One camera body, 2 lenses under $1000?
Started Feb 5, 2020 | Discussions
csnite
csnite Regular Member • Posts: 156
I am currently in a conundrum over options for MU43 for me.  My history with the format was E-pl1, E-pm2, Em5, with a gf1 thrown in there somewhere. I moved to fuji after the em5 and liked it ok. Last year I went whole hog in with the xt3, 18-55, 35 1.4, rokinon 12, and 56 1.2, then hit rough financial times, so sold it all in November. I now have a moderate amount to spend on a system. I got tired of dealing with the xtrans files and I am pretty sure that the mu43 quality is perfectly fine for my travel/family pictures.
I am looking to spend $1000 or thereabouts. My only two lens requirements are a decent travel walkaround covering roughly 14-60ish and a "standard" fast lens. I may add more in the future, but I found with my fuji I pretty much used the 18-55 and 35 1.4, with the 56 and 12 almost never being used.
Here's my options unless I am missing something.
E-M10 ii, 14-150, 17mm 1.8 (or 25 1.8 which I used and like but wished it was a little wider) New this is around 1250, but I don't have a problem with used and could find all of these pretty easily.
GX-9, 12-60, 25 1.7 (which I am concerned about because the EVF of the gx85 turned me off pretty badly)
If you had $1000 and wanted to buy a body, fast normal, and walkaround zoom, what would you buy?
 csnite's gear list:csnite's gear list
Olympus TG-5 Sony a7C Tamron 20mm F2.8 Di III OSD Samyang AF 75mm F1.8 FE Sony FE 40mm F2.5 G
Fujifilm X-T3 Olympus OM-D E-M10 Olympus PEN E-PL1 Olympus PEN E-PM2 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX85
Luke Forrest Senior Member • Posts: 1,072
Re: One camera body, 2 lenses under $1000?
The em10ii viewfinder isn't really any better unless your eyes are prone to the rainbow tearing effect. But if you don't like the evf and this is how you compose then it's not really an option.
You could buy the new fuji xt200 with kit lens and new xc35mm f2 for a $1000. If you're used to the fuji system this might work and the xt200 doesn't use an xtrans sensor.
Within M43, there is also a Panasonic G85 with 12-60 kit lens for a little under $700. This is a weather sealed option. It leaves $300 for another lens.
There are probably a lot of options if you shop around, especially used kits.
best of luck
rashid7
rashid7 Veteran Member • Posts: 7,011
every option means some sort of compromise.  The Olympus route you mention sounds good.
If you are willing to settle for 16mp, you might consider the GX8 2-lens kit and have $400 left over for a nice prime (or2)... but you have to live with the EVF.  (Its the same on GX9).
The g85 is in my opinion the best all-around m4/3 camera for the $ right now.
I love the Lumix menu sys, and they have the best contrast AF  -  if you aren't spending more.  Also their kit lenses tend to be best
Keep it fun!
pannumon Veteran Member • Posts: 4,130
5
G80/85 instead of GX9, but depends on your preference. You should be able to get G80/G85 with these two lenses for $800 or $900.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
csnite
OP csnite Regular Member • Posts: 156
Yeah, unfortunately, the rainbow tearing really bothers me, especially with my glasses. I could look past it, but it's probably always going to bother me.
rashid7
correction = the gx85.  The GX8 has a fantastic EVF, and, even used, is more pricey
Keep it fun!
Yar1971 Regular Member • Posts: 410
This is exactly the setup I currently use. With 17/1.8, not 25mm. 14-150 is a heritage from my previous camera (E-PL-1), 17/1.8 bought separately second hand, the same  as 14/2.5 I previously used (still have). I'm mostly photographing tourist, so 90% of my images are from travels or local trips. Fast prime is mostly used for interiors and for outdoor photo in evening. From that point of view wider option is better than "standard" 25mm lens. I can honestly recommend this set.
The only reason to choose 25/1.8 (why not very cheap and almost equally good 25/1.7?) instead would be using it to capture portraits of single people with more blurred background. But You will lack something wider for general interior shots. If longer FL is Your priority, later You may add something smaller&wider, like 14/2.5. 15/1.7  would be better than 14/2.5, due to better F/stop but is more expensive and bigger (I mean the case if You decide for 25mm first).
Another story is If You rally need ultrazoom of 14-140, 14-150 class. I need, because I like photo of accidentaly spotted wildlife on the trail. That's why cannot use better optical solution: a separate tele-lens. Usually there's no time to change lenses on unexpeted targets. Landscapes, bvuildings do not escape from the frame. Wildlife, people and vehicles do.
If Your needs are different, the better solution seems to be something like 12-60/3.5-5.6. That gives You 12mm at wide end, this is what my setup is lacking ( i'm going tu buy in the future a small prime wider than current 14mm, probably 12/2.0). Note, that You can use this glass (as any other) both on Pana or Oly body. The only really important limitation is when You want  to use Oly lenses on some of Pana cameras, that has no built-in camera stabilisation.
If You need longer tele than 60mm from time to time on planned occasions, You may later add a tele-lens, like Oly 40-150 (cheap&good).
