M6 mark II shutter shock with EF-M 15-45mm
Started Feb 9, 2020 | Discussions
nolten Contributing Member • Posts: 850
Re: M6 mark II shutter shock: Couple Questions
1:  So I've set my Av, One Shot mode to electronic shutter.  I don't wave the camera around shooting vertical towers in that mode.  Any other down sides?
2:  I've read that the EF-M IS lenses use a spring for the IS mechanism to work against and its the spring that causes the movement from the shutter action.  So do all IS lenses use this mechanism?  EF-S, EF, EF L?
I mostly use EF-S and EF IS lenses on my M6II.  I have the 11-22 and 28 Macro and haven't seen any issues but I'd like to know what I'm dealing with here.
 nolten's gear list:nolten's gear list
Canon G1 X III Canon EOS 5D Mark IV Canon EOS 90D Canon EOS M6 II
plantdoc Veteran Member • Posts: 4,339
Re: Disappointing, keeping M5
Almost always use IS lenses in that range of shutter speeds. Therefore, it is a problem that shouldn't exist. Would be interesting to see how adapted efs lenses fair. No complaints about the M5 for my needs.
Greg
AdamT
AdamT Forum Pro • Posts: 62,282
5
Same here , its the most popular shutter speed range in the UK general dull weather . all it would take would be a firmware update to either add EFCS or at the very very least have an option to switch to E-Shutter at those speeds like the Panasonic GX8 does - better still to switch to EFCS at those shutter speeds if the mech shutter is needed to circiumvent weird bokeh issues ..
This is a very expensive camera and no , the problem shouldn't exist as it doesn't on the M6-II`s DSLR twin, the 90D or any other Canon Mirrorless camera from the original M to the R5
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
ex human Regular Member • Posts: 194
Re: M6 mark II shutter shock with EF-M 15-45mm
Thought I’d resurrect this thread.  I’ve noticed what seemed like horrible softness/missed focus, or even motion blur at shutter speeds that shouldn’t produce this.  Only with the zooms (15-45 and 18-150).  The primes are always exquisitely sharp. Just wondering if    anyone has any simple workarounds to suggest.
 ex human's gear list:ex human's gear list
Canon EOS 6D Canon EF 135mm F2L USM Canon EF 100mm F2.8L Macro IS USM Sigma 50mm F1.4 DG HSM | A Canon EF 16-35mm F4L IS USM +12 more
Nigge Regular Member • Posts: 223
Canon must fix this issue with FW. I don’t understand what they are doing.
 Nigge's gear list:Nigge's gear list
Canon EOS 5D Mark II Canon EOS 80D Canon EF 50mm F1.4 USM Canon EF 100mm f/2.0 USM Canon EF 70-200mm F2.8L IS II USM +6 more
R2D2 Forum Pro • Posts: 26,529
Post a few shots for us when you can (with EXIF intact).
R2
