M6 mark II shutter shock with EF-M 15-45mm
Started Feb 9, 2020 | Discussions
MichalEs Junior Member • Posts: 42
Hi, I've bought an M6 mark II with kit lens recently and did some testing of the kit lens to check if I got a decent copy. I was really disappointed with its performance at 45mm. Photos were really unsharp. After testing various hypotheses I was able to pin point the problem to shutter shock. I did some ca 1 sec exposures from a tripod and they went out good using both electronic and mechanical shutter, so I tested shorter exposures handheld with IS and voila! Here are the results (the test was not as thorough as in the existing shutter shock thread, but the results leave no doubt.
I expected to be happy with the new camera with much improved sensor and was going soon to buy more lenses for it and an EF adaptor for my already owned EF ones. Now I wonder if I should return it and keep my 700D or maybe make a warranty claim. I get same kind of softness also at 1/125 and 1/160. This is unacceptable in my opinion. I'm going to contact Canon support about it, but have little hope to get a helpful reply.
To other M6 mark II users - do you notice shutter shock with this lens with the same level of blurring as on those 100% crops from the centre of the frame?
 MichalEs's gear list:MichalEs's gear list
Canon EOS 700D Canon EOS M6 II Canon EF 35mm F2.0 Canon EF 50mm F1.8 II Tamron SP AF 90mm F/2.8 Di Macro +6 more
Canon EF-M 15-45mm F3.5-6.3 IS STM Canon EOS M6 II
R2D2 Forum Pro • Posts: 26,529
Re: M6 mark II shutter shock with EF-M 15-45mm
5
Please contact Canon.  If we get a new thread here every month then maybe we’ll get a firmware update out of Canon.
R2
rrc1967 Senior Member • Posts: 1,984
to be honest, I rarely look at 100% at the center of my images.
I mean, with 32.5MP I'm never going to print / view anywhere close to that level of magnification.
it's been well advertised that the M6 II has a mechanical first curtain shutter and not EFCS.
also comes down to your dampening, and how good your tripod is.
Personally I find the M6 II far surpasses what I need it to do.
As far as a real world photo? I haven't had much trouble with it.
Do I wish it had EFCS? Hell yes.
The damned thing sounds like a machine gun.
dpr4bb Senior Member • Posts: 1,418
5
I ended up returning my M6II because of shutter shock. Shutter shock is just a hassle. It randomly spoils photos, and I just didn’t want to deal with it. I don’t understand why Canon decided to skip EFCS on this model.
OP MichalEs Junior Member • Posts: 42
Contacted them as well. Though I don't expect much from Polish branch (nor any other to be honest ;-)). Probably more threads in not what we need, though in a way - if there were more of them maybe more customers would be warned about this issue. Now that I researched the issue I know there's a single sentence about it on DPR review (without a sample photo), but before buying I didn't notice it and I skimmed and watched many reviews.
I've seen the samples by Hoka Hey and there weren't bad (of course after noticing the issue), so maybe there are worse and better cases and making a warranty claim makes sense. Probably reasonable thing to do would be to just return it, but you know... once you get a hang of something it's not so easy to part with it, especially as there's no alternative with similar set of features in Canon's ecosystem.
Your samples don't look too bad - wonder if copy variation comes to play here. I've got another sample from my camera (see below) - 1/80 sec, camera laying on a table. It's perfectly reproducible and not acceptable in my opinion. You don't upgrade from say 18mp to 32mp just to get pictures that are worse or to worry and constantly check if your shot hasn't been affected. Still would like to have a camera with M6 mark II features, so it's a conundrum.
Hope that some more samples here will help people assessing the severity of the problem. The only one so bad on the forum that I've seen was from user Helen, who returned her camera.
Was it so bad as my samples? Here's another one (and also one has been posted another post in this thread). I could live with slight degradation, but mine's severe to my eyes. People often bash the EF-M 15-45, but in this case I think it's not bad as long as I use electronic shutter.
PhilM oz Senior Member • Posts: 1,350
Ouch - not good at all.
I tested my 15-45, 11-22 and 22 prime and I can't see any noticeable difference between mechanical and electronic shutter. Tried 1/60 and 1/80 second exposure.
The 22 prime does not have IS so I would have thought it would be more susceptible to shutter shock; but I can't see any difference.
Perhaps there's an issue with your 15-45 lens. Do you have any other lenses to test?
Phil.
plantdoc Veteran Member • Posts: 4,339
Shutter shock. Interesting. Some M4/3 cameras had this issue but I believe it has been solved in the last few years by various methods. Surprised Canon didn't consider this issue with a small, low mass, high resolution camera.
greg
Jack Jian Regular Member • Posts: 309
I think you have a bad copy either the lens or the body. Try with other lenses and check the result too. Although I do not own M6 II, I do not hear any such issues in forums or anywhere online. The samples I saw are tack sharp most of the time, softness only due to lens or missed AF.
okay, but that's worst case scenario for shutter shock. Tell me. how many photos do you in real life take with the camera laying on the table?
