Startup noise on K1. Normal???
Started Feb 1, 2020 | Questions
Phil_Rose
Phil_Rose Senior Member • Posts: 1,044
I have no idea why it took all my edits away. Let me try that again,
I have just bought a K1ii (upgraded) and it makes this 'curr' noise on startup. Not loud but audible. I'm embedding a video. Is this normal? I hope you can hear it over the perpetual rain!
Thanks for any reassurance you can offer!
I like turtles.
www.philrosephoto.com
Pentax K-1 Pentax K-1 II
MightyMike Forum Pro • Posts: 41,691
Re: Startup noise on K1. Normal???
Mine seems to make the same sound
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/user/SpeEedy/profile/photos?sortBy=photoFavoriteCount
mxx
mxx Senior Member • Posts: 1,250
So both of yours are broken?
 mxx's gear list:mxx's gear list
Sigma DP3 Merrill Canon PowerShot SX50 HS Sony Cyber-shot DSC-V1 Pentax K-5 Pentax K100D +11 more
PDL Regular Member • Posts: 457
My K-3II makes the same noise on startup. I do have the dust removal shake on startup selected.
PDL
ozdean
ozdean Forum Pro • Posts: 28,665
Yes dust removal is on.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 70mm F2.4 AL Limited +14 more
Its not dust removal!!!
I turned my dust removal off in the menu just to check and I still get the sound
Mike from Canada
Pentax645 Contributing Member • Posts: 968
Same noise here on start up. Dodd's Camera, where I made the purchase, said it's the  stabilization mechanism centering the sensor. No way I can dispute or confirm this, but he's the only Pentax guy I've ever encountered in a retail store FWIW.
My camera is set for dust removal on startup and shutdown......no noise on SD.
I was immediately concerned when this first happened, but 5,300 shots later all seems well.....except that noise??? The image stabilization subjectively works fine as well.
It would be good to get a definitive answer on this. Do some K1s not do this?
Larry
 Pentax645's gear list:Pentax645's gear list
Pentax K-1 Pentax K10D HD Pentax DA 55-300mm F4.0-5.8 ED WR HD Pentax DA 15mm F4 ED AL Limited Pentax smc D-FA 100mm F2.8 macro +6 more
Alex Sarbu Forum Pro • Posts: 13,257
Re: Its not dust removal!!!
Indeed, it's not the dust removal (which is ultrasonic on this camera - and the SR-based one makes a completely different noise).
Yes, there is a "start-up noise".
Alex
"When you tear out a man's tongue, you are not proving him a liar, you're only telling the world that you fear what he might say." - George R.R. Martin, A Clash of Kings
 Alex Sarbu's gear list:Alex Sarbu's gear list
Ricoh GR III Pentax K-5 IIs Pentax K-1 II Pentax smc DA 35mm F2.8 Macro Limited Pentax smc DA 21mm F3.2 AL Limited +9 more
James O'Neill Veteran Member • Posts: 6,117
That's what I have always understood too. It could be a myth, but SR is never actually "OFF" if you're working without it , it is 'Inactive' , and there is some transition from however the sensor is parked when powered down to its working position.
 James O'Neill's gear list:James O'Neill's gear list
Pentax K-1 Pentax K-5 IIs Pentax smc FA 77mm 1.8 Limited Pentax smc FA 43mm F1.9 Limited Pentax smc DA 18-250mm F3.5-6.3 +3 more
Massao Senior Member • Posts: 2,580
Hmmm...but it doesn't occur on APS-C cameras? At least not on kx, kr, k7, k5, k5ii  k30, and ks2.
I hear similar sounds on all my Sony SLT cameras. Never bothered to check what and why. The cause could be similar. Sony has IBIS too.
Kind regards,
Massao
First camera: Canon FTB; First autofocus SLR camera: Pentax; First Nikon: F601 (N6006); First digital camera: Sony DSC-W5; First DSLR: Nikon D70; First mirrorless ICL camera: Samsung nx11
 Massao's gear list:Massao's gear list
Samsung NX500 Sony Alpha NEX-3 A3000 Sony SLT-A68 Samsung NX1100 +40 more
bilybianca Contributing Member • Posts: 699
Just checked the K-1 and the K-5, both make a little sound at startup, but the K-5 noise is a bit "softer". I buy the explanation that it is the sensor moving from "asleep" to "active and ready" position. If I shake my K-5 (gently!) when it's off power I can clearly hear the sensor ratteling inside. In the K-1 it's not that obvious, but I think it's there too. And both cameras work just as they should. Conclusion: not to worry!
Kjell
 bilybianca's gear list:bilybianca's gear list
Pentax *ist DS Pentax K-5 Pentax K-1 Pentax smc DA 14mm F2.8 ED (IF) Pentax smc DA 16-45mm F4 ED AL +24 more
aueda New Member • Posts: 1
I like turtles.
It is the sound of aperture motor.
Remove the lens and turn on the camera so you can see the aperture lever moving.
My K-1 and K-5 make same noise but K-50  does not. I think expensive aperture motor (of K-1, K-5 etc) make the noise and cheap aperture motor (of K-30, K-50, etc.) don't make the noise.
 aueda's gear list:aueda's gear list
Sony RX100 II Olympus C-5050 Zoom Nikon D800 Pentax K-1 II Pentax K-5 +4 more
@Massao
Didn't you read my message? It does occur on APS-C cameras - specifically the K-3II.
PDL
lela_jr Regular Member • Posts: 294
Got the same start-up sound on K1 an K-3.
www.izudinlelic.com
 lela_jr's gear list:lela_jr's gear list
Pentax K-01 Pentax K20D Pentax K-3 Pentax K-1 II Pentax smc DA 35mm F2.8 Macro Limited +29 more
LoneTree1
LoneTree1 Senior Member • Posts: 2,801
Good thing comments are turned-off.
https://www.youtube.com/watch?v=O_QmCzeIky0
miles green
miles green Veteran Member • Posts: 7,827
i agree, mine does it too.
Miles Green
Pentaxian since 1997!
Corfu, Greece
N.B. All my images are protected by Copyright
 miles green's gear list:miles green's gear list
Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +7 more
Phil_Rose
OP Phil_Rose Senior Member • Posts: 1,044
Thanks all. I think I am reassured. It seems to be normal.
Phil
I like turtles.
Polacofede Senior Member • Posts: 1,409
My K1 and K3II does the same sound since day 0. I have never worried about it.
Sometimes i also hear a tiny noise to be similar to a capacitor loading.
 Polacofede's gear list:Polacofede's gear list
Olympus XZ-2 iHS Panasonic Lumix DMC-FZ200 Pentax K-50 Pentax K-3 II HD Pentax DA 55-300mm F4.0-5.8 ED WR +6 more
