Who only 16k for a camera sensor
Started Jan 21, 2020 | Discussions
Brisn5757 Veteran Member • Posts: 4,540
I have the G7 camera which has a 16k pixel sensor and I noticed the Panasonic produced other cameras that have a 16k pixel sensor, so I'm wondering why not move to higher pixel sensors like other manufactures have.
The only advantage of a 16k sensor was when I was only holiday I could take a lot of photos without fulling up the media card.
Brian
 Brisn5757's gear list:Brisn5757's gear list
Olympus SP-570 UZ Sony Cyber-shot DSC-WX70 Sony Cyber-shot DSC-HX200V Sony RX100 IV Canon EOS 300D +9 more
Panasonic Lumix DMC-G7
Cyvan Regular Member • Posts: 447
Re: Who only 16k for a camera sensor
11
I think you mean 16MP ie Megapixel . Panasonic has moved on, starting with the GX8 then GH5, GH9, GX9 and G90 all have 20MP sensors.
 Cyvan's gear list:Cyvan's gear list
Panasonic Lumix DMC-GX8 Panasonic G85 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 +7 more
OP Brisn5757 Veteran Member • Posts: 4,540
Good to know. It was a while since I last checked.
Brian
DidierDCH Senior Member • Posts: 1,184
Note that, depending on how you use your images, 16 MP is not necessarily that limiting.
If displaying on a full HD screen without any cropping for instance, you only need 1980x1020 pixels meaning a mere 2MP. A 4K screen at 4086x2304 pixels is about 10MP.
Printing large size posters is another matter of course...
Didier
 DidierDCH's gear list:DidierDCH's gear list
Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-FZ300 Panasonic Lumix DC-ZS70 Panasonic Lumix DMC-G1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +2 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
10
Brian
For some of us 16MP works just fine.
In fact when things got to and past 8MP it worked just fine for me.
But then, I lead a simple life.
As for card capacity, buy bigger cards and/or more of them, they are darn cheap now.
Barry Twycross Veteran Member • Posts: 4,780
I don't need the extra pixels. I'm quite happy with 16Mpix.
I've compared the output of a 16Mpix sensor (in my GX850), against a 20MPix sensor (in my GX9). The 16Mpix is less noisy, even when you downrez to the same size for comparison. The 20MPix makes marginally sharper images (when you downrez to the same size of comparison).
 Barry Twycross's gear list:Barry Twycross's gear list
Olympus E-PL7 Fujifilm GFX 50R Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Fujifilm GF 110mm F2 Venus Laowa 7.5mm F2 MFT +11 more
Asla
Asla Senior Member • Posts: 1,101
Brian
Hi!
How big are you printing? 30x40cm photos are great from both sensors. And if you are printing way larger, 4mp might not do that big difference, as one might expect.
Other thing is of course newer technology: newer sensor may produce little less noise at higher iso's.
Someone already suugested buying more cards. I think that is a good advice.
A s l a
rurikw
rurikw Veteran Member • Posts: 3,788
Brian
Hi!
A s l a
I've got very nice A2 (594x420mm) prints from 16MP but when I had an exhibition last summer the feedback was: fewer and bigger! So what do I do now? As my images are mainly of rocks and walls I could get a hi res model or learn hand held super resolution or do panoramas. Or go 40MP FF. Or accept the lack of sharpness from up close.
 rurikw's gear list:rurikw's gear list
Nikon Coolpix 5000 Sony Cyber-shot DSC-R1 Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill +37 more
Asla
rurikw wrote:
Brian
Hi!
A s l a
Hi!
I'd say give a hi res a chance. Take both hi res photo an normal to compare. Steady subjects like rocks and walls is just, where hi res fits best.
A s l a
rurikw wrote:
Brian
Hi!
A s l a
A discussion at https://www.markuswaeger.com/2019/02/12/aufloesung-und-druckformat/ argues (in German) for the latter, essentially stating that the larger the print the farther away from it you will actually stand to watch it, hence the lower dpi are required so that the required number of MP is lower than you could think.
From two key tables in there;
If you retain 300 dpi whatever the print size:
18MP => 297mm × 420mm
24MP => 340mm × 500mm
36MP => 400mm × 600mm
50MP => 500mm × 750mm
If however you factor in some reasonable viewing distance depending on the size of the print:
A2 print at 1m: use 90ppi≈ 2,2MP
A1 print at 2m: use 60ppi≈ 2,8MP
A0 print at 3m: use 45ppi≈ 3,2MP
Poster 252cm × 356cm at 5m: use 30ppi≈ 12,5MP
Perhaps worth a try, see if that works for you?
Didier
rurikw
DidierDCH wrote:
rurikw wrote:
Brian
Hi!
A s l a
Didier
Comforting figures. I will obviously have to do that with the old pics. It's just that I don't think I can prevent people from going closer. I wasn't very happy with some 5MP files at A2. But i'm a bit of a pixel peeper.
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
The "best of both worlds" would also be possible.
They could make a 64MP bayer-pattern sensor, with rgb or even rgbw pattern, and then combine every square of 2x2 pixels to form a 16MP image that still does not take up more space on the memory card but that would be free from moiré artifacts and that would have more or less the same low noise (because binning pixels reduces noise).