A good tripod, and/or handheld, I'm just not seeing it as much.  Landscape long exposure, I'm going full electronic .. because any vibrations from shot to shot are nil with electronic.  Otherwise, I'm using the onboard camera as fill (which mitigates shutter shock), or shooting at non problematic shutter speeds.
If you see it in real world photos, then sure.
Another thing. I have a few thousand M6 II photos (not that many), and it's hard to find any that are even in the 1/30 to 1/80 shutter speed zone. I may have a handful that are in that shutter speed area, that are NOT ISO 3200-6400 - which when you are up in that level of ISO, it really doesn't matter.
While I agree, Canon should have put EFCS on the camera, and the omission is really freaking weird, in real world conditions, i'm not seeing an impact.
and the camera just freaking sings with the SIgma 56 1.4 (as you can see above)
Here are tests from my M6 II and various lenses.
Yes, the 15-45 and 18-55 lenses are not as sharp as the others; but I can't see any shutter shock in any of the comparisons.
In all cases the electronic shutter is on the left, mechanical on the right.
22mm prime
18-150mm
18-55mm
15-45mm
11-22mm
Phil
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
From what I've read, when there is shutter shock it is actually caused by the IS, so lenses without IS don't have it. None of my primes show it. I was able to see it a little with my 11-22 in the 1/20-1/100 range. It's not an issue for me, because I can simply use electronic shutter with the 11-22 if the speeds are going to be in the affected range. The only other lens with IS that I use a fair bit with the M6II is the 70-200 F2.8L IS II. But I use that for sports, and am never shooting at slower speeds than 1/500 with it, so I've never seen shutter shock with it. I haven't bothered testing, to see whether it can be affected by shutter shock at slower speeds.
Phil.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Steve Light
Steve Light Junior Member • Posts: 42
Analysis of Shutter Shock and the lack of EFCS.
https://www.canonnews.com/canon-eos-m6-mark-ii-analysis-of-shutter-shock
AdamT
AdamT Forum Pro • Posts: 62,282
Its the Squeaky wheel which gets Greased !
R2
Nice attitude R2 .... I Hate the posts which dumb down Shock complaints calling the Complainees Trolls etc because Canon will not fix something if they can get away with it - Its the Squeaky wheel which gets Greased !  ......
I`m very interested in the camera as there would appear to be no M5-II on the horizon but will not buy it until they`ve put EFCS in the firmware like the 90D has .
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
AdamT
It`s not Caused by the IS, it`s caused by the M6-II`s first mechanical curtain , there are no such issues with IS lenses on any other M series body because all of them have eletrconic first curtain as does the DSLR version of the M6-II, the 90D  ..
well its an issue for a lot (Most I`d say) and it needs sorting, Period . the camera ships with the 15-45 as a kit and that lens has IS - the best quality native zoom for the system is the 11-22 and even you have seen it with this also (I use this lens as a "kit" lens, barely touched the 22mm prime since getting it)
I`ve Mailed canon about it (to the point of saying that I won`t buy the camera until its sorted and suggest that anyone even remotely interested in the M6-II does also, even if you use one prime or only shoot over 500th sec as one day you`ll want to use that 11-22 or 15-45 and not want to use wobbly E-Shutter mode - the problematic shutter speed area is the most common . Its the Squeaky wheel which gets Greased !
If they didn`t want to have people leave EFCS on all the time because of the occasional bokeh issue they could copy what Olympus did and only have it activated in the affected shutter speed area
Disappointing, keeping M5
Very well done testing. What was Canon thinking? Really not acceptable flaw in expensive, top model in my opinion. Really glad that I stuck with M5 and a couple M 4/3 cameras that have solved this problem.
Greg
MyM6II Senior Member • Posts: 2,424
Quotes from DPR's review of the M6II:
"We saw very slight shutter shake at moderate shutter speeds in Mechanical shutter mode" and "we were hard-pressed to find it impacting our images in more casual shooting."
They also found it so minor that it was'nt even mentioned in the conclusion nor in the "What we don't" list.
The Camera got the GOLD Award and 85%.
Yeah, what a serious problem. LoL.
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
Alastair Norcross
It's caused by interaction between the mechanical shutter and IS. Thus it is caused by the IS, in the sense that the IS is what determines, in the M6II, whether you'll see any (often very slight) shutter shock. My point, which shouldn't have been hard to understand, was that you don't get shutter shock with non-IS lenses. The meaning of what I wrote was obvious, and I'm surprised to see that you didn't understand it (or perhaps willfully misunderstood it).
Alastair
Alastair Norcross
Re: Disappointing, keeping M5
Greg
So you do most of your shooting with IS lenses at shutter speeds between about 1/25 and 1/200 in conditions where you can't use e-shutter? In that case, good decision.
Alastair
