Canon and sticky rubber coatings
Started Jan 25, 2020 | Discussions
MarkAM
MarkAM Regular Member • Posts: 231
I have a 20D bought 2005, only taken 700 shots, kept in pristine circumstances (inside camera case in cool room). Looks like new. Dials and focus rings now sticky as thermoplastic coatings starting to degrade.
Same thing happened to my expensive Canon 18x50 binoculars, bought in 2009 for over $1300. Sticky degrading rubber everywhere.
I do not use skin lotions, insect repellents or any of the other things people blame. It's actually a manufacturing fault in which the rubber (thermoplastic) is not properly cured by heat when applied. I know this because it also happened to a stabilizer on my archery bow several years ago. This is a part attached to a bow that is never touched. It just started "melting", very sticky to the touch. The part manufacturer confirmed that it was a bad batch where the rubber was not adequately "cooked" and replaced it free of charge.
I asked Canon to assist and was told they would not help in any way. I did a Google search for the problem and found many people had experienced it, one or two had it repaired free by Canon but as time went on Canon started refusing to repair it, or wanted a hefty fee. I suppose it was too time consuming and too many people were having problems.
I have camera and binocular equipment dating back to 1933 that is in perfect condition, yet these new cameras and binos are shot just a few years after manufacture! It's shocking.
The generally agreed DIY remedy is to slop isopropanol (isopropyl alcohol) on the coating until it comes off. Of course all the markings on the dials will come off too, making the dial useless. You'll also potentially harm adjacent plastic surfaces with the chemical.
More recently, I've noticed some of the thermoplastic "soft-touch" surfaces in my VW Golf have started to become sticky too. Go to YouTube and search for "sticky dashboard" to see all the people who have had this happen to them in multiple brands of cars, for example:
Going forward, I'd like to see all reviews at DPReview mention the finishes on cameras, so that we know which units to avoid. My next camera needs to have HARD PLASTIC or METAL finishes, or I won't buy it.
Love to hear what others think about this.
Canon EOS 20D
gium Senior Member • Posts: 1,653
Re: Canon and sticky rubber coatings
It's the nature of rubber and it happens with everything, not just camera equipment. Can't do much about it.
I have had it happen to my old EOS 300D. I just scraped the sticky rubber off the grip. My EF 15mm fisheye had the focus ring that became sticky. The focus ring was replaced at a local photography repair center for 50 euros, it took them 15 minutes. They told me replacing or cleaning focus or zoom rings for lenses are relatively easy, since 99 out of 100 times they don't have to "mess with the optics" of the lens.
I can buy new Canon rubbers and focus- and zoom rings at some national webshops or at ebay or aliexpress. For example a new rubber grip for my 300D costs less than 10 euros at ebay and I could install that myself.
I would rather have the rubber grip, have it degrade after 10 years and then fix it for 50 euros or less, then have a slippery piece of equipment for those 10 years.
 gium's gear list:gium's gear list
Canon EOS M5 Canon EOS RP Canon EOS R5 Canon EF 85mm F1.2L II USM Canon EF 24-85mm f/3.5-4.5 USM +9 more
BlueRay2 Forum Pro • Posts: 14,816
that is called "entropy" in action look at the Egyptian Pyramids, while still standing and crumbling, they are not near in the same condition as they were in their 1st Millennium! but i do agree with you, canon and the rest of the industry should make an effort to come up with something better to construct their camera bodies with, no excuses considering today's technological advancement in synthetic material durability! i'd expect the camera bodies to last at least 30 years. as for industry using better synthetic composites for their camera bodies, i wouldn't hold my breath, unless, there is a huge consumers' complain!
We are ephemeral dreamers, like surfers on evanescent waves!!!
hotdog321
hotdog321 Forum Pro • Posts: 21,151
I've had this happen, too, especially on the rubber of an old lens. I suspect ozone might be part of the problem, but that is just an opinion. I also had the leather case for a 300 f/2.8 eventually fall apart and the leather(ish) lens hood cover turn into a sticky mess after many years.
I know you said you don't use chemicals, which is good. I actually embedded a fingerprint into the shutter release of a T-90 film camera because I had a bit of "Cutters" residue on my hands.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
MarkAM
OP MarkAM Regular Member • Posts: 231
That's not correct. Rubber (actually thermoplastic) that becomes sticky is flawed.
Then just have it fixed if it happens. Replacing a dial or a ring or a sticker grip is a cheap repair and it occurs very rarely. We're not dealing with a complete VW car dashboard or a complex repair process (like an aperture or shutter replacement).
MarkAM
No, thermoplastic elastomers, commonly known as TPE, has thousands of formulations. The poorer formulations break down in the presence of solvents, UV, heat and even ordinary skin oils (which everyone produces all the time).
I just think it's time manufacturers stopped using this unreliable surface coating.
And the reviewers should always note if it is present on a product they are reviewing!
MarkAM
That's one approach. I was quoted hundreds of dollars to fix my Canon binoculars, and over a thousand to fix my car interior.
The other approach is not to buy anything using TPE (thermoplastic elastomers). I'm okay with hard plastic surfaces. I don't find them "cheap", unlike so many reviewers of products.
It's so relevant to come up with quotes to have your almost-fully-tpe-coated binocular or car dashboard repaired on this camera forum... just fyi, you can buy a replacement rubber for you 20D grip for only $8 and replace that yourself.
