5D mirror fix
Started Jan 15, 2020 | Discussions
jerelee Regular Member • Posts: 346
5D mirror fix
How much is a mirror fix on a 5D classic?
 jerelee's gear list:jerelee's gear list
Panasonic Lumix DMC-GX85 Canon EOS M6
Mark B.
Mark B. Forum Pro • Posts: 27,914
Re: 5D mirror fix
Honestly, probably more than it would cost to buy a good used copy.  I'd be surprised if the parts are even available.  Maybe you can buy one on ebay that doesn't work but has a good mirror, then find a shop that can replace the mirror on yours from the used body.
Mark
preferredfault Regular Member • Posts: 365
Re: 5D mirror fix
Easy to fix yourself, just re-glue it carefully in the proper spot. You could use special glue, but crazy glue should work just fine. Then once I'm sure it's properly glued down, I'd put a bit more glue to bridge the edges of the mirror with the mechanism to make sure it's secured in place.
"I can explain it for you, but I can't understand it for you."
Scott Larson Veteran Member • Posts: 6,928
Re: 5D mirror fix
I fixed mine with super glue. Too bad Canon didn't use super glue when they made it.
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +16 more
