RF 70-200 or EF 70-200 with Converter for EOS R
Started Jan 30, 2020 | Questions
Suave Senior Member • Posts: 2,289
Re: That tried and true "air pump" design
pokesfan wrote:
Ah, yes, the 17-55. Truly one of the worst lenses in Canon’s history for build quality and dust. That is a *great* comparison to a 2019 $2700 L lens with extensive sealing and filters. You must be a scientist.
I've taken apart (and yes, put back together) a fair number of Canon lenses, including the 17-55.  Its build quality is perfectly fine.
 Suave's gear list:Suave's gear list
Nikon D7000 Canon EOS 5D Mark III Canon EOS RP Canon EF 85mm F1.8 USM Canon EF 24-70mm f/2.8L USM +7 more
ZX11
ZX11 Veteran Member • Posts: 6,156
ThePointblank wrote:
ZX11 wrote:
RDKirk wrote:
ZX11 wrote:
I don't like the air pump design of the new RF 70-200 and its far higher price for the same image quality. To me, the EF 70-200 on the EOS R is a better choice. To each their own.
Interestingly, nobody seems to be reporting problems with the "air pump" design for the 24-70 or the 24-105...and it hasn't been a problem for decades. It appears to be a design Canon perfected a long time ago.
After reading Roger Cicala's disassembly report on the RF 70-200, I have no reason to doubt its solid mechanical prowess.
https://www.lensrentals.com/blog/2019/12/the-not-very-long-awaited-teardown-of-the-canon-rf-70-200mm-f2-8-is/
I have seen the video on youtube.
Hasn't been a problem for decades? The EF-S 17-55 f/2.8 does have a problem with dust getting in it due to the huge volume of air it pumps in and out as it zooms. It is not a decades old design. Similar dust with the EF 24-105.
No other air pump lenses get dust in them? Seems there are plenty of youtube videos about getting dust back out of Canon's air pumps.
I do not have to like the RF's air pump design just because it is the newest greatest hip thing. I do not think Canon was mistaken when they designed the all internal design on the EF 70-200 f2.8 and the EF 70-200 f/4.
I don't like fiddling with the lock on the RF 24-105 that is necessary for its air pump design. Do I have to like it too? I don't like the extra rotation range the RF 70-200's zoom ring has. The extra rotation needed to move the RF 70-200's large front element, entire barrel, hood, and the kitchen sink, forward and back.
I like the non-pumping, non-moving inner barrel, and thinner design of the EF 70-200. The EF is solid, sealed, and proven reliable. My choice. To each their own.
Read what Roger Cicala says in the comments:
OK, I'm not commenting on 'will it resolve' because I'll go on a 20 minute rant. Of course it will resolve.
Biggest dusters: 85 f1.2, 105mm f1.4s, 70-200 f/2.8s, 150-600s are fast horses. The biggest variable to 'how dusty is it' is probably 'how much do the front and rear elements magnify it'.
To be fair, in olden times some extending barrel zooms (Canon 100-400 old version, Sigma Bigma) were the dustiest. Like so many things, progress was made. I believe that progress is more like "we know the front element is going to magnify, we know there is air flow, let's design the air flow so it doesn't pool under the front element", but I don't know for sure.
Here's what I know for sure:
Every lens has air flowing through it, there are no air-tight lenses.
Air has dust in it.
Dust in air likes to settle on solid objects.
That glass stuff in your lens makes things look bigger, smaller, sharply in focus and sharply out of focus. Including what's inside the lens.
When you take a lens apart to clean out dust it's interesting how the horrid dust you saw on the second element almost disappears when you take the first element off.
When you take apart a lens to not clean out dust it's interesting how dusty the inside might be even though you didn't really see it.
There is generally less dust (not no dust) in lenses that we just opened new in box, too.
I sum this up in Roger's Rule #63: If you don't see dust in your lens, you don't have a bright enough light.
Per what he sees, the current crop of non-pumping 70-200 f/2.8's are already gathering a lot of dust inside. He also listed a a couple of large prime lenses (which don't zoom at all) and the 150-600's as among the worst.
All lenses will get dust inside. The issue is how much the front and rear elements in a lens magnify the dust.
You appear to say but don't say, the EF 70-200 pumps as much air through it, air with dust, as the RF 70-200. I don't think that is true. I don't want an air pump if given a choice.
I don't see dust in my EF 70-200 and still think it is a solid, sealed, and proven lens. Regardless of R forum attempt to say it isn't the lens it was before the RF was introduced. The EF isn't air tight and water proof but it doesn't exactly flow air through it. The new RF is an air pump, abet an air pump with air filters. It flows air through it like nobody's business.
My comment was to the replier who said "no one" was reporting problems with the air pump design. When you see a video on cleaning dust out of a lens, it invariably is an extending zoom design.
People like the compact collapsing design of the new lens. Good for them. I don't need that and am happier with the solid EF version.
You are moving lens elements inside a lens. Don't think for a second that there isn't air movement in and out of the lens.
