A very mixed experience with the RF 70-200 f2.8
Started Feb 2, 2020 | Discussions
BobNL Veteran Member • Posts: 5,196
5
Hi everybody,
I'm a dancesport (and event and concert) photographer based in Germany. Since November last year, most of my work has been done with the EOS R. About 90% of the time I use the 70-200 2.8 is used for dancesport. So I was pretty excited when Canon announced the 70-200 RF. But it was a long wait and expensive! Because of the high price I thought I'd better try it out first on a real-life situation so I rented it for a weekend to shoot the Goldstadtpokal in Germany.
In the 2 days before I tried the lens out around the house and was very impressed with the optical quality and the image stabilization. It is actually phenomenal in that regard. I also liked the size very much and already saw myself going out and about with a considerably smaller bag for my kit.
Unfortunately, under stress, the lens turned out not to be what I hoped for. The first big problem is the throw of the zoom ring. It's too long and stiff. With my EF version, I use my thumb to quickly go from 70 to 200 and back. This is not possible with RF, it slowed me down a lot. Causing me to miss moments and cutting off limbs way too often. I needed at least two throws and the stiffness didn't make it a pleasant experience.
Secondly, the lens was slow to operate. Switching from one couple to another was taking up so much time. It took way too long until it focused on the next subject. As if it made a very smooth focus pull for video. And that is IF it immediately focused on the new subject. I often had to actuate the AF 2 of 3 times for it to properly focus. Causing me to miss unfortunately a lot of moments. I didn't have this problem with the EF version on the R.
So will I buy the RF 70-200? No probably not. But maybe it was some user error, some set-up mistake. Was maybe this single lens not good? Anyone here with different experiences?
And as the last (personal) note; as good as the lens is technically, it is very neutral and therefore lacks some character. The files felt a bit emotionless.
 BobNL's gear list:BobNL's gear list
Sigma dp1 Quattro Sigma SD1 Canon EOS-1D X Sigma sd Quattro Sigma fp +12 more
dmanthree
dmanthree Forum Pro • Posts: 10,302
Re: A very mixed experience with the RF 70-200 f2.8
I haven't used the RF yet, but I have used the F4 EF version. The short throw zoom ring and ease of zooming the entire range is important. Curious to see if others report that having a long throw and stiff zooming action is an impediment to shooting action.
Luckily, we have choices.
---enjoys shooting with inferior gear---
Battersea Senior Member • Posts: 1,091
Thanks for your experience review
I look  forward to reading what others have experienced.
 Battersea's gear list:Battersea's gear list
Canon PowerShot G16 Canon EOS 7D Canon EOS 6D Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM +6 more
NoTicket Regular Member • Posts: 218
7
RF owner here.
The long focus throw is a problem for some. I got used to it very quickly. But it is going to be a real issue for some people, and that is not something anybody should argue really. You CAN get used to it tho. I have gotten to the point where I zoom from 70-200 in one go with the RF.
On the EOS R the autofocus is faster on the RF than the EF. Any limitations in autofocus speed have been due to the EOS R being not a very good performer in this respect, regardless of EF / RF. It is possible that you lost focus and it tried to focus at min distance. The min distance on the RF is very very close. It may be the case it appears to take a long time to pull from min distance. In these scenarios you may want the focus limiter.
As for neutrality, I don’t really see the lens lacking character at all. Though to be fair I never thought the ef version had any special character either. Especially once the version iii coatings removed the majority of veiling and ghosting in backlit situations. The only significant difference is the RF version has significantly smoother bokeh.
RedFox88 Forum Pro • Posts: 30,738
That’s probably not the lens fault but which ever camera you used in your dark conditions
Jonathan0007
Jonathan0007 Regular Member • Posts: 163
I never had any issues with the autofocus (though I wasn’t photographing demanding scenarios requiring twitch reactions), but I too wasn’t that impressed with the overall output. It looked somewhat lifeless IMHO (I know many will disagree, but this is how I personally felt) and actually prompted me to return it (I felt like I was spending a lot more time in post than I like). I think I am going to see what the rumored 135mm prime looks like and then see where to go from there.
