GX9 or EM5III?
Started Feb 2, 2020 | Discussions
Chris Noble
Chris Noble Veteran Member • Posts: 5,189
Autofocus, IBIS
Steppen wolf wrote:
I've had a GX9 for some time and have recently bought an EM5 MkIII. I'm pretty happy with the GX9 overall - and it's a steal at the current prices. The EM5 is pretty expensive.
However, the PDAF focus of the Oly is way better than the GX9's CDAF. I know DFD has its adherents but it simply doesn't work very well when you try to focus on small moving objects - like birds for example. The Oly is in a different league - it snaps into focus very quickly without problems.
The other thing is the IBIS. The Oly is again way better. The GX9 isn't bad - it's better than my A7RII for example - but again the Oly is in a different league. I never really believed their claims of 5.5 stops stabilisation but I do now. It is pretty amazing what it can do.
The other feature really like is the Pro-capture where it buffers up shots and writes them to the card when you hit the shoot button - great for capturing moving subjects.
But it all depends on what kind of photography you do. I'm pretty well sold on the EM5 despite the "plasticky" feel and high price, If you can afford it I'd go for it. The other factor is what lenses have you got. Some of the nice Oly features don't work with third party lenses. They're both good cameras.
Interesting that DPR hasn't picked up on those alarming Panasonic weaknesses in their testing. They like the IBIS on both, and concerning autofocus, "Fast, accurate" autofocus for the GX9, "unimpressive continuous autofocus and tracking performance" for the EM5III.
 Chris Noble's gear list:Chris Noble's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +3 more
SamKnopf Contributing Member • Posts: 764
GX9 is worse physical design than GX7
nevada5 wrote:
Max5150 wrote:
I've had both. Unless the tilt up viewfinder in the GX9 is mission critical, definitely without hesitation, EM5.3 . I'd also go as far to say that if for some reason you prefer some feature inherent in Panasonic camera's like the menu setup, or the focus system, then I'd pick a different Panasonic camera entirely, like the G90 or wait for the GX9 to be replaced. Although I really like the Panasonic menu and ergonomics in their other camera's, the GX9 was just too cramped for me and I didn't enjoy using it.
The OP says he's had the GX7 since it came out - over 6 years. So I don't think the form is too cramped for him. You didn't mention any other negative, nor did you mention why the EM5.3 would be advantageous, so........
I also have a GX7 that I enjoyed using.  I bought a GX9 and returned it.  There are quite a few physical changes on the GX9 compared to the GX7, and they are all in the wrong direction.  They added an unnecessary dedicated exposure compensation dial, causing everything else to be more cramped, especially the on/off switch.  The built-in flash, weak but occasionally useful, is gone.
The GX7 had a small but comfortable grip.  There was no good reason for eliminating that, but they did.   Why do designers change things for the sake of change, even if they make the product worse?
 SamKnopf's gear list:SamKnopf's gear list
Sony a6500 Sony a7R III Panasonic Lumix DC-GX9 Panasonic Lumix DC-G100 Sony a7C
larsbc Forum Pro • Posts: 18,282
flash
While I agree with you about the exp comp dial and the grip, I think the on/off switch is ok but more importantly, the GX9 does, in fact, have a pop-up flash just like the GX7.
400trix
400trix Senior Member • Posts: 1,125
Re: Autofocus, IBIS
They probably had the AF misconfigured. C-AF and tracking settings seem a bit backwards, as lower sensitivity is what makes the focus sticky. Which doesn’t feel intuitive to me. It might help if it defaulted to sensitivity = -1, but I’ve never owned a camera with C-AF that worked, so there might be a downside that I don’t know about.
Archer in Boulder
God loves the noise just as much as the signal.
 400trix's gear list:400trix's gear list
Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko 300mm F4 IS Pro Olympus 12-45mm F4 Pro +1 more
OP technotic Contributing Member • Posts: 792
Re: GX9 or EM5III?
Thanks for your insights. Right now I'm heavily leaning towards the EM 5 III.
Tech Head
Tech Head Regular Member • Posts: 225
Re: GX9 or EM5III?
technotic wrote:
I've had a GX7 since it came out and 6 small lenses (4 Olympus 2 Panasonic). I was considering selling it all off and moving to a larger sensor camera. I recently visited a camera shop and tried out all the latest offerings and I realized the bigger and heavier gear is not for me.
The one thing I'd really like is IBIS so I can get some smoother video hand held and some cool long exposure shots with no tripod needed. So I'm considering the GX9 and EM5III. I know the GX9 is way cheaper at the moment but I'm looking for a camera that will last me a good number of years so just wondering if the EM5 is going to give me more options such as the live composite, phase detection AF, better IBIS(?). I've never had an Olympus body so not sure if there are things I'll miss from the GX7 (had the GF1 before that).