But everyone would be screaming for access to all 64MP for their images...
Getting to know the Olympus OM-D E-M5 II.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
Haider Senior Member • Posts: 1,234
Brian
16MP is good enough for most consumers. I rarely print bigger than 5x7, some at 8x10. I had a few prints made for me at 20x16. I was happy with the results. It's on a wall behind the sofa. I think that m4/3rds should concentrate resources on an AI/Deep Learning based image upscaler. Everyone is using engineering to do colour from a black and white CMOS sensor,..
 Haider's gear list:Haider's gear list
Olympus E-M1 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +2 more
Brian
Hi!
A s l a
The largest I'm able to print is A5 size but I tend to crop my photos so a 16 MP sensor limits how much I can crop the photo. Lens quality is another limiting factor.
DidierDCH wrote:
rurikw wrote:
Brian
Hi!
A s l a
Didier
Usually I print at 6x4 inch and the largest I can print is A4, but I tend to chop some of my photos.
PS: for anyone reading this this the first word in the title should have been 'Why' and not 'Who'
Brian
Brian
Kristoff_EM5 Regular Member • Posts: 311
I like to print big(ish) from my 16 mp sensor in my EM5i, I'm experimenting with up scaling in Photoshop using "preserve details 2.0".  So far I'm pretty impressed.
 Kristoff_EM5's gear list:Kristoff_EM5's gear list
Olympus OM-D E-M5 Olympus E-M5 II Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +5 more
Asla
rurikw wrote:
DidierDCH wrote:
rurikw wrote:
Brian
Hi!
A s l a
Didier
Hi!
Yes, comforting figures. But of course, more ppi = more close it looks good. I think you are best one to decide.  Try, print, look, compare, judge.
a s l a
The way things are going with software advantages it would not surprise me that you can sharpen a burred photo by having the software repainting parts of the photo. Removing noise from a photo without softening the photo is another thing that might improve.
Brian
Brian
Yes we have bayer interpolation why not have HiRes Interpolation. Do it on a PC with CUDA/nVidia GPUs. I have already seen images in deep learning already being cleaned up without the blurring of normal NR and ray traced images upped to look like they have more light sources as part of the original rendering....It's the way to go do it in the Oly viewer software on a PC/Laptop....
Guy Parsons
Why only 16k for a camera sensor (repaired)
Based on the fussy rule of 300 original camera pixels per inch of print, then .....
  • For 6x4 inch print edge to edge 1800x1200 pixels = 2.16MP is perfect
  • For A4 at 8.27x11.69 inches edge to edge means 2482x3507 = 8.7MP
At a less fussy but still quite adequate 200 camera pixels per inch then.....
  • For 6x4 inch print edge to edge 1200x800 pixels = 0.96MP
  • For A4 at 8.27x11.69 inches edge to edge means 1654x2338 = 3.9MP
Edge to edge printing is called "full bleed" and to allow for paper size variations and positional differences in handling the paper within the printer, then the full bleed print is actually up to a few mm bigger than the paper, so some pixels are "wasted" on all edges in that case and make the MP requirements a whisker larger.
"Why" means that we need to listen to what Olympus used to stress that "12MP is all that is needed to replace 35mm film".
In my own practical experiments and lots of printing from digitised film and from low MP cameras in early days of digital for camera club competitions, then I would have to say that "8MP looks better than 35mm film" as long as it is not printed too big.
The reason being that film printed too big hides the loss of resolution in the grain. Digital printed too big is far "cleaner" than film and there's no hiding the lack of resolution, so digital has a harder top size limit for printing.
It all gets down to how far the viewer is from the print, if we allow for always close examination, then it's best to stick to calculating on 300 original camera pixels per inch of print, wandering down to 200 allowable for some subjects, dreamy scenes, female portraits etc where absolute resolution is not important. Below about 180 camera pixels per inch then it does just begin to look soft.
Good printing methods also help, I've always used Qimage for printing and that does a noticeably better print than any photo edit program that I've tested over the years. It auto interpolates to the internal needs of the printer driver depending on model and make and also auto sharpens to suit the print size requested.
Modern tricks can be used like "overdrive" in Qimage on some newer printers where better resolution can be achieved by upping the interpolation a notch. https://www.ddisoftware.com/qimage-u/tech-prt.htm
Now my club competition days have long gone, so currently only occasional 6x4 dye-sub prints for memories or give-aways. Keep in mind that 6x4 printing is actually more critical than any large print as inevitably the viewers drag out a magnifying glass and look for detail of signs and identifying faces in crowds. So they should always be a well done 300 camera pixels per inch or better effort. Thus you need to keep to that 1800x1200 crop or better for the postcard size, but in truth the 1200x800 number is acceptable for most things.
The advantage of the 6x4 print is the ability to "zoom" by crop, so early days wandering with my Panasonic LX3 with it limited zoom of "24 to 60mm" I can stretch the zoom when printing 6x4 to make it something like a "24 to 180mm" camera with an acceptable print. Nice.
Similarly with my current Sony RX100M6 with its "24-200mm" lens can be made into a "24 to 608mm" camera at 300 resolution and "24 to 912mm" camera at 200 resolution on those postcards.
Regards.... Guy