JE River Regular Member • Posts: 282
I wonder if Canon forced themselves to put a longer throw into the zoom ring because of the telescoping design. The seals and support structure for zooming that large chunk of glass and barrel probably need a lot more torque to zoom than the more traditional single barrel 70-200 lenses. Thus, the zoom ring seems geared to sacrifice throw distance for mechanical advantage.
I would assume, if the new RF 70-200 is up to the same build quality standards needed in other 70-200 lenses, the extending barrel had to be overbuilt like crazy to gain the same strength and coaxial alignment found on the single barrel lenses. Then they likely tossed in some thick and tight dust and moisture seals to keep the lens from gunking up.
It wouldn't surprise me if Canon came out with another 70-200 f2.8 RF lens using a single barrel design if there are enough customers who want ultimate usability and don't care if it doesn't collapse smaller.
Steve W Veteran Member • Posts: 6,998
Maybe they will do that in a small RF 70-200mm f/4L IS. Please
Two things are infinite: the universe and human stupidity; and I’m not sure about the universe! - Words to live by. Albert Einstein
 Steve W's gear list:Steve W's gear list
Fujifilm X-E3 Canon EOS R5 Sony a1 Sony a7 IV Sony a7R V +49 more
shawnphoto Senior Member • Posts: 1,307
BobNL wrote:
Hi everybody,
I think the zoom ring throw is a minor issue. It’s tough to draw other conclusions because the camera it is on is a little outdated already. Overall I really like the lens. I actually prefer the neutral smoothness this lens produces. But, it could be a tad more contrasty. Of course that is easy enough to fix in post. All in all I think it is a great lens.
 shawnphoto's gear list:shawnphoto's gear list
Canon EOS R Canon EOS RP Canon EOS R5 Canon EF 24-105mm F4L IS II USM Canon RF 28-70mm F2L USM +4 more
ZX11
ZX11 Veteran Member • Posts: 6,156
I like the idea of the RF extending zoom design being the next big thing, then the internal zoom design in a few years being the next big thing, then in a few more years an external zoom design being the next big thing, and so on.
Photographers dumping their obsolete zoom design to buy the new cutting edge design,...a real world comedy sketch.
"Very funny, Scotty! Now beam me down my clothes."
"He's dead, Jim! You grab his tri-corder. I'll get his wallet."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
RDM5546
RDM5546 Senior Member • Posts: 3,654
Re: Thanks for your experience review
Thank you for your report. I was wondering if it bothered some users.  I think it would bother me.  I love the exerience with the EF70-200f2.8L,  I bought the original and the mk III version. I think I have shot more pictures with this lens than any other lens.  This is in contrast with the EF100-400L original version with the push-pull zoom action.  I really hated this zoom method from day one of using the lens and it never got any better for me.   I never used as much as I could have.   The newer EF100-400LMK II zoom action is so better.  It now one my favorite lenses.   I use both of these lenses is action sports where the shooting is chaotic.  Zooming speed is vital.    Have the two other RF trilogy lenses but I want to thank you for helping me decide to hold off and maybe use the money on an R5 if the reports of the real camera match the rumors.  Using the adapters with the EOS is not a big deal for me.  I do use this focal length with the EOS R as much as I do my 5D Mk IV due to the better camera handling I experience with that combination.    When carrying two cameras I put the  RF18-35mm on the EOS R body and the EF70-200f2.8 on the 5D.   The EF lenses are great work well with the EOSR but the EROS R with two trilogy RF lenses I have seem to be a little faster focusing, have image stabilization and may focus better in low light.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
hunk
hunk Veteran Member • Posts: 3,409
Hi Bob,
I own both the EF and the RF version. I agree with the throw. But then again, it doesn't bother me at all. In my work (mostly fashion, advertising and company stuff) I can take my time.