And Roger Cicala has far more experience tearing apart lenses than either one of us, and has seen the 70-200's from all vendors. He's saying that once you tear apart the lenses for cleaning, the worst offenders for dust accumulation are the current crop of non-pumping 70-200's, and a number of large primes. While some pump-design lenses do make it on his list of worst offenders (namely the old 100-400 and the 150-600's), his opinion is that they have gotten a lot better over the years with better lens designs.
It is his belief based upon experience cleaning thousands of lenses that the biggest issue is how much does the front and rear elements magnify the dust. You can have an incredibly dusty lens on the inside, but don't notice it until you tear the lens apart for a cleaning, or you can have a lens with noticeable dust spots, which disappear when the front and rear elements are removed for cleaning.
Interesting that he finds internal designs pumping more air in and out.  Or, enough air that they get dustier than extending barrel designs.  I thought they would just pump air around inside them, from front to back, with very little external air movement.  The extending lens designs double their internal volume and then half their volume with each zoom change.
I think there must be more to Cicala's story than what he is telling us.  Those EF 70-200's used in dustier conditions, for longer, because they are sealed?  Used in harsher conditions than the new RF 70-200 he tore down?  I will stick with reviews of internal lens designs without moving front elements and what they say are its advantages than go this one guy.
Or, do we need to go comment on the plethora of old videos about the EF 70-200's and correct their comments on the internal design.  Correct them due to this one guy, Cicala's video.  I'm pretty sure I can find a video about the earth being flat or the sun rising in the west so I watch lots of reviews on the lenses before I decide.
"Very funny, Scotty! Now beam me down my clothes."
"He's dead, Jim! You grab his tri-corder. I'll get his wallet."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
ZX11
If you've done videos on 17-55 cleaning, then I have likely seen them.  I looked at getting that lens for years but never bought it.  Cleaning it and taking off the front element seemed like just something it would need occasionally from the owner.  I could do that.
The lens was known as L level glass but not having L lens build quality in its weather sealing or metal construction.  Which made it more affordable for its target customers, IMO.  Matched the lack of weather sealing on the Rebel cameras the lens was built for.
The lens cleaning looked fun and I wouldn't have an issue removing the front or rear element of the RF 70-200 for cleaning.  But why would I when the EF version is available and proven to be well sealed against dusty environments.
No video.  It was actually a lens that someone forgot outdoors.  It got wet and accumulated all sorts of dirt inside, but somehow the electronics survived.  Had to be disassebled completely.
Re: cleaning behind the front group.  I strongly believe that the only time it should be done is before the lens is sold.
Hoka Hey
Hoka Hey Senior Member • Posts: 2,991
Re: RF 70-200 or EF 70-200 with Converter for EOS R
One thing that has not been mentioned is that if you have any interest in the EOS M bodies, get the EF so that you can use it on both systems. M6ii is a fun little camera and adapts to the EF lenses quite nicely and focuses really quickly with the EF lenses. I feel like the M6ii focuses faster than the R or 5D4 with the EF 70-200L 2.8 ii but have not done any actual testing to verify the feeling and this feeling comes from before any firmware upgrades were made to the R.
Joe
ThePointblank Regular Member • Posts: 119
Air has dust in it.
Considering Roger is the head of LensRentals.com, has in his inventory thousands of lenses and cameras from all sorts of manufacturers, and is capable of doing repairs and maintenance in house, he should know bad lens designs.
Go back and read his article and read the comments; he's very clear that he doesn't think the pump design is going to be an issue. Canon's build quality is excellent here, and clearly, Canon also doesn't think dust accumulation is an issue.
 ThePointblank's gear list:ThePointblank's gear list
Canon EOS R Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 100-400mm F4.5-5.6L IS II Canon EF 50mm F1.8 STM +1 more
R5D4
R5D4 Contributing Member • Posts: 968
Ad Hominem because your argument is unsupportable? Is that why you need it? Any more insults in your playbook for those you disagree with. Did you write the law that said photographers have to like the lens designs you like?
I have seen the reviews stating the advantages of non extending front barrels. I will stick with those advantages. The long term reliability of the new RF is speculative based on that guy's tear down, but not proven, while the EF is well proven. Unless you have owned your RF 70-200 for years longer than I suspect.
I assume you missed the argument from the previous poster that in the last several decades of lens design, no extending lens has had a dust problem. That it is a problem of the distant past. I disagree that it is a problem restricted to the the past and provided an example to support my view. The video I was watching also had a 24-105. Also the worst lens in history?
Sorry that my dislike of air pump designs, supported by examples, fills you with uncontrolled rage, Mr Scientist. Ignored.
You're awfully sensitive for a keyboard warrior in a camera forum. Just take a chill time out, nobody is insulting your dislike for dust nor your strong stance on an imagined problem with the lens.
I was merely pointing out that you have pulled probably the worst example for comparison with the 17-55, a lens that is notorious for dust and rattles and generally poor build quality. There is not a seal anywhere on it, and plastic parts abound. Sorry you were insulted by being called a scientist. I assure you it was not an ad homonym attack, but rather a sarcastic reference to your poor choice of comparison. If I wanted to attack somebody I would not call them a scientist.
