscle into it. It wasn’t going anywhere.
And the M100 is designed a little bit different than the M50 or the two Ms that I already own, an M6 and M10, and there’s no way to get any floss under that button. There’s no room.
I asked Canon about it, and the cost for them to fix that thing was significantly more than just buying another (used) M100 body on ebay, so that wasn’t an option.
But good thing- among many other things, I’m a bike mechanic, and had a little bottle of oil on my workbench. I knew this was a last-ditch effort which could end up doing significant damage to the camera.
But, I went for it, and it worked! Not totally. That dial is still a little rough, but it does move, and it looks like it didn’t damage anything about the internals of the camera, so it looks like I’m back in business, and I saved the camera, thanks to your help. Super awesome.