About the AF I'm puzzled. On my R (and RP, which focusses the same) the RF seems quicker. Quick ànd very reliable may I add. The AF system in the R is not perfect but in my experience both EF and RF lenses perform reliable. I'm certain the EF isn't better. It will be very interesting to see how the lenses perform on a more proffessional body like tje rumoured R5.
 hunk's gear list:hunk's gear list
Olympus Stylus 725 SW Canon EOS 5D Mark IV Panasonic GH5 Canon EOS R Canon EOS R5 +10 more
CanonshooterRF212 Contributing Member • Posts: 503
BobNL wrote:
Hi everybody,
The throw is what it is.  I can see some sports pros not liking it; I think most people will gladly take it as trade off for the smaller/lighter package.
As far as AF.  What are you comparing it to?  Granted I only had the lens for a two day rental when I played with it, but it was noticeably faster than the EF III with adapter I regularly use.  If you’re experiencing it bring slower than an EF on an R body I’d think something was very wrong.
 CanonshooterRF212's gear list:CanonshooterRF212's gear list
Canon EOS R Canon RF 50mm F1.2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +1 more
Lawn Lends
Lawn Lends Senior Member • Posts: 2,432
The extending barrel is a compromise design. It's like buying a convertible car. It's more complicated and needs to be built to avoid lens creep. I would never take an extending lens into a wet tropical environment -- too many horror stories. I would worry about salt water spray too. That said, it makes the most of your camera bag space and may even allow an additional lens to be carried, or just a smaller bag.
IMHO, the longer the max focal length of a lens, the more useful it is to have an extending barrel. Hence the 100-400 really profits from the design. The 80-200 doesnt profit from the extending design as much, but it must be nice.
 Lawn Lends's gear list:Lawn Lends's gear list
Canon EOS 6D Canon EOS 5D Mark IV Sony a7R III
The new lens really is lighter. And it fits in my bag more easily. How is that a comedy sketch? The new lens is brilliant.
Of course they did.  It was obviously a trade off for the design.  Canonrumors already went over the patent for a non telescoping RF 70-200 f2.8; if the market demands it, it will come.
For the VAST majority of people, even professionals, I think the weight/size savings outweigh the costs of the design; Canon wouldn't of released the lens if they didn't believe this to be true.
rrc1967 Senior Member • Posts: 1,984
actually we did
But yes, as we suggested, it makes sense for Canon to have multiple choices.  Let's face it .. on the EF mount they ultimately had 4 different 70-200's.
ZX11
actually we did
Another advantage of the EOS R and RP.  Four different 70-200's, and the RF 70-200, to select from.  Lots of choices.  There is even a pretty good selection in the 24 (28)-70mm range.  Canon aiming for every budget/quality need?
OP BobNL Veteran Member • Posts: 5,196
You'Re welcome The more I think about it and work on the files the less I like the RF version. I may have had an off day but I don't like the results. It misses something I got with the EF version. I have been shooting this same event for years now (last year with R and EF version) and this year I'm seriously unhappy with the results. Normally this events gives me some of the best pictures of the year. The longer throw on the zoom is one reason I think but the other is the the lack of a certain something. The lens seems to be without character. Its very hard to quantify of course but for me the files seem so dull.
Even though I haven't used the lens, I feel the same way. The new lens just doesn't have the same "bite" (?) as the latest EF versions, even the f4 III. At least based on all the samples I've seen.
I felt the same way about the 70-300L when I decided to keep the 70-200 f4 L IS instead. The 70-300 always seemed like it had a weird haze, or something like an old analogue feel to it. Great lens, but didn't have the same magic of the 70-200 lens, IMO.
Still though, it was clearly the smart move on Canon's part to make a small and light 70-200 for the RF system. Especially when one can toss a new generation 70-200 EF on there with an adapter.