Seriously, nobody cares what lens you buy. But you sure look like a silly goose dying on the "oh no I see a speck of dust in my lens" hill.
 R5D4's gear list:R5D4's gear list
Canon EOS R5 Fujifilm X-T3 Canon EOS R6 Canon EF 35mm F1.4L II USM Fujifilm XF 35mm F2 R WR +9 more
Colin46 Senior Member • Posts: 1,700
Terry Straehley wrote:
I recently bought an EOS R with the EF converter for my EF lenses. I have used the EF Converter with my EF100-400 and an EF 1.4 converter. With the EOS R this combo will focus, whereas it would not focus with my EOS 7D. The EOS R will focus down to at least f/8 (equivalent) whereas the older cameras will only focus to f/5.6. My advice is if you are going to have all R cameras, buy native RF lenses. I have a full selection of EF lenses from my past cameras and that is why I have the converter.
The r will actually auto focus down to f11 (f5.6 lens with a 2x tc) and that’s with all points, even the best dslr’s will only do f8 and that’s usually only with a few central af points.
 Colin46's gear list:Colin46's gear list
Nikon Z9 Canon TS-E 24mm f/3.5L II Nikkor AF-S 300mm f/4E PF ED VR Nikon AF-S Nikkor 500mm F4E FL ED VR Nikon 24-70mm F2.8E ED VR +6 more
lawny13 Veteran Member • Posts: 3,132
Air has dust in it.
I think you are going through logic because of your initial assumption that if the lens telescopes it must pump dust in and out of it and it is therefore worse than non telescoping glass.
Perhaps the initial question should be... do lenses get dust in them? There answer there is yes. Primes, zooms, both get dust in them over time. The following question should be how do telescoping lenses compare with their internal dust acquisition over time with the other lenses.
So though I am certain that telescoping lenses do end up with dust with them over time, it seems that if you look at the real world reports from places such as lens rentals, is that ALL lenses get dust in them over time. I have had dust in zooms and primes. And I have not noticed any significant difference between them nor any impact on the resulting images.
So you find people on youtube finding dust in their telescoping lens. Big woop. If I search on youtube "internal dust prime lens" I find vids on that as well, and instructions for opening up and cleaning that dust. So what does that tell us??
So if at lensrentals they state that in their experience they find more dust in primes than zooms, should I right off primes? Nope. dust is a fact of life.
dodgenburncdn New Member • Posts: 2
I have the EF 70-200 and a 1.4X extender that I use on my EOS R frequently (with & without extender) with very good image results. It is a beast however. On top of the lengthy and heavy lens, 50mm is added with the 1.4X and R mount adapter wi. control ring. This makes for a very cumbersome assembly to use and carry. I have planned a couple of European vacations this summer and fall (COVID 19 permitting) and the size of this lens with add-ons will necessitate leaving it at home. For that reason I am seriously considering the RF 70-200 despite its cost. Would be even more appealing if extenders were available for it. Nevertheless to your concern, the EF 70-200 with extender will pair up quite nicely with your EOS R.
rbarta Regular Member • Posts: 285
Air has dust in it.
I just wanted to add my personal experience to this discussion for those trying to make a decision on "air pump" lenses in general. I have gone on several north African safari's and trips to the Galapagos and other harsh environments with a 70-200mm f2.8 IS lens. I've had this lens cleaned only once (before I sold it to get the 70-200mm f2.8 IS II). If you've ever been on an African safari you know how dusty it is, range rover stops, lots of dust is kicked in the air, but in many cases you have to get out your camera and start shooting before dust settles because the animal may leave. While you are shooting animals that are less shy, other Range Rovers drive up and the cloud of dust washes over you and your camera. If you are a pro doing this full time I'd imagine you would have to clean this lens once a year (maybe more). Safari helpful hint : always cover your camera with something when not in use like when you are driving between locations.
My wife took a 100-400 on a 2 week safari (yes just 1) and the internals had to be cleaned.  This lens was sold as we plan to take many more similar trips.
If you are not going to extreme environments (which is most people) then I'd imagine that the RF 70-200 or RF 100-500 would be no problem at all. And an internal cleaning after a once in a lifetime trip is no big deal.
 rbarta's gear list:rbarta's gear list
Canon EOS-1D X Canon EOS 5D Mark III Canon EF 15mm f/2.8 Fisheye Canon EF 50mm f/1.2L USM Canon EF 16-35mm F2.8L II USM +7 more
Nimonus Contributing Member • Posts: 556
The front and rear glass of a lens are the weakest link.
For dust-proof,
  1. Best: zoom and focus are all internal. There have no breath-in or out.
  2. Worst: zoom and focus are all external. There have many breathe in and out.
  3. Moderate: either external zoom, or external focus.
Any breathing will bring in the dust, whatever the filtering system using, it's just when.
ProDude Senior Member • Posts: 4,851
The new filtration systems that Canon has in place in the new RF100-500 and RF70-200 allow for one to be in less then ideal environments and NOT suffer intrusion of dust and elements. I wouldn't hesitate to stick with the newer RF designs both physically AND optically.
Name the gear and I've probably owned it and used it.
