Filtration Experiments
Started Jan 22, 2020 | Discussions
(unknown member) Contributing Member • Posts: 656
NOTE: Because I was unable to get support for deleting or editing the topics title,(https://www.dpreview.com/forums/post/63308716) I've had to create a new topic based on a different subject.
There's on on going debate with several members here and other sites who are experiencing issues with ND or Polarization filters on their mirrorless cameras. For the past year I've tested 6 major brands and 3 not so major brands a total of 12 different ND, Graduated ND and Polarization filters.
For more than 1 year, I've purchased, tested then returned filter like B&W, Hoya and tiffen only to learn that none of these filters will work on my Canon M6 camera. it's like the camera views beyond the filter rendering the glass/plastic or resin filters obsolete.
This morning I've located another fellow who's been experiencing the same issues I have when using polarization filters on his mirrorless camera. mind you there are those within the forum who continue to avoid these results claiming that it's user error and not the filters fault.
As Alex and my self have said.. We know what we're doing and how to adjust the filter for maximum filtration. yet these forum members continue to read only what they want to read and avoid the issue that Yes there are those of use who are experiencing issue with the use of filters on our cameras. subsequently, I've since ignored all those who continue to discredit my test on the use of filters in conjunction with my M6 mirrorless camera.
After reading Alex's post from this morning, I couldn't help be notice at his images looked nearly identical to those image I took when testing these filters myself. Based on his images, it's apparent that Alex, myself and many others are having these same or identical issues for these filters. (https://www.dpreview.com/forums/post/63554319) As he has suggested, he too seem to gain more filtration or a slightly darker image when using the B&W filter. The exact filter I used almost 1 year with the identical results.
Here's a list of filters I've tested with my Canon M6:
  • B&W
  • Hoya
  • Tiffen
  • Lee
  • Gobe
  • Ranger
The B&W seem to offer the most filtration or darker image than all the other filters tested as I've listed this filter in the number 1 position.
Because of all these failed attempts to use filters on my camera and with my connections with the aerospace/electronics industry, I've contacted several counterparts in an effort to locate a space age material that could be used as a filter for my camera. it's become my mission to find materials that can or could be used as filters either as an ND or polarization filter.
As of 2 months ago, the shop sent two samples of materials they located in their shop set to be trashed. One piece was yellow while the other was tinted dark. I've since been testing the yellow material as a filter with positive results with images like this.
Dead Tree at Fell Lake
On this day, I wasn't able to carry my camera with me, so I took my LG Rebel cell phone with me just in case. Ironically, I also had a small sample of the yellow material that I placed over the cell phone camera lens. The end result is the above image. The bluest of blue skies and clear water helped me achieve this picture, with a cell phone I don't us often because I can never trust the image quality.
Although the image is a bit darker than I'd like it to be, it was clear that the yellow material is going to be apart of my photography from now on.
During these test, The shop again sent a sample of the tinted plastic/resin material. As compared to a ND filter which I've had for some time, the space aged tinted material is dark by 35-45%. I've yet to test this timed material, but the shop seen fit to pre-cut these small panels into 85mm x 100mm in order to fit the Coken P mounts. Now if I could get some warmer days to venture out with my new tinted "fixed" polarization filters.
Just as soon as I'm able to do that, I'll report back with my findings. But as compared to one of the ND filters I already have, this new plastic/resin material is darker than a grade 8 ND filter but not as dark as a grade 10 ND filter and has a metallic type coating on the face side of the material.
Canon EOS M6
petrochemist Veteran Member • Posts: 3,619
Re: Filtration Experiments
Given that the filters are physically blocking some of the light coming through the system your camera can't render them obsolete. It's probably just changing the ISO so the effect is not seen (keeping the same shutter speed despite the reduced light).
Cameras are clever but they can't work out what light has been blocked by an external filter, they just react to what gets into the lens.
It would be different if you were talking about UV filters, digital cameras are barely sensitive to UV, so this change is ignored.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
D Cox Forum Pro • Posts: 32,980
It's not clear whether you're talking about polarizing filters not working or colour filters not working. And if polarizing, straight or circular.
