Would a DP0 or Dp1 Quattro be suitable as an only camera on vacation?
firoze
firoze Regular Member • Posts: 192
Hello, I will be visiting Athens and the Greek islands on vacation soon. So far, on all my vacations I have used a camera with a zoom lens. Do you think a fixed lens camera like a DP0 or a DP1 would be suitable as an only camera? My genre of photography are landscape, architecture and close ups of flowers etc. (I am not keen on a SD Quattro because with a zoom lens it would be too heavy and bulky. I prefer lighter smaller cameras when travelling).
Thanks in advance.
 firoze's gear list:firoze's gear list
Sony RX100 Leica X Vario Leica V-Lux (Typ 114)
Sigma DP1 Sigma dp1 Quattro Sigma sd Quattro
jande9
jande9 Senior Member • Posts: 1,538
Re: Would a DP0 or Dp1 Quattro be suitable as an only camera on vacation?
I took my DP2M as my only camera on one trip to the UK.  I go often so I thought that the discipline would be interesting, like travelling with a fixed lens Rollei 35 film camera.
It did not turn out well.  I found that there were too many situations where the Sigma couldn't cope with the conditions.  Church interiors, wedding parties, deep forest walks.
Now I always take another camera in addition to the DP2.
A good phone might suffice for you, but your RX100 seems to be the ideal general purpose travel cam.  I borrowed my son's for one trip and used it a lot for my travel snaps.
Jan
 jande9's gear list:jande9's gear list
Canon PowerShot A650 IS Sigma DP1s Sigma DP2 Merrill Panasonic FZ1000 Sony Alpha NEX-7 +4 more
otumay
otumay Contributing Member • Posts: 573
Thanks in advance.
I think DP0 will serve admirably during your coming vacation in Greece.
If I do not wish to carry heavy gear, I usually end up with DP0 AND DP2, both Quattro models. Since they use the same batteries, I carry only one battery charger.
 otumay's gear list:otumay's gear list
Sigma DP1x Sigma DP3 Merrill Sigma dp2 Quattro Sigma dp0 Quattro Sigma SD10 +18 more
xpatUSA
xpatUSA Forum Pro • Posts: 17,893
firoze wrote:
Hello, I will be visiting Athens and the Greek islands on vacation soon. So far, on all my vacations I have used a camera with a zoom lens. Do you think a fixed lens camera like a [dp0] or a [dp1] would be suitable as an only camera? My genre of photography are landscape, architecture and close ups of flowers etc.
In terms of composition, especially for reasonable perspective, I would take the dp1 because you mentioned close-ups.
But that was not your question. For vacation, I would prefer a range-finder style camera, m43/APS-C with a reasonable zoom lens on it.
(I am not keen on a [sd] Quattro because with a zoom lens it would be too heavy and bulky.
Too many variables, not enough grey cells ...
Ted
Panasonic Lumix DMC-LX1 Panasonic Lumix DMC-G1 Sigma SD9 Sigma SD15 Panasonic Lumix DC-G9 +13 more
firoze
OP firoze Regular Member • Posts: 192
Jan
Thanks, I did suspect indoor shots would not turn out well with the DPQ. As you say, my RX100 could come to the rescue in those situations.
firoze
otumay wrote:
Thanks in advance.
I was considering the DP0 for it’s wide angle lens (and of course for the Foveon sensor). Unfortunately while a ultra wide is very useful indoors like in cathedrals etc, I suspect the low light capabilities of the DP0 might disappoint. As Jan above suggests, I could use my RX100 in those situations.
Dryce Regular Member • Posts: 479
It depends on how/what you shoot.
Personally - if I was going to carry just one DPM or DPQ then it would be the 1 or 2.
Usually I don't travel with just one DPM or DPQ but if travelling light take one (most likely the DP0Q) plus a mirrorless camera.
 Dryce's gear list:Dryce's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Sony Alpha DSLR-A700 +3 more
firoze
I already have the Leica X Vario which has a 28-70 lens, but I wanted to experience the Foveon magic, and wanted to use a ultra wide, hence the choice of DP0. However I do not want to carry both these cameras.
I was wondering whether a fixed focal length would suffice on vacation?
The other option for a small high quality camera would be the FP with 45/2.8. I know the FP  doesn’t have a Foveon sensor, but it’s files do have a bit of the Sigma/Foveon DNA. I tested one recently and liked the IQ. And the FP’s low light capability is excellent. But again I wonder if I could get away with only a 45mm lens on such a trip.
RX100 plus a DP0Q sounds like a good combination.
D Cox Forum Pro • Posts: 27,093
Jan
A table-top tripod can be very handy in such cases. And the dp0Q accepts the Sigma remote control cable, which is an excellent gadget. A tripod also allows you to save the special bracketed HDR files called "SFD Mode" (see the Additional Info" PDF). SFD gives good results inside churches, for instance.
I suggest downloading the manual to help you decide.
https://www.sigma-global.com/en/download/cameras/brochures-manuals/#dp
Sigma fp
firoze
My choice of a single Quattro would be the DP0 for its ultra wide lens. But I guess DP1 or 2 would be more versatile.
firoze
That sounds like a good solution.
firoze
Many thanks for the link, I will download the manual and read up on the SFD mode.
It's in the Additional Info PDF as it was added in a firmware update.
Sigma fp
Graham Gibson Contributing Member • Posts: 752
Maybe a DP1 with a Ricoh GW-4 or 3 addon lens to go wider when needed. For close-up flowers and low light, I think the DP0 lens would be a big limitation. Also, I find the 28mm focal length to be more usable for all-around shooting. Wide enough for most scenes, but still possible to crop in a bit.
firoze
Thanks Graham, I will give this a thought.
Sjak
Sjak Senior Member • Posts: 5,613
This is very personal, and also depending on how and what you typically shoot.
On a recent trip to Hungary, I took my Monochrom with me, with just a few lenses. Eventually, most lens-switches were for the sake of playing with another toy. In hindsight, I would have been fine with just a 40mm and an orange filter.
On a trip some time ago, I had my (old) DP2 with me for the daytime/outdoor-shots, and my Fuji + a standard prime for the indoor/night-time.
If you don't do much indoor or nighttime, just a Sigma would be fine. Otherwise, add a second compact camera.
 Sjak's gear list:Sjak's gear list
Panasonic Lumix DMC-LX7 Pentax K100D Pentax K10D Leica M-Monochrom Fujifilm X-T1 +1 more
firoze
This is excellent info, thanks. I would mostly shoot outdoors in daylight, or evening light. For the rare indoors and night shots, I could make do with the RX100.
Iconoscope
Iconoscope Regular Member • Posts: 450
No.  These are much too limited unless you buy all four of them!  Even a 3X optical zoom would have made a more versatile and usable camera.  But if you insist on using a DP camera, get a DP2M or DP3M and include an adapter to attach a wide angle converter.
 Iconoscope's gear list:Iconoscope's gear list
Sigma DP2s Kodak DCS Pro 14n Sigma SD9 Sigma SD15 Panasonic Lumix DMC-GH1 +7 more
firoze
Thanks. Why do you suggest getting a Merril instead of a Quattro?