-J.
larsbc Forum Pro • Posts: 18,282
yes, you're missing something
You're missing something: Panasonic G85, Panasonic 12-60/3.5-5.6, Panasonic 25/1.7
Or skip the 25/1.7 and get the Olympus 17/1.8.
G85 has fantastic handling, pretty good battery life and excellent video.  AF for stills is fast and accurate even in low light.  Continuous AF for stills and video, not so much (like any m43 in that price range, really).
Asla
Asla Senior Member • Posts: 1,101
Hi!
Of those I'd pick oly body pana 12-60mm and oly 17mm...
But when I think better, either mix of those would be fine!
A s l a
AndyH44 Veteran Member • Posts: 3,112
G85 kit (12-60 f3.5-5.6)  + P20 f1.7
Nothing else matters!
"The world doesn't exist to satisfy our expectations."
alcelc
alcelc Forum Pro • Posts: 19,005
Not an Olympus man. So concentrate on the Panny I know better. If 12 (i.e.,24 in FF or 16 in APSC) means small to you:
For size and weight, GX85 (lower cost) or GX9 and 14~140;
For ergonomic, G85 (on budget) or G95 and 14~140.
A fast lens to supplement the above: 25 f/1.7 (on budget), 20 f/1.7 (for the size) or 15 f/1.7.
Except G95, actually any combination of the above could meet with your budget with an exchange spares for a <US$100 12~32 for the wider end.
Albert
gary0319
gary0319 Forum Pro • Posts: 10,540
I have the E-M10 II, 14-150 and 25 1.8. Shop around and you should get what you want for well below the $1K mark.
BTW I think the E-M10 II is one of the best (if not the best) Olympus cameras ever produced.... and the 14-150 is so good it is now glued to the front of my E-M5 III.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
johnpatrickbishop Regular Member • Posts: 276
Another vote for the G85
With 12-60 kit lens and then a 1.7/1.8 prime of your choice focal length. I own a GH5, but the G85 really does everything I need. Some of my favorite photos have come from the G85. It was the camera that really sold me on M4/3.
Also consider lenses on eBay/MPB.com. I've had good luck and good deals.
 johnpatrickbishop's gear list:johnpatrickbishop's gear list
Ricoh GR II Panasonic G85 Panasonic GH5 Nikon Z6
piccolbo New Member • Posts: 0
Re: yes, you're missing something
I wouldn't mix pana bodies with oly lenses because you lose DfD, hence CAF speed. As was already said, CAF is not a strength of the g85 or any other m43 body in this price range. It's not a strength of the S1 either. It'a a Panasonic weakness (oly has one phase detect model which apparently does better). If you work without DfD you lose another something, and I haven't been able to find any tests of how big that something may be. So it's an unknown penalty. Of course, that if CAF matters to you at all, some people never turn it on.
RSTP14 Veteran Member • Posts: 6,370
gary0319 wrote:...
BTW I think the E-M10 II is one of the best (if not the best) Olympus cameras ever produced.... .
Interesting, why do you think so?
Roger
 RSTP14's gear list:RSTP14's gear list
OM-1 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-45mm F4 Pro +4 more
gary0319
rogerstpierre wrote:
gary0319 wrote:...
I have had the E-M10, E-M10 II, E-M5 II, E-M1, E-M1 II, and now the E-M5 III and I think the E-M10 II is the Olympus sweet spot for size, features, performance and price. On a recent trip to the Rocky Mountain National Park I took the E-M10 II as a backup to my E-M1 II and ended up using it for almost 90% of my shots. I used it with my 12-40 Pro for landscapes, the 14-42 pancake in my jacket pocket and the 14-150 on hikes. The E-M1 II mostly stayed in the car with the PL100-400 on it, awaiting the rare sighting of a moose or elk.
Some of the E-M10 II shots from that trip.
Doom Scythe Regular Member • Posts: 286
A sound choice. I don't know the prices in your country, but I would opt for what you suggested if you don't shoot so often in low light.
E-M10 Mark II - Body only for $450
Olympus 14-150mm - $350
Panasonic 25mm f1.7 - $150
That fits nicely into your budget for $950. All prices are quoted for new set, street prices.
Alternatively, you can opt for the following for better lowlight and overall sharpness:
Olympus 12-40mm - $650
Slightly more expensive, but you get 1 glass for all.
 Doom Scythe's gear list:Doom Scythe's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 +5 more
Fairlane Contributing Member • Posts: 518
I would go for the GX-9, 12-60, and 25 1.7.
Then I would add the Sigma 16mm 1.4
should be doable within your budget.
I have the GX9 myself, and the 25 1.7. Also have the Sigma lenses, which I absolutely love,  the 16mm and the 56mm. By far my most used lenses. The 25mm Lumix is also quite good.
 Fairlane's gear list:Fairlane's gear list
Panasonic Lumix DC-S5 Panasonic Lumix DC-S5II Panasonic Lumix S 20-60mm F3.5-5.6 Sigma 85mm F1.4 DG GN Sigma 105mm F2.8 DG DN Macro +1 more
rashid7
I love my Sig30f1.4... but the 16 is too heavy, Pro-heavy.  I opted for the 15 instead.
Keep it fun!
Heavy? It weighs 400g. The GX9 weighs around 450g. I find it balances perfectly, and my much smaller primes tend to stay in the bag...
