Olympus PEN e-Pl6 shutter count menu repeat access
Started Feb 2, 2020 | Questions
Paul 1712 New Member • Posts: 8
Hi
I managed to get into the shutter count menu by going settings>spanner>lcd settings and then pressing info and ok however I now need to look at that menu again and following the same process again doesn't work. Can you only access this menu once?
Paul
 Paul 1712's gear list:Paul 1712's gear list
Olympus OM-D E-M10 Olympus PEN E-PL6 Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ
Olympus PEN E-PL6
Brian Chichester
Brian Chichester Senior Member • Posts: 1,114
Re: Olympus PEN e-Pl6 shutter count menu repeat access
Paul 1712 wrote:
Hi
Paul
The full sequence for shutter count access is long and complex and involves some key presses that don't show a response on screen. It's possible that you went wrong somewhere without realising. One wrong press and it doesn't work (and it doesn't tell you why).
 Brian Chichester's gear list:Brian Chichester's gear list
Olympus XZ-2 iHS Olympus Stylus 1 Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +3 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Brian Chichester wrote:
Paul 1712 wrote:
Hi
Paul
Hmmmm, surely after 5 months the OP has sorted it out.
It certainly is endlessly repeatable and I found that it seems to take a moderately slow and steady pace of pressing the buttons to have 100% success time after time. Do it too quickly and it seems to fail.