Are ND filters not working ? If you put a strong ND filter on the lens, with the metering mode set to A, and fixed ISO setting, the shutter speed should change. Does it ?
If you put a polarizing filter on the lens, and rotate it while watching the image (on the LCD or EVF) of a reflection in water,  the reflection should come and go. Does it ?
If you put a red filter on the lens, you should get a red image. Likewise for other colours.  If you have Auto White Balance set, the effect will be reduced. Set White Balance to Daylight/Sunlight for these experiments.
Sigma fp
Dem Bell Senior Member • Posts: 1,091
You can tell whether a polarizer works or not without attaching it to a camera. Just look through it at an LCD screen.
The camera will record whatever light the filter passed through. Film, DSLR, mirrorless, Canon, Nikon - doesn't matter. It is harder to see the effect in the EVF though, because it automatically adjusts its brightness.
OP (unknown member) Contributing Member • Posts: 656
Dem Bell, I tell others who want to test the polarization filter off camera first while holding the filter in front of the computer screen, then rotating the out filter ring to the optimum or darkest setting. mark this setting before mounting the filter on the lens. The only regret I have is that I sold my 35mm cameras back in the 90's or I would have offered an alternative test using the 35mm camera. Now I just need some warmer weather to thoroughly test this tinted filter material.
I'm very excited to see any results and hope this could shed new light on those person wanting to use filters on their cameras without having to worry about rotating any outer rings. Though my design would require the use of a Cokin P type lens mount. Not only am I interested in using one of these tinted filters, I' wondering if multiple filters can be stacked into the Cokin P mount and offer more filtration. I mean holding two or three panels up to the sunlight, I don't see any difference. Again wait around, cause spring is just around the corner. We'll be making a special early morning trip to the Eastern Shore of MD to catch a sunrise just for this purpose.
BBbuilder467 Veteran Member • Posts: 7,057
Count stops with ND
If you lock the exposure in Manual mode, when you add an ND8, the meter should react by 3 stops. The EVF might compensate, but the camera has to see it. If the ISO is locked, the meter should show it.
If you don't have to adjust to compensate for the ND, you have to be doing something wrong.
It works the same indoors or out.
Re: Count stops with ND
Builder, after 50+ years of taking photographs & 10 years using digital camera, I think I know what I'm doing.
Also to all other responding to this thread, this is an on going experiments of mine using a variety of new/space age product that were not designed to be used as filters. This is a blog of sorts and members need not respond to my thoughts or experiments, unless they actually have an interest in the test i'm doing and not to correct these test for I know what I'm doing.
With the help of a couple of aerospace & electronic industries, "we" think we know what we're doing. Again the yellow panels have proven very benefit to my photography style. But I've yet to test the tinted panels and I'm going to bit up a container of rubber coating which I'll us on a single edge of each panel to create a hold point as well as a orientation point when using the filter in the Cokin mounts.
It's hard to relate to anything when you claim that you add a 3, 6,or 9 stop ND and see no effect whatsoever, but use yellow and you do.
The color filters can work in black and white film mode, but they might be 3 stops and auto white balance can cancel them out.
Yet another member who has ignored my request to stop responding to my test thread only to inform me I'm not doing something right. Thus another member who will fall by the wayside and is now be ignored..
In other words, I suspect that having a test thread should be discontinued simply because other members continue to discredit what I'm attempting to achieve. A personal documentation of my experiments without being critiqued or criticized for my testing procedure. I suspect that I'll need to break down and create a blog site just to avoid these unwanted comments.
SteveLA New Member • Posts: 4
I have read quite a few of OP posts/comments on these boards stating that polarizers and NDs don’t work with his M6. If you consider that both of those filters are wildly different, than how is it that they don’t work but a yellow filter does?
The issue I have is that OP will not state in any forum what it is he is trying to do. He provides no photo/exif data to back the issues he is having and just keeps stating that somehow he found a camera that renders NDs and Polarizers obsolete.
Madness.
Madness.
That was my point. In an auto exposure mode, it's possible that a 3 stop ND could practically disappear, but it can't do that in Manual mode. The 3 stops have to show up somewhere.
It's really too bad you keep deleting your accounts.
