Rebel t6 slave flash
Started Feb 3, 2020 | Questions
Mozz New Member • Posts: 1
Hi,
I was hoping to utilise an old manual flash for occasional indoor shots, I have an optical slave flash shoe. The pop up flash triggers the off-camera flash but somehow the shots come out darker than with the pop up flash alone.
Test shots are with everything set to manual, shutter speed tried between 1/60 & 1/200.
Is the camera compensating for the extra light? If so how when everything is on manual?
I appreciate the best answer is to spend a few hundred $$ on a dedicated flash but can't justify it at the moment.
Any assistance greatly appreciated.
Canon EOS Rebel T6 (EOS 1300D)
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: Rebel t6 slave flash
Mozz wrote:
Hi,
The built-in flash operates in ETTL auto only. It fires a low power pre-flash for metering just before the shutter opens, determines the flash output level needed then fires again when the shutter opens. Other digital SLR camera brands operate similarly.
The 2 flashes happen so quickly you normally perceive just one flash, but your optical slave is reacting to the pre-flash and triggering the slave before the shutter opens. The slave's light fools ETTL metering that the scene is bright so it fires the built-in at a much lower output, and the slave's flash has quit when the shutter does open.
You need "digital" optical slave trigger that ignores the metering pre-flash, or an inexpensive 3rd party radio transmitter/receiver set.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
