Another fisheye question
Started Jan 21, 2020 | Discussions
GinaRothfels Regular Member • Posts: 348
I already own a fisheye lens - the Tokina 10-17mm fisheye zoom (f3.5-4.5) which I occasionally use with an adapter on my M50.
While reading this forum last night I became aware of the 7Artisans 7.5mm fisheye which is wider, faster (f2.8) and doesn't require an adapter. The one drawback is that it's a manual focus lens.
I'm not too bothered about using the adapter, but I'm curious to know whether the benefits of the wider and faster lens are going to be significant enough to make it worth buying. Ideally I'd like to test any lens before buying it, but this one isn't available locally - only on Amazon.
I'm probably expecting a bit much asking if anyone has used both lenses, but I'm struggling to find any comparisons aside from this one from versus.com which says the Tokina is BETTER because of its narrower minimum angle of view and longer maximum focal length. Clearly this comparison doesn't understand what fisheye lenses are all about.
Any advice would be much appreciated.
Canon EOS M50 (EOS Kiss M)
Sittatunga Veteran Member • Posts: 5,406
Re: Another fisheye question
See this thread; https://www.dpreview.com/forums/post/63490564
Personally I like the Samyang lens, as its stereographic projection is a bit more relaxing to view than most fisheyes. Ken Rockwell has an interesting discussion of this as one of his more sensible web pages.
For anything this short, scale focussing is as quick as anything; you can guess any distance further than arm's length more than accurately enough and use a tape measure for anything within reach.
Samyang 8mm f/2.8
Taken an hour after sunset, hand held; that's the moon in the picture
OP GinaRothfels Regular Member • Posts: 348
Samyang 8mm f/2.8
Thanks. I love your photo but the Samyang costs a lot more than I want to spend on a manual focus lens. It's almost double the price of the 7artisans.
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
What about the newly announced 4mm F2.8? Now that's a fisheye! 210 degree angle of view. It's manual focus, but at that length, just set it to infinity and F5.6 (or 8) and you're fine.
https://www.dpreview.com/news/5486009930/venus-optics-adds-canon-m-fuji-x-and-sony-e-mount-options-to-its-4mm-f2-8-circular-fisheye-lens
$200 seems like a pretty reasonable price for this. I'm tempted, but I'd probably just take a few gimmick shots, and then leave it in a drawer.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
I haven't read about that yet. I'll have a look later. If it produces circular images (I'm guessing that based on the title) it may be too gimmicky for me. I've got a fisheye converter which I used on my Olympus OM-D E-M5 a long time ago for round photos, but I didn't use it often.
Well now I've read it. I like some of the sample photos in that article but I can't see myself getting much use out of that lens. Thanks for the suggestion though.
DrSki New Member • Posts: 7
i am totally impressed with Meike's 8mm, f2. 0 lens. Around $150. EOS-M mount. The fast aperture is great for night and low light shots and even wide-open the depth of field is great. Focusing is not a concern.
Night shot
sunset shot: crepuscular and anti-crepuscular view.
 DrSki's gear list:DrSki's gear list
Canon PowerShot SX150 IS Nikon Coolpix A10 Canon EOS M10 +2 more
HaroldC3
HaroldC3 Veteran Member • Posts: 3,067
What about the Laowa 9mm f2.8 lens?  It’s mf but not fisheye so no need to defish.
 HaroldC3's gear list:HaroldC3's gear list
Canon EOS M6 Nikon Z7 Canon EF-M 22mm f/2 STM Canon EF-M 15-45mm F3.5-6.3 IS STM Nikon Z 14-30mm F4 +3 more
Night shot
F2.0 sounds great. I'm not sure I want circular images though.
I like fisheye but I'm sure your suggestion will help someone else.
Edit: on second thoughts it's something to consider as I probably don't need two fisheye lenses anyway.
I'm considering buying the EF-M 22mm f2, but as I already own an EF-S 24mm f2.8 pancake, something wider might be better.
noisebeam Senior Member • Posts: 2,963
Do you mean their 6.5mm f2 offering?  Or their 8mm f3.5?  Looks like 6.5mm to me.
 noisebeam's gear list:noisebeam's gear list
Sony RX100 II Canon EOS 30D Canon EF 100mm f/2.8 Macro USM Sigma 15mm F2.8 EX DG Diagonal Fisheye Sigma 30mm F1.4 EX DC HSM +8 more
Jack Calypso Senior Member • Posts: 1,094
I have an old Minolta MD 7.5mm fisheye, and it's fixed focus. Not a concern at all:-)
And then I saw the price. I'm not in the market for a $500 lens right now, especially not a manual focus one. I can buy both the Canon EF-M 22m f2.0 and the 7artisans 7.5mm f2.8 and still have change.