Anyone else faced this decision? Which way did you go and are you happy with the decision?
I don’t know yet how the E-M5 III focuses in video, but I know that with the most recent firmware on the E-M1 II, the video AF was much improved due to enabling PDAF in video. If that’s something you need and if the E-M5 III can match the E-M1 II, then it’s definitely one you should consider.
Video AF is an Achilles heel of Panasonic cameras.
nevada5
nevada5 Forum Pro • Posts: 15,569
That's very odd
Everyone else who bought a GX9 got a flash built into theirs - yet it was missing from yours.
I'm wondering if maybe the OP shouldn't consider your advice as "expert" with regards to the GX9.
I'll try to be nicer if you'll try to be smarter.
Life is short - drive a convertible.
Re: That's very odd
Sorry, I wrote quickly, and my memory was faulty about the built-in flash.  However, my memory is not faulty about the fact that I bought it, tried to like it, didn't like it, and returned it.
One thing I liked was that it used the same battery as my GX7, so that I could have taken the two on a trip, with the GX7 as a backup.   However, it just didn't convince me that it was a worthwhile upgrade.
929406 Regular Member • Posts: 285
Re: GX9 or EM5III?
I like the GX9 in concept but no mic input is a deal breaker for me, so if your deciding between the two then definitely the EM5.3
 929406's gear list:929406's gear list
Fujifilm X-Pro1 Panasonic Lumix DC-G9 Panasonic S1 Sony a7S III Sony a7C +18 more
tjuster1 Senior Member • Posts: 2,241
Re: Autofocus, IBIS
LOL no bias here!
The guy said he had a GX9 and now has an EM5-iii, so he has experience with both. Why do you dismiss his conclusions? (Oh now I know  . . . look at your gear list)
 tjuster1's gear list:tjuster1's gear list
Panasonic Lumix DMC-GM5 Olympus E-M5 III Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +6 more
LeeHicks Forum Member • Posts: 59
Re: GX9 or EM5III?
I have owned both and prefer the EM5.3 for these reasons:
  • Autofocus
  • weather sealing
  • EVF quality
  • general handling comfort, placement of dials, buttons.
  • battery life
Just my opinion though and based on my usage scenario.
I find the EM5.3 IBIS to be top notch and no real-world difference to me compared to the GX9 + Dual IS lenses. I'm not a professional tester though, so this is just based on using the two cameras to simply take photos.
That being said, I have also broken the tripod mount off the bottom of my EM5.3 and waiting on Olympus to repair. Not really thrilled about that result.
 LeeHicks's gear list:LeeHicks's gear list
Olympus E-PL9 Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 60mm F2.8 Macro Sigma 30mm F1.4 for Micro Four Thirds +2 more
Chris Noble
Re: Autofocus, IBIS
LOL no bias here!
I quoted DPR. Are you saying they are biased? I am biased in favor of professional testing.
Steppen wolf Regular Member • Posts: 122
Re: Autofocus, IBIS
Maybe the IBIS on my GX9 is faulty, but it's certainly a stop or 2 behind the new EM5. It's still pretty good though - but the Em5 is remarkable in my experience. I haven't (yet) managed to find fault with the EM5's focusing, whereas the GX9 is not that good at spot focusing on tricky targets - like moving birds for example.
As for the DPR reviews of the two cameras I'd suggest that DPR is judging the cameras by different standards - because they're plainly in a different price range. It would be nice to see a side-by-side comparison with the two cameras but it would be a bit unfair on the GX9 which is about half the price.
Max5150 Senior Member • Posts: 1,055
Re: GX9 or EM5III?
Circling back here even though I replied earlier in this thread. I had the GX9 for a while and have had the EM5.3 since November.
If you have not used an Olympus camera before, I'd borrow or rent for a weekend and take a few hundred shots to get to know the menu and controls. I have yet to meet a camera menu system I couldn't adapt to, but the Olympus setup is different and might take some getting used to. I'm not saying it's overly complex, just different. Secondly, I'd like to have a bit more of a protruding grip on it. Olympus obviously wanted to keep the camera svelt without losing usability, but I'd personally like a bit more grip. The need for a grip on my GX9 was even more pronounced as far as I'm concerned. I found a decent one on ebay that was on the camera all the time.
Other than that, from a performance standpoint, you'll need to get any camera dialed in to your preferences, but once I achieved that, I find the EM5.3 a fantastic compact camera. With a small prime lens, a small uwa zoom, or a small wide/short tele zoom it's a really nice piece of kit. I think it's a camera I will be happy with for a while - at least through a couple model generations
