Best aperture (sweet spot) for Panasonic 14 - 140 mm lens
Started Feb 7, 2020 | Discussions
Brisn5757 Veteran Member • Posts: 4,540
I once believed that the smallest aperture (f22) would give me the sharpest photo as most things would be in focus but since then I've read that it varies between different lens so I was wondering if someone know what the best aperture to use for the Panasonic 14-140mm zoom lens that will give me that sharpest photo.
If not then is there some test I can do to determine the best aperture to use?
Brian
 Brisn5757's gear list:Brisn5757's gear list
Olympus SP-570 UZ Sony Cyber-shot DSC-WX70 Sony Cyber-shot DSC-HX200V Sony RX100 IV Canon EOS 300D +9 more
Panasonic Lumix G 14mm F2.5 II ASPH
rashid7
rashid7 Veteran Member • Posts: 7,011
Re: Best aperture (sweet spot) for Panasonic 14 - 140 mm lens
https://www.ephotozine.com/article/panasonic-lumix-g-vario-14-140mm-f-3-5-5-6-lens-review-22632
F8 in general (if u don't need more light!)
I would never go smaller than f11, due to defraction, unless you have a compelling need for depth of field (macro?)
Keep it fun!
rashid7
Actually, ephotozine graphs seem to show that only at 14mm do you need to close down to f8.  At 50 and 140mm its pretty sharp wide open.  I would have expected the opposite, which seems to be the case with most zoom lenses i own.
I wish lenstip had reviewed it; I tend to trust them more.  Check out some others?
Remember, in most lenses, esp cheaper ones (?) there may be considerable copy-to-copy variation.  Often, aberrations are on the outside of the frame, which may be eliminated by using a smaller aperture (=larger#).
Only lens rentals does tests on multiple copies (normally ten!).  And their blogger, Roger C, plots the variation he finds.
Keep it fun!
alcelc
alcelc Forum Pro • Posts: 19,004
DXO's result
https://www.dxomark.com/Lenses/Panasonic/Panasonic-LUMIX-G-VARIO-14-140mm-F35-56-ASPH-POWER-OIS-mounted-on-Olympus-OM-D-E-M1-Mark-II---Measurements__1136
The following were extracted from the above and combined as below in terms of the sharpness test from 14 to 140 on evert f/stop. The greener the sharper, the more red the worse.
Source: DXO  Mark (Center, 1/3 field, 2/3 field, corner
I would say wide open of 14-140 f/3.5-5.6 could get the best result in most case (except for the best corner between 25~50 as from above.
In real life I keep this lens wide open all of the time. If I get any not crispy sharp result (center to 1/3~2/3 from focus point) on 1:1, 99% would be either because of shutter shock (the older models using the olde m-shutter or no e-shutter option) or stability issue of myself.
As a general rule for M43 lenses (except 45-200 and 100-300 which has their sweetest spot at f/7.1-f/8), f/8 could be the edge before diffraction will kick in to soften the output.
My 2 cents.
Albert
nevada5
nevada5 Forum Pro • Posts: 15,569
Article on diffraction here goes into a lot of detail that might help.  With M43 I usually consider f/11 as narrow as I want to go.
With regards to the 14-140 - I use the lens a lot and I've found that f/8 is where I get sharp corners, so I'll leave it there unless I have a specific DOF or shutter speed concern.
I'll try to be nicer if you'll try to be smarter.
Life is short - drive a convertible.
OP Brisn5757 Veteran Member • Posts: 4,540
Hi rashid7.
To be clear on what you mean when you wrote "using a smaller aperture (=larger#)."
would you refer to a f16 as a smaller aperture?
Brian
Thanks for the info nevada5.
Brian
Thanks rashid7.
I have too replies confirming f8 is the best aperture.
Brian
Re: DXO's result
My 2 cents.
Thanks alcelc.
It's good when many agree on one aperture setting (f8)
Brian
Great Bustard Forum Pro • Posts: 45,641
The answer is not so straighforward.
5
Brian
TLDR: The sharpest aperture for most situations is like from wide open to two stops down.
Let's begin with OL's MTF-50 tests of the lens:
In short, wide open to one stop down delivers the highest resolution *on the focal plane*. However, as you stop down, more and more of the scene is within the DOF. So, even when diffraction starts exacting a toll on the resolution on the focal plane, the photo, as a whole, may continue to have more resolution since more of it comes within the DOF.
However, when stopping down, one of two things necessarily happens:
  • Less light is projected on the sensor for a given exposure time, resulting in a more noisy photo.
  • To maintain the amount of light projected on the sensor, a longer exposure time needs to be used, which increases the risk/severity of motion blur.
So, what's the "best aperture"? Well, it's wide open if you want:
  • a more shallow DOF
  • less motion blur
  • a less noisy photo
And all three of those come as a set. But if you want a deeper DOF for an overall sharper photo, then the "best aperture" is most narrow aperture you can use up to the point that:
  • the motion blur is too great
  • the photo is too noisy
  • the loss of resolution due to diffraction is too great
All of these things are not merely subjective, but dependent on the scene and the viewing conditions of the photo.
