Lomography Daguerrotype aperture plate
Started Feb 9, 2020 | Discussions
newmikey Veteran Member • Posts: 5,203
Storm Ciara is passing over the Netherlands so I was homebound today. Decided to make my own version of the "Aquarelle" aperture plate supplied with the Lomography Daguerrotype lens to try on my own Pentax gear.
I first found a reasonably clean image of those plates on Google, copied them into Gimp and sized them to precisely the 67mm filterthread size of my DA*50-135mm zoom (minus 1mm to fit it inside).
Double-printed it on the laserprinter after which I glued both sides together for firmness and to avoid reflections. About half an hour of fiddling about with nail scissors, I had my aperture plates. (also made a copy of the "Lumiere" plate).
Although I really have to wait for a sunny day and a field full of flowers to really pass judgement, I managed to squeeze a quick shot of the dog outside.
 newmikey's gear list:newmikey's gear list
Pentax KP Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 85mm F1.4 EX DG HSM Pentax 16-85mm F3.5-5.6 WR +2 more
petrochemist Veteran Member • Posts: 3,619
Re: Lomography Daguerrotype aperture plate
This sort of thing has been on my to do list for years - I've done similar shapes for the affect on bokeh, but as yet only removing the rear group for a soft focus effect.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
dellaaa
dellaaa Senior Member • Posts: 1,201
I like the effect, so you put this directly in front of the lens?  I see you were wide open, what's it look like stopped down?
 dellaaa's gear list:dellaaa's gear list
Canon PowerShot G10 Sigma DP1 Merrill Nikon D800 Sigma SD1 Merrill Fujifilm X-Pro2 +4 more
