Canon M10 Grip Options
Started Jan 30, 2020 | Questions
SmartUK New Member • Posts: 5
Hi. I’m an EOS M10 owner who’d like to add grip but finds the Canon GR-E3 expensive for what it offers and has a face jacket but which obscures access to both the battery/SD card slot and the tripod mount.
There seems to be only one aftermarket grip option for the M10 from Fotodiox. I’ve seen others for the M1 and other M models but nothing for the M10.
Can anyone help? I’ve seen some 3D-printed ones that use adhesive pads but that would make me nervous!
Thanks!
Canon EOS M10 Leica M10
Steve Siegel
Steve Siegel Regular Member • Posts: 400
Re: Canon M10 Grip Options
I added this to the wife's M100.  Makes it a good bit easier to grip.
Flipbac
 Steve Siegel's gear list:Steve Siegel's gear list
Canon PowerShot G1 Canon G1 X II Canon EOS M6 Canon EOS M50 Canon EOS RP +14 more
OP SmartUK New Member • Posts: 5
Thanks, Steve. People seem to like it and it being held on with a sticky pad doesn’t seem to be outing them off.
Sittatunga Veteran Member • Posts: 5,406
Works well on mine, been on for a couple of years so far.  The official Sony grip for the RX100 series is also held on with double sided sticky tape.
jkcz Regular Member • Posts: 168
Thanks!
I use a 3D printed grip stuck on with 3M 2 way tape...no complaints and this stuff isn't gummy so it should come off nicely if I ever decide to remove it.
 jkcz's gear list:jkcz's gear list
Canon EOS M100 Canon EOS M6 II Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +2 more
Hi again. I have now got a metal grip from China - I’d seen one attached to an M100, even though it was described as only fitting the M (M1). I took a punt and it’s fine; fractionally too big on the grip side but only by a couple of mm which I’ve filled with a cut-down self-adhesive sponge pad from an SSD, just to help keep it in place. Any concerns I had about “not suitable for other models” warnings seem to be unfounded
Thanks for everyone’s input. Have a look here: https://www.instagram.com/p/B9ZTjAyHJzO/?igshid=ypgk2pr4qoix