Harold66
Harold66 Forum Pro • Posts: 12,002
OH waouh, this is a serious misconception.
ok let’s try to keep it simple. First you should never ever use the smallest aperture on ANY lens on ANY format. Except in very very close macro shots where the subject is only a few centimeters away’ there is no reason to do that, ESPECIALLY on smaller sensors
Now, while F8 on micro 4/3 sensor is going to give you great DOF,this does not mean this is the aperture where you are going to get the greatest IQ in terms of resolution.
The best rule of thumb on micro43rds is something like
You need to reason compared to the max aperture
on a bright single focal length say like a lens between 12mm and 45mm (24 to 90mm in 35mm equivalent) the best IQ would be reached between 2 and 3 stops from the maximum aperture
on a variabke aperture zoom say a f4 to f 5.6 transtandard zoom , the best aperture would be usually ONE stop from the max aperture or at the max aperture when the max aperture is the slowest (5.6 in this example)
at full aperture you lay encouter a bit of vigbetting ( although not too likely if the longest focal length is long and it is automatically fixed in post)
So if you want to make it simpler , i would summarize like this
Single focal length 2 or 2.5 stops
Zoom with fixed max aperture 1 stop
Zoom with variable max aperture 1 stop at the lowest end of the zoom. 0 pr 1 stop at the longest end of the zoom with the smaller maximum aperture
Now regarding extended DOF which is a different matter, you can stop down one more stop from this rule of thumb if the subject is only a few meters away but if the subject is like 10 meters away, there is no need to even close further down
Hope this helps
Brian
Harold
FOLLOW me on IG @ledaylightstudio.
thedemandingtraveler.org
www.haroldglit.com
IG :thedemandingtraveler
 Harold66's gear list:Harold66's gear list
Sigma DP2 Merrill Ricoh GR II Panasonic Lumix DC-G9 Fujifilm GFX 50S II Panasonic 20mm F1.7 II +5 more
rashid7
Hi rashid7.
Brian
yes Brian!
Keep it fun!
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Re: The answer is not so straighforward.
Brian
  • less motion blur
Beautifully explained.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
alcelc
Re: DXO's result
My 2 cents.
Thanks alcelc.
Brian
Not for this lens I am afraid.
Not go beyond f/8 is just to avoid diffraction effect only.
As per DXO's result, f/8 is already not the optimal performance of this lens. Nothing wrong to shoot at f/8 ( for the better DoF because it is eq to f/16 of FF already), but if looking for the best performance of this lens (sharpest), stop down to f/8 is not.
FYI.
Albert
Breb Forum Member • Posts: 84
I watched this yesterday, couldn't understand a word he said but found it interesting anyway. It's a pity no one else has done similar. He goes through various focal lengths at different F Nos and shows the sharpening effects. The first 14mm wide open is very poor at the edges but he stops it downs, big improvement, worth a look and be patient it's a fairly long video.
https://www.youtube.com/watch?v=0GerIcaXpeo
s_grins
s_grins Forum Pro • Posts: 14,011
F4.0 - F8.0
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
evetsf Senior Member • Posts: 1,707
Hi rashid7.
Brian
it might be time for an explanation of the term and syntax.
The proper way to write it is "f/x.x", because it is a mathematical fraction. The "/" is frequently left out, because that's the way it's spoken.
What it refers to is the physical diameter of the aperture of the lens as a fraction of the lens' focal length. Using a 100mm lens to keep it simple:
If f=100mm then
f/2 = 50mm diameter aperture;
f/4 = 25mm diameter aperture;
f/8 = 12.5mm diameter aperture
And so on for other values. Because the numeric value is the denominator of the fraction, the result (aperture diameter) gets smaller as the number gets bigger. Also, as the focal length of the lens changes, the physical diameter of the aperture will be different even if the f/number is the same.
Steve
 evetsf's gear list:evetsf's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH Panasonic 12-60mm F3.5-5.6 OIS +3 more
Brian
  • less motion blur
Hi Bustard.
It's like the old saying "You can't have your cake and eat it" so it's either one way or the either. I can deal with noise by having slower shutter speeds and if there is plenty of light I may be able to keep a reasonable shutter speed to avoid hand shake.
So it looks like the main problem is diffraction.
If I zoom with the lens to 140mm then due to the reduction in light I'm using the widest aperture most of the time and when I'm on the widest setting of 14mm then it improves the depth of field even at a wide aperture. So maybe not too many losses.
Brian
Hi rashid7.
Brian
If f=100mm then
Steve
Thanks Steve.
It can be misunderstood when people say small aperture (small number f1.8 or narrow aperture.  I think it's better to say wide or narrow aperture.
Brian
Re: DXO's result
My 2 cents.
Thanks alcelc.
Brian
FYI.
Hi alcelc.
If f8 is not the sharpest then I'm wondering what is, maybe going to f11 or f16 will give me better performance (sharper picture) or is going the other way having a wider aperture going to improve my sharpness (I'm not talking about DOF).
I was also told that diffraction reduces that photos sharpness so if I reduce diffraction shouldn't I get a sharper photo.
Brian
