CANON G5X and 3rd party batteries
Started Feb 1, 2020 | Discussions
Cyberphobia New Member • Posts: 19
Just bought a second hand G5X with a WASABI battery and some of the features do not work!
Touch screen, Q and touch shutter, plus every time I take out the nearly end of life battery to charge it the day date time go back to 00.
Other features seem to be not right either. Would these symptoms be due to the WASABI battery?
I would buy a CANON proper if I was told yes its the battery or send it back to ebay.
Cyberphobia
Canon PowerShot G5 X
Chaplain Mark
Chaplain Mark Veteran Member • Posts: 6,539
It's the Camera....
The camera issues you described are not battery related, they are problems in the camera itself.
You could try doing a factory reset, if you haven't already done so.  Failing that, it's time for a return or repair.
Hope this helps...!!
Thank You,
Chaplain Mark
'Tis better to have a camera and not need one than to need a camera and not have one.
In pursuit of photographic excellence.
 Chaplain Mark's gear list:Chaplain Mark's gear list
Canon G3 X Canon PowerShot G5 X Sony a7R III Sony a7C Sony FE 135mm F1.8 GM +3 more
OP Cyberphobia New Member • Posts: 19
Re: It's the Camera....
My thoughts exactly I have started a return to the seller.
Thanks for the reply
Cyberphobia
Chaplain Mark
Cyberphobia
You are most welcome.
I hope you end up with a good copy of the G5X,  it is an excellent camera...!!!
Thank You,
Chaplain Mark
(unknown member) Senior Member • Posts: 1,455
Cyberphobia
Canon did say that they were going to continue making it.
At the moment the little DC -1850 leather half case/jacket is going for £10 against £39.99 on the canon site and it does give a bit of protection and a larger grip. There is a battery flap so a nice little treat for the camera.
Recieved full refund from eBay not the seller they never got back to me but I found a minty Nikon F100 to go with my minty Nikon D700 and will use my wife's horrible Canon elph as a pocket digital.📸
Thank you
Cyberphobia
Peter in Canberra Senior Member • Posts: 1,346
Re: CANON G5X and date/time
resurrecting an old thread ...
I also bought a used G5x - everything seems to work fine except it keeps asking me to enter the date & time as if from scratch.
Happens mostly if battery is removed but also, I think, sometimes when memory card is removed or left off for a fair while.
Anyone know a fix for this?
thanks
Peter