Good luck with your quest for justice against the big companies who use TPE..
MarkAM
The parts that are sticky are the mode dial (on body) and zoom ring (on lens). I'm not aware of cheap replacements.
You seem to have completely misinterpreted my words. I am not on a "quest for justice". I'm suggesting that reviewers alert us to the presence of these unreliable coatings. And I was canvassing what others thought of the fact that their expensive photographic equipment has this flaw.
for the amount of money these "big companies" charge for their gear, they would change these cheap covers quickly if there were enough Ped off owners' screem!
it was not a misinterpretation. It was sarcasm. I apologize if I came off too harsh.
I understand where you're coming from, as your car dashboard and fully coated binoculars were expensive to repair. I would be cautious as well when Canon comes up with a fully rubber coated camera. But that is fortunately not the case. A rubber for the grip, mode dials, some small covers: all can be replaced relatively cheaply.
As I wrote before, you can have your rubber grip or dial or zoom ring for your lens or SLR fixed for 50 euros or less. Ok, maybe your repair facility charges more than mine, so let's say its 100 euros. That is 100 euros in case it even does happen after let's say ten years, because it might also not happen.
That is why I believe the reviewers will not find it worthwhile to do the extra research and include that sort of info in their reviews for a problem that has such a small impact.
MarkAM
No, they cannot. I'm in Australia and they will costs the equivalent of $150 or more ... if they are even available. Have it done for you and labour will double that price. This is not a trivial flaw, and I'm not sure why you are trying so assiduously to minimize it. 🙄
No research required! If it has soft-touch rubbery dials or surfaces, it has TPE. Simple!
$150?!?? I think you missed my previous post then. Let me help you:
Canon original cover grip for your 20D: $8 for the item, $20 for shipping to Australia.
Canon original rubber dial for a 5D mkIV : $4.59 for the item, $3.16 for shipping to Australia.
Two Canon genuine zoom rings for a 17-40mm : $38,99, $2,99 shipping to Australia.
All those prices are nowhere near $150 euro per item. And as I said before: my repair facility only asked 50 euros to replace a focusring and it took them 15 minutes.
Let's just look back:
Does it happen to every or an above average number of bodies or lenses in 10 or 20 years: No.
Does it cost a relativily high price to fix: No.
This doesn't look like a high impact problem to me.
So I'm either minimizing something, or you are wasting your time making a big problem out of something that has low impact.
Again: I agree with you when it comes to car dashboards and your coated binoculars and other fully rubber coated equipment. But complain on those forums, I'm sure you will find more people in agreement there then on this lens related forum.
Ooh, when it's that simple I'll just get back to what I wrote in my first post:
I would rather have the [comfortable] rubber grip, have it [possibly] degrade after 10 years and then fix it for 50 euros or less, then have a slippery piece of equipment for those 10 years.
TheBlackGrouse Veteran Member • Posts: 3,586
You are absolutely right, I have binos for decades, with a lot of rubber, not sticky at all.
Binoculars are used in extreme conditions, thrown in heated cars when it's -20 degrees Celsius outside, carried in pockets, catch a lot of sun-cream, sweat, things like that.
Binos are supposed to last a lifetime and the better ones are built for that. If it's possible for binos why not for cameras? Prices are not that different.
TheBlackGrouse
Active Outdoor Photographer
MarkAM
Yes, probably real rubber. Durable 👍
Yet I had thermoplastic elastomer (TPE) aka "fake rubber" turn to mush even without doing any of those thing. My equipment sits in the closet 99% of the time.
Thanks for the sensible comment.
MarkAM
Two Canon genuine zoom rings for a 17-40mm : $38,99, $2,99 shipping to Australia. All those prices are nowhere near $150 euro per item.
Couple points:
  1. I said $150 all up, not $150 per problem.
  2. I don't need a cover grip
  3. That's the wrong dial for the 20D, AFAIK. Is the 20D dial even available?
  4. That's the wrong zoom ring for a EF-S 18-55MM KIT lens, AFAIK.
The point I'm making is that no matter if this costs $150 or $300 to fix (labour costs are much higher here in Australia than where you are), it's money I should not have to spend.
I used my Asahi Pentax K1000 today, lovely camera, 40 years old, never had a moments problem with it. That's as it should be. Surfaces pristine and durable.
On the other hand, it rained today, and my wife commented to me as we hauled out our umbrellas: "This one has a sticky handle". Sure enough, bought 10 years ago in California, the TPE coated handle is melting.
You expect that sort of thing to happen to a $30 item, not to a $1,500 item.
AT LEAST I DO.
Without a study, we don't know. Lots and lots of reports on the internet.
I simply disagree. Not everyone pays the low prices you seem to have access to for parts and labour .... IF you can find the right replacement equipment.
We agree to differ then. Thanks for your input.
Paul Stricklin Senior Member • Posts: 1,174
I learned to use the back of my hands to spread Off after ruining a car steering wheel and several camera accessories.
Paul Stricklin
Club, Event Photographer to pay for the equipment
Nature, Landscape for the joy of life
LPS
 Paul Stricklin's gear list:Paul Stricklin's gear list
Canon EOS 80D Canon EOS M6 II Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM
