Galaxy Note 10.1
Started Jan 29, 2020 | Questions
charles janga Regular Member • Posts: 185
Galaxy Note 10.1
Hi Guys.
I do want to know if possible to help me with this question,as I mention above I own a Samsung galaxy note 10.1,I want to buy a portable charger for it,is it possible?and what for cable do i have to use for it?
Thanks in advance.
charles
charles janga
I2K4
I2K4 Senior Member • Posts: 1,441
Re: Galaxy Note 10.1
I'd suggest any good brand charger (e.g. Anker) depending in the size you need, but be sure it takes a USB 2.0 "A" type connector.
Appears you have an oldie tablet that uses a proprietary Samsung cable - double check the ECC number but this seems to be the same as for your Note 10.1:
https://amzn.to/2uFSGTg
If you already have a good cable that connects the tablet to the wall charger, that will work fine with the USB 2.0 charger port, so you may not have to buy another cable.
