SX530HS - Alternatives to FA-DC67A
Started Feb 4, 2020 | Discussions
pedroandrade New Member • Posts: 1
Hi everyone,
I own a Canon PowerShot SX530 HS, and I am interested mostly in using it for macro photography. I acquired a Raynox DCR250 close-up filter, and to connect it to the camera I read that the recommended adapter model is the FA-DC67A.
However, using this configuration (SX530 + Raynox + FA-DC67A) was terrible, specifically because this adapter never screws on properly. As far as I can tell neither the adapter or the camera is damaged, and I've even watched video tutorials just to check if for some reason I was not screwing it properly. It is just that the adapter screws on only very slightly, and the weight of the subsequent lens makes it very easy for it to fall down.
Does anyone know of any alternatives to the FA-DC67A adapter? I was particularly interested to know of any that could use the internal screw on the lens, instead of the one outside where the FA-DC67A attaches (which seems to be a very flimsy screw).
Thanks for the help!
Canon PowerShot SX530 Canon PowerShot SX530
Dugboy 1805 New Member • Posts: 3
Re: SX530HS - Alternatives to FA-DC67A
Hi you say that the adaptor won't screw on if you go on a website called photo 24 stating your camera make/model you will be able to purchase
an adaptor/lens specifically for camera you have
PS this adaptor clips on rather than screws on as there is no threads on SX 530HS models hope this has shed'some light on your problem👍
labrie Forum Member • Posts: 65
I own a SX50 and a non-Canon adapter, so my experiences may be not applicable, but it seems that SX530 lens is very similar.
The adapter uses bayonet mount, not screw; it turns about 90 degrees CW and locks with audible click, then it sits in place; I see no way for it to fall down (other than breaking either the adapter or the lens). I believe the original Canon adapter has to be mounted the same way; but from your description it looks different. Maybe some dirt is blocking turn? Did both "leafs" of the adapter mount get caught by on-lens counterparts?
The one I use was bought together with lens hood -- it's JJC LH-JDC100, I see plenty of them on ebay, each with adapter. About half the price of Canon adapter alone, and you can mount the lens hood and filter at the same time. There may be better ones, of course; this one just works for me.
As Dugboy 1805 has stated, the lens has no screw -- these grooves just go around, they don't form a thread. I've seen metal filters forcibly screwed in -- it can be done, but I wouldn't damage my camera like that.
Please, feel free to correct my English.
