What is an M3 still good for?
Started Feb 5, 2020 | Discussions
Microprism Contributing Member • Posts: 865
If anyone prefers manual focus lenses and is on a budget, you might look at this model. Working copies can go for under $150 on eBay and if you ignore the autofocus system (which is terrible) you might like the results. Here are some of examples from a blooming pear tree shot with the lens set to manual focus:
 Microprism's gear list:Microprism's gear list
Canon EOS 5D Canon EOS 7D Canon EOS M6 Canon EOS M6 II Canon EF 50mm F1.4 USM +22 more
Canon EOS M3
lilBuddha Veteran Member • Posts: 6,258
Re: What is an M3 still good for?
The M3 is a terrific camera. I'm not sure what the problem with the AF is. I don't recall any serious problems with it. I primarily use the touchscreen to focus and rarely, if ever, encounter problems with it.
Andy01 Veteran Member • Posts: 5,188
I think that to say the M3 AF is terrible is a bit of a hyperbole. The AF is quite accurate - just slow.
For most static shots, or even slow moving action, the AF is perfectly adequate. The general speed and responsiveness (eg. 3 shot AEB) of the camera is slow.
The actual IQ I found was quite good. Sometimes the colours were a bit off and needed some adjustment in post, but the camera is quite capable of producing very good images.
If you said that the camera was terrible for fast action, birding etc, I would certainly agree with you, but for many people taking holiday snaps, or general family shots, there is not much wrong with it.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
I still have my original M (along with an M6 and M6II). The AF is fine. It's not lightning fast, like the M6II, or as fast as the M6, but it's more than adequate for most uses, including portraits and landscapes. It copes perfectly well with the kind of shots you posted. I used the camera extensively for nearly four years, before getting the M6, and never used manual focus. I don't recall reading that the AF on the M3 is worse than on the M, in fact quite the opposite. So I'm sure the M3's AF will cope just fine with most subjects, though probably not BIF or fast sports. Having said all that, I'm pretty sure that you can get an M6 or M5 in good condition for about $250. In fact, you can get it new on Amazon bundled with the 15-45 for $450. I would say it's definitely worth paying an extra $100 for the M6 over the M3, and worth paying an extra $200 to get a new M6 ($450 - $100 for the lens), unless money is really very tight. All the improvements in the M6 over the M3 add up to far more than $100 worth.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Abu Mahendra Veteran Member • Posts: 5,312
Pure BS
AF is terrible - pure BS
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
OP Microprism Contributing Member • Posts: 865
Actually it didn't cope well at all. With a bit of a breeze the AF couldn't keep up with the movement of the flowers and branches — which led to my comment. I agree it should be fine for objects that are truly static and in other respects is a very nice camera.
Re: Pure BS
If a camera can't focus on a subject that is moving back and forth by only inches how would you describe the AF?
plantdoc Veteran Member • Posts: 4,339
Re: Pure BS
Flowers moving in the Wind can be like fast action focusing plus limited DOF and subject movement and a difficult focus point. For moderate macro pics, the subject needs to be still and so do you. Remember manual AF? Very slow. My M3 was OK for anything but action pics if using a stm lens. Vastly better than manual focusing slr used for 30 years.
Greg
Pure BS or Inept
I would describe the person operating the camera as 'inept'.
Alastair Norcross
That's weird. My M copes with that kind of situation well. Were you in servo using single point, or all points? Perhaps the M3 AF is not as good as the original M (after firmware update). I have seen people say that the M3 is the worst of the M line, but I've never tried one, so I don't know.
Alastair
nnowak Veteran Member • Posts: 9,073
Re: Pure truth
No, it really is terrible.  Of all the M system cameras, the M3 is the only one where the AF is completely incompatible with the EF 50mm f/1.4.  Up until the release of the Sigma 56mm f/1.4, the Canon 50mm f/1.4 was the best option for a portrait lens and it flat out does not work on the M3.
I also tested my M3 side by side against my original M with several different lenses.  The M3 would throw up a red "AF failed" box in several situations whereas the M would slowly but surely achieve focus.  When it worked, the M3 would be faster, but all too often it didn't work.  The M just worked.  The M2 works even better.
RLBur
MOD RLBur Veteran Member • Posts: 5,551
Civil
We can disagree and still be civil.
Randy
 RLBur's gear list:RLBur's gear list
Canon PowerShot A640 Canon PowerShot G1 X Canon PowerShot S120 Canon PowerShot G7 X Olympus PEN E-PL1 +10 more
fstopx2 Senior Member • Posts: 1,088
Re: Pure truth
Whats it good for?
Selling it and putting the money into a newer M.
I had the M, M3 and M5. I would say the M3 is marginally better than the original M but not by much. The M3 had difficulty with more EF/EFS lenses and situations than the original M. I had some lenses the M3 would not focus at all. It was only a marginal improvement over the original M IMHO.
Both the original M and the M3 take very nice pictures but they are hardly fast.
Re: Pure truth
fstopx2 wrote:
Whats it good for?
This supports my original point that the M3 is quite a nice camera for manual lenses. It has one dial less than the M6, but most manual lenses have an aperture ring so the control ring can be dedicated to shutter speeds. AF performance is irrelevant with a MF lens attached. The image quality output of the camera is not much different than the later M5 and M6 (or maybe the M which I never had).
Thanks for the thoughts on this. I used 1 point AF in One Shot not Servo mode. Maybe Servo would have made a difference? The tree is near where I live and I had taken photos with an M6 the day before without any issues under the same conditions. Anyway, the M3 worked so well in manual focus mode that I thought to mention it if anyone out there is looking for that sort of thing.
Re: Pure BS
Greg
Your points are well-taken. This was the wrong subject for this camera's AF system.
Re: Pure BS or Inept
Duly noted.
Re: Pure truth
Microprism wrote:
fstopx2 wrote:
Whats it good for?
That is if you want to focus manually . Frankly I cannot tell which camera took which picture between the M, M3 and M5.
I never cared for the M3's buttons/dials, I found them too tiny and fiddly. They took functionality that was on the screen with the original M and pushed it to buttons/dials. You end up with this hybrid operating model between the screen and buttons. I would rather do it on the screen like the original M or your favorite smartphone.
The M3 was one of the few cameras that I was sorry that I bought because there was not a huge difference between it and the original M.
The original M is very robustly build, the M3 not so much but its better the M5 and later.
In my experience, I would say the AF is fine for more subjects than it isn't. For macro work, IMO anything but manual is rubbish. Why, because I frame my subjects intentionally. I don't want a flower or insect merely in focus, but in place as well. If the subject moves, the shot is not what I want, sharp or not.
Is the AF on the M3 perfect for everything? No. That doesn't make it rubbish.
I regret my choice of words. I agree the AF system has limitations, but it is not "terrible" — at least not for everything. Outside of that, I like the results from this camera.
