HDR with RAW
Started Feb 6, 2020 | Questions
Phil_Rose
Phil_Rose Senior Member • Posts: 1,044
HDR with RAW
Hi all, This seems like it should be obvious or at least easily findable but perhaps my Googling is shoddy! I have a K1ii and I was trying the HDR function shooting RAW. I shot a shot (the top one in the attached) with no HDR and the bottom one with HDR and it shot three images and took a while to blend them. It looks a lot more HDR on the back of the camera. I take it into Exposure X5 and it just looks identical. All the HDRness is lost. It looks right in XNView (screenshot added).
Do I have to use Silkypix to do the edits while retaining the HDR look?
Thanks!
Phil
I like turtles.
www.philrosephoto.com
Pentax K-1 II
PeterPentax
PeterPentax Senior Member • Posts: 1,131
Re: HDR with RAW
It is likely your raw converter cannot handle HDR raw files. it is just selecting one of the three captures to present to you during editing. That is I guess why you do not see a difference.
Rod Herdman Veteran Member • Posts: 3,494
Re: HDR with RAW
Doesn't the in-camera HDR function only output a JPG ?
All I want is a digital back for my trusty K1000 . . .
 Rod Herdman's gear list:Rod Herdman's gear list
Pentax *ist D Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc DA 50-200mm F4-5.6 ED +12 more
Phil_Rose
OP Phil_Rose Senior Member • Posts: 1,044
Re: HDR with RAW
I can see the results on the back of the camera and in Xnview and I read a lot about people using raw to do it though I can't imagine how it works.
I like turtles.
Phil_Rose
Re: HDR with RAW
Thanks. Do you know what editors can handle them?
I like turtles.
Southern Gent
Southern Gent Regular Member • Posts: 148
Re: HDR with RAW
I use LR as the first stop, and don't recall having problems importing an in camera HDR dng file. The latest version of ACR also handles Pixel Shift as well, but I believe DCU5 is still better.
Phil_Rose
Re: HDR with RAW
Interesting. I don't use LR. I just installed DGU and it's good to have that as a backup though it's so slow and clunky that would be a rare thing indeed.
Thanks for the help though!
Phil
I like turtles.
PeterPentax
Re: HDR with RAW
I think Silkypix Developer Studio Pro can.
What I do however is to take 3 or five raw shots using bracketing and then process them in Lightroom using the HDR merge tool.
The K1 and K1II have such great dynamic range it is often just as good to make a raw capture exposing for the highlight regions and then bring out the shadows in PP. This avoids the need for HDR.
Phil_Rose
Re: HDR with RAW
Yeah, I use Photomatix to bulk process RE images. Realtors all want HDR! I just wondered if I could do it in camera but it seems impractical.
I like turtles.
Southern Gent
Re: HDR with RAW
I only use DCU5 on a limited basis (pixel shift), and you're right it can be a little clunky to use, but for what it does, it does it well.
PeterPentax
Re: HDR with RAW
You can produce a JPEG in camera in HDR.
Phil_Rose
Re: HDR with RAW
Of course! I was narrowly focused on RAW. Thanks for the reminder. I'll see how that does.
I like turtles.
Re: HDR with RAW
PeterPentax wrote:
It is often just as good to make a raw capture exposing for the highlight regions and then bring out the shadows in PP. This avoids the need for HDR.
Yes, this is what I do, with a single image. I use the HDR tool in Silkypix, it works well for the majority of cases except of course the most extreme dynamic range.
Fotoni Senior Member • Posts: 1,091
Single photo not really HDR
Usually HDR means higher than what camera can do with a single photo. Why call something HDR, if it is normal performance? Decent dynamic range has been there for several years and little improvement since then. HDR is not the same as lightening shadows strongly with post-processing which either produce noisy mess or the scene has low contrast which is not really HDR either.
The main reason for HDR and HDRish post-processing confusion is that many displays have low dynamic range or are very small to make the difference between HDR and fake HDR:
 Fotoni's gear list:Fotoni's gear list
Pentax K-1 Pentax FA* 50mm F1.4 SDM AW Canon PowerShot SD4000 IS
Roland Karlsson Forum Pro • Posts: 30,035
Re: Single photo not really HDR
I am not sure you are right. I only think HDR means mapping a high dynamic range image to a smaller dynamic range, matching the output medium. If the original comes from 1, 2, 3 or more shots does not really matter.
But sure, if the camera has an HDR mode it usually means taking three images.
/Roland
Kalpanika X3F tools:
https://github.com/kalpanika/x3f
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony RX100 III Pentax K-3 Pentax K-1 +14 more
miles green
miles green Veteran Member • Posts: 7,827
Re: HDR with RAW
Everyone does HDR a little differntly - a diffent mappping of a high DR image to a jpg 8 bit. By HDR effect, i tink we usually mean that local adjustments are made to brighter and darker areas of the image, a bit like dodging and burning.
That said, if you like the Pentax flavour of HDR, make sure you save a jpg in camera. I've noticed that these are pretty good in some cases, and the K1ii will auto align the 3 images, giving much sharper results that some raw developers *coughlightroom*.
Here's one, in camera HDR was better than what i managed in LR. Maybe my LR skills need tweaking?
Miles Green
Pentaxian since 1997!
Corfu, Greece
N.B. All my images are protected by Copyright
 miles green's gear list:miles green's gear list
Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +7 more
Southern Gent
Re: HDR with RAW
Actually the K1MII has several options for composing HDR in camera,  Auto, 1,2,3, and ADV. Auto chooses the bracketing, 1,2,3 is predetermined, and ADV is similar to HDR 2 with a boost in contrast and saturation. If you shoot raw you have the option of selecting one image and discarding the others. I rarely use it,  prefering batcketed shots composited post, so i cant really say how well it works.
Phil_Rose
Re: HDR with RAW
Now that's a great idea! Shoot HDR in camera and convert in camera to JPG then you have the option to use the JPG or the RAW in  Pentax software afterwards.
Pentax software
I like turtles.
timo Veteran Member • Posts: 5,927
Who wants 'HDRness'?
I am not sure why anyone would want the 'HDR look' - that usually means that something has been overdone. If the camera is already capturing the full dynamic range of a scene in one shot, surely a natural-looking 'HDR' shot shouldn't look any different.
This has probably been pointed out already, but Lightroom is one of the easiest possible ways of achieving HDR. Just fire off three bracketed shots, and LR blends them in moments, including alignment - and will save them as a DNG image. Much more control than doing it in the camera.
Tim
'If I were you, I wouldn't start from here ... '
http://timauger.smugmug.com
http://timauger.blogspot.sg/
 timo's gear list:timo's gear list
Fujifilm X30 Pentax K-5 Pentax K-30 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8
PeterPentax
Re: Who wants 'HDRness'?
I use LR to do a HDR merge from bracketed shots. I think it works well.
As far as HDR "look", if it is overdone and looks unnatural then I don't like it. HDR merge either in camera or in software is very useful in a high DR scene like an interior shot but with a window showing a bright scene outside.
What we see with our eyes and what a single camera exposure can capture are two very different things. Our eyes compensate automatically and very quickly, the camera cannot in a single frame. So when you use terms like "natural looking", you have to allow for the fact that a single capture may not be "natural".
