nx2000 firmare update failure
Started Jan 16, 2020 | Discussions
leoncito
leoncito New Member • Posts: 3
hi everyone
i have a nx2k and just update the firmware, but now the camera fails
when i turn off the rear led keeps blinking in green and after a few seconds is unabble to turn on, for turning on the camera i have to remove the battery and put the switch on the ON position and insert battery after that everything runs fine
but if want to connect the camera to my pc it wont be recognized
is there a solution? or a downgrade is posible?
thanks for your answears
Samsung NX2000
alonsomg New Member • Posts: 2
Re: nx2000 firmare update failure
Sorry to hear that. I was in the same situation. Here is whats happened:
I tried to update firmware from 1.10 to 1.18, with no successful use iLauncher, i tried manually install by the Micro SD.
The camera got stucked in the Updating green line several minutes. So i did extract the battery, and keep the green light blinking. After one hour of research, a member here suggested, use another card and remove the battery, (At this point the display get a ghost image of the update screen) so...
I get another micro SD (already formatted in camera) with 1.18 firmware and insert battery.
The updating progress was finally done!! but.....
Camera was flashing the back led over and over. SO i used your method to remove battery and use, and when switched off, again the green blink.
Made more research about and downgrade. What else i could lose?? lol
Download 1.17 firmware and do the same prices of "upgrade" and guess what??
IT WORKED!!!
Now the camera was bring back to life with latest software (please ignore the 1.18)
Little changes notice , so my advice: keep your camera with the old software and you will avoid a 3hr headache. Or take the risk!
Hope this help you!!
