video playback cannon sl2
Started Jan 31, 2020 | Questions
jp202 New Member • Posts: 1
I am new to digital photography and used my sl2 to video an event., approximately 30 minuets. I can view the playback on the camera and I downloaded it to my pc. However I connected the camera via mini usb to the usb port on my tv. It identifies the camera but shows no files? Any suggestions?
thanks
Canon EOS Rebel SL2 (EOS 200D / Kiss X9)
jvc1 Senior Member • Posts: 2,202
Re: video playback cannon sl2
thanks
After you connect the cables, did you turn on the cameras power then press the play button?
I keep some of my favorite pictures here,
https://www.flickr.com/photos/129958940@N03/
 jvc1's gear list:jvc1's gear list
Canon EOS Rebel SL2 Canon EOS 90D Canon EF 85mm F1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 60mm f/2.8 Macro USM +10 more
Murrango Forum Member • Posts: 92
thanks
It's possible that your TV doesn't recognize the file format, or the codec that your camera uses to record video. Try copying the files from your PC to a flash drive, plug that into your TV, and see if the TV recognizes the files then.
The easiest way to play your videos on your TV, is to connect the camera using the HDMI port. That's why it's there.
 Murrango's gear list:Murrango's gear list
Canon PowerShot SX50 HS Canon EOS 1000D Canon EOS 500D Canon EOS M Canon EOS M5 +12 more
Jack Jian Regular Member • Posts: 309
thanks
The Camera does not behave like a direct storage device unlike Pen Drive, Card Reader etc. Therefore, your TV will not be able to access the files directly.
