Which hub for lightning port on iPad?
Started Jan 27, 2020 | Discussions
darinb Contributing Member • Posts: 895
Any suggestions for which hun I need for my iPad Pro (the older one with the lightning port)?
I want it to:
1) Not require external power (other than any from the iPad itself--nothing else plugged in)
2) Allow me to plug in a Samsung T5 drive
3) Have an SD card reader built in
I have this a try earlier but both the hubs I tried required external power once the SSD was plugged in.
Happy to buy any dongle needed, etc.
Darin
Darin Boville
My photo site: http://www.darinboville.com
Instagram: http://www.instagram.com/darinboville
 darinb's gear list:darinb's gear list
Apple iPhone 12 Pro Max
brousseb
brousseb Regular Member • Posts: 193
Re: Which hub for lightning port on iPad?
You won't find what  you're looking for, everything will need external power (except for the apple SD card reader).  In addition to the hub, you will also probably need the apple USB 3.0 camera connection kit (dongle) that will accept a USB input along with a lightning power input.
With this setup (camera connection kit + hub) you should be able to pretty much connect anything.
Just a note, some hub's won't work with lightning/apple.  I use a Kingston Nucleum and it works, other people have tested different hubs that don't work.
 brousseb's gear list:brousseb's gear list
Panasonic ZS100 Panasonic LX10
brousseb
Here is a picture:
You could also attach the T5 directly to the apple camera connection kit, or a USB card reader directly without having the hub.
In this scenario, the hub is required for the HDD.
Boomanbb
Boomanbb Veteran Member • Posts: 3,186
You would need to upgrade to a model with usb-c to power devices from the iPad.
Ben Boozer
Disagree without being disagreeable
 Boomanbb's gear list:Boomanbb's gear list
Canon EOS 7D Canon EOS 7D Mark II Canon EOS M3 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 70-200mm f/2.8L USM +12 more
TheClueless
TheClueless Senior Member • Posts: 2,140
brousseb wrote:
Here is a picture:
#toorealdonglelife
 TheClueless's gear list:TheClueless's gear list
Leica Q2 Leica M10 Nikon D850 Panasonic Lumix DC-G9 Sony a7R IV +80 more
OP darinb Contributing Member • Posts: 895
brousseb wrote:
Here is a picture:
O.K, so the ideal solution here would be to have a newer iPad that uses USB-C an dthsu does not require a power source--is that right?
But still sort of dongle-crzy. It seem like all of those things could be combined into one unit--an SSD, a built-in SD card reader, and a USB-C port. Wouldn't need the hub anymore. I guess they exist--I googled and see one from WD. Anyone try one of those?
Darin
Darin Boville
I'm not seeing a lightning version of the Kingston Nucleum hub--is that what you are using? Do they still make it? As I say in the other post, I think the right solution is to upgrade the iPad at some point but I'd like to try out the workflow for a bit to see how it goes, even if that means being tethered to a power source. (And, by the way, any idea if one of those portable batteries would work as a power source? Seems like they would....)
Darin
Darin Boville
brousseb
There is also a usb-c to usb adapter in there, so I can plug it into the Apple Camera Dongle (the white one).
A usb-c iPad would resolve most of these issues.
