Dummy battery for LP-E17 (T7i) for shooting video?
Started Jan 28, 2020 | Discussions
jlustig Junior Member • Posts: 36
I want to shoot videos using my T7i and I'm concerned about the battery giving out. I've looked at some options for a dummy battery which would replace the LP-E17 battery with a cord out the back that could plug into a USB power pack. But all of the options look like cheaply manufactured things that will break the camera... it's hard to tell what will actually be compatible. Any suggestions for a good product that will allow me to do this?
 jlustig's gear list:jlustig's gear list
Canon PowerShot S95 Canon EOS Rebel T7i
Canon EOS Rebel T7i / EOS 800D / Kiss X9i
Kirk Sachs Junior Member • Posts: 32
Re: Dummy battery for LP-E17 (T7i) for shooting video?
I needed something similar for astrophotography. I bought one of these
https://www.amazon.com/dp/B074K181L8/ref=dp_cerb_1
It's not USB, but you just need an 8 volt input. I ended up using one of my 18v drill batteries with a buck converter set to 8.4 volts and it works perfectly.
Looking at Amazon, it looks like there are some available that are USB. If you go that route o would get one of the ones that have two USB plugs, as the power from just one when stepped up to 8.4v might not be quite enough.
