Rear cap replacement for WCL-X100 converter?
Started 8 months ago | Questions
SirPalomid
SirPalomid Contributing Member • Posts: 866
Hello folks,
I finally was able to loose rubber rear cap for WCL/TCL converter, does everybody know where I can find a replacement (may be even not original Fuji)? Google does not give me valuable results unfortunately.
Appreciate your help in advance,
 SirPalomid's gear list:SirPalomid's gear list
Fujifilm X100F Fujifilm X-E1 Fujifilm X-T1 Olympus E-M1 II Samyang 7.5mm F3.5 Fisheye +6 more
John356 Regular Member • Posts: 162
Re: Rear cap replacement for WCL-X100 converter?
You should be able to use a standard lens cap, don’t have my F / WCL with me to give you the correct size.
John
 John356's gear list:John356's gear list
Sony RX100 Fujifilm FinePix X100 Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-H1 +7 more
SirPalomid
OP SirPalomid Contributing Member • Posts: 866
I doubt that I can use standard REAR lens cap for Fuji WCL / TCL though, that rubber piece that covers rear element (that screws into X100F body).
jmiyasaki New Member • Posts: 1
Hi there. Have you found a replacement yet? I’m having the same issue—lost the rear cap to my WCL-x100 ii.
DarnGoodPhotos Forum Pro • Posts: 10,124
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X-Pro2 Fujifilm X-E3 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +4 more
Robmas4229
Robmas4229 Contributing Member • Posts: 751
I just use a 49mm pinch cap on each end of my WCL-X100II.
 Robmas4229's gear list:Robmas4229's gear list
Fujifilm X100V Fujifilm X-T2 Fujifilm X-E3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +6 more
SirPalomid
DarnGoodPhotos wrote:
I searched eBay for "fuji wcl-x100 rear cap" and found:
https://www.ebay.com/itm/Metal-Rear-Lens-Cap-Cover-for-Fujifilm-Fuji-Fujinon-WCL-X100-WCL-X100-II-WCL-X70/174281671355?hash=item2893ff42bb:g:8BUAAOSwN3xeu-q-
Oh, thanks a lot. it is just what I need!
Going to buy 2 instead of rubber caps that are so easily to come off.
SirPalomid
Hi, I haven't yet, but take a look at ebay link in some of the answers below from DarnGoodPhotos - metal caps for converters, going to try them.