Of course import duties and a high exchange rate don't help.
Understand that if you place the horizon near the centre of the frame, you can then crop and enlarge to get unique perspectives that would be difficult to achieve with a standard lens. Following images are examples. I'm shooting with an M100. Most of my fisheye images are nightscapes, so the f2 works great for me. You are going to get circular images with a fisheye lens. That's why it's called a fisheye! But there is a lot of latitude for creativity.
cropped fisheye image
Not all fisheye lenses produce circular images. My Tokina 10-17mm fisheye zoom doesn't . Nor do the 7Artisans 7.5mm fisheye or the Samyang 8mm f/2.8 from which Sittatunga posted a sample image in this thread.
CQui
CQui Senior Member • Posts: 1,738
I have no financial interest in Venus optics but
I own their Laowa 9mm wich is very good and I recommand for wide angle
And if you need fisheye and want to get wider than wide angle then look at the Laowa 4mm
Claude
 CQui's gear list:CQui's gear list
Canon EF 50mm F1.8 II Canon EF-M 22mm f/2 STM Canon EF-M 18-150mm F3.5-6.3 IS STM Venus Laowa 9mm F2.8 Canon EOS M6 II +6 more
EFM Wide Angle Options
I am also looking for an ideally <10mm <f2.8 Rect. or FE EFM lens.  This is the summary I put together for myself, but thought I'd share:
Circular Fisheye:
Laowa 4mm/f2.8 cFE, MF/A, 135g, $200
Meike (or Opteka) 6.5mm/f2.0 cFE, MF/A, 266/300g, $130-143
Full Sensor Fisheye:
7artisans 7.5mm/f2.8 FE, MF/A, 278g, $140
Samyang (or Rokinon) 8mm/f2.8 FE, MF/A, 260g $250-300
Rectilinear:
Laowa 9mm/F2.8, MF/A, 215g, $500 (I read this one has up to 4stop vignette in corners)
Rect Wider than 10mm, but for comparison sake:
The 11mm/4.0 end of the Canon 11-22 zoom.
Rokinon 12mm/f2.0, MF/A, 245g, $330-400
Several Mieke, Opteka, 7art, 12mm/f2.8 MF/A offerings in ~$190 to $240 range
Sigma 16mm/f1.4 – AF/A, 405g, $450
Please add any other lenses below 10mm and correct any wrong too.
Re: EFM Wide Angle Options
Nice list. Thanks for sharing.
Circular Fisheye:
Rectilinear:
Looks really nice, but more than I'm willing to spend on an MF lens.
I already have that one, so I'm not sure the faster 12mm lenses will offer that much benefit.
Sounds really good because it's f1.4 but for that money I'd want to try it out before buying it. Sadly it's not available in my country yet. Maybe one day!
Thanks. I had it ready to go! I listed the weight as well as I will take it as part of my multi-day backpacking trips (for non tracked astro shots and more) and every 100g counts.
Circular Fisheye:
Rectilinear:
I will spend if a great lens, but the reports of the severe vignette wide open mean that for evening or astro shots if I correct in post then I loose the benefit of the lens speed. Sometime full correction is not needed of course, but I am more and more bothered by vignetting. I'd rather add in in post if for the art than have it inherent. It is not the only lens on this list with the issue, but I haven't yet researched.
I have it too and it is my primary lens on camera when hiking/backpacking. I listed it because any wide evening/astro lens will need to be notably faster, sharper across field wide open or wider. The Rokion 12/2 below does get some interest from people doing astro shots, but it will not add a new FL for me.
It is tempting, but for me not only pricey, but relatively heavy for my purposes and not a new FL.
After I reviewed these options I think am most interested in the full sensor coverage fisheyes. They are small and light and can be defished when desired with less extreme losses in the corners than the circular fisheyes.
At this point that would be the 7art 7.5mm or the Roki 8mm. Now I need to find out if the Roki has benefits over the 7art and the decide if worth 2x the price.
I also am tempted by the fun aspect of the 4mm or 6.5mm. I could use it for a few night sky images in combo with the 11-22 which I will have anyway and I enjoy 'fun' lenses for day use as well.
Decisions...
Circular Fisheye:
Rectilinear:
The price and weight bother me too, but I may be tempted if I ever have an opportunity to buy one. Alternately maybe the Sigma 56mm f1.4. Neither is a lens I would buy online though - I'd have to try them on my camera to see if I like them.
I'm not particularly interested in the circular lenses but I'm still tempted by the 7artisans 7.5 though I don't really need another fisheye lens. The main attraction is that it doesn't require an adapter like my Tokina 10-17mm does. And it's smaller and lighter, faster too. But I'm a bit worried about buying something I haven't seen. I've never bought a lens online before.
Decisions...
Decision making is something I really struggle with.
