Focus issue with Sigma 120-300 f2.8 sport
Started Jan 20, 2020 | Discussions
RamiGridishPhoto New Member • Posts: 5
Hi
i bought sigma 120-300 f/2.8 sport version 1 week ago
i use this lens with Canon 1DX
suddenly have a focus issues with the lens
The lens doenst focus in 300MM, if i want to do focus on 120mm its ok but after i will try in 200+250+300mm it doesnt work
anyone know this issue and it happen to him?
i dont know what to do because i bought the lens 1 week ago and its very strange and she is new
i will appriciate your information about that
thank you
(unknown member) Forum Pro • Posts: 11,356
Re: Focus issue with Sigma 120-300 f2.8 sport
RamiGridishPhoto wrote:
Hi
thank you
Did it stop focusing at 300mm at any distance or just up close?
If I don't respond to your post after you responded to my post with NEGATIVE remarks that means you are on my Ignore list.
Photography Director for Whedonopolis.com
Mike_13 Senior Member • Posts: 1,005
possibly have focus limiter on to something that prevents you from focusing further away?
 Mike_13's gear list:Mike_13's gear list
Canon EOS-1D Mark IV Canon EOS-1D X Canon EOS Rebel T4i Canon EOS R Canon EF 100mm f/2.0 USM +10 more
OP RamiGridishPhoto New Member • Posts: 5
Hi
no, i did reset to setting with the dock
the lens is new and i dont know why she doesn't focus
someone know maybe its issues with sigma 120-300 lenses?
i saw in number of post more persont that its happen to him
it stop focusing at 300mm at any distance ,close and far
also in 200mm
she focused only in 120mm and its also sometimes work and sometimes no
Hi
dock reset would not have any impact on where the focus limiter switch is set to
the AF issues happen with faraway subjects?  i.e. 40 feet away?  what about at MFD?
also in 200mm
If AF on camera and on the lens is ON, Limiter on the lens is on FULL and Custom on OFF and it doesn't focus then your lens is broken.
Luftwalk Regular Member • Posts: 214
Maybe you can try updating FW first, if there are some problems with earlier FW and the camera in question
 Luftwalk's gear list:Luftwalk's gear list
Nikon Z6 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 50mm F1.8G Sigma 24-35mm F2 DG HSM Art Nikon 200-500mm F5.6E ED VR +4 more
The lens is new so it has current FW.
He's indicated using the dock with to reset settings, which means if his FW was out of date, he would have been made aware at that time that it was available.  I certainly hope he wouldn't have ignored it
If you've reset via dock, didn't ignore any potential FW updates, and ruled out switches on the lens, I think your next option is to try alternate bodies (friends, camera store, etc..) to see if the issue remains.  This is probably headed towards the lens needing Sigma's attention
Thank you
Basically i just checked with other bodies and have a same issue
With other lenses everything is well
Its very wird, have a chance that the lens is defective although she is a new?
I dont have luck with sigma lenses, with my last 120-300 i had same issue until i replaced focus engine
I saw in other posts and i think to more photographers with this lens its happened
The switch is on Af
Swith of custom is off
Swith of limiter is infinity
Stabilizer is off
Have a chance that the lens is defective although she is a new?
Maybe do you know about more photographer's with this lens have a same issue?
I think its issue with sigma lenses
if NEW lenses never had issues, they wouldn't come with this thing they call WARRANTY
It happens, and unless there's apparent physical trauma evidence to the lens, you should be well covered
ikolbyi Contributing Member • Posts: 608
Thank you
I recently purchased this lens for a Canon 5D.M4 and I had front-focusing issue, meaning the lens was front focusing even when I used a single autofocus point.  The resolution was for me to send my camera body with the lens to Sigma for calibration.
 ikolbyi's gear list:ikolbyi's gear list
Canon EOS 5D Mark IV Canon EF 24-70mm F4L IS USM Olympus E-M1 III Olympus Zuiko Digital 2.0x Teleconverter EC-20 Sigma 120-300mm F2.8 DG OS HSM +6 more
LMowrey New Member • Posts: 1
There is a range switch on the barrel of the lens. More than once I have experienced issues similar to what you describe until I remembered to check that switch. Good luck.
