RF Lens Humming noise
Started Jan 12, 2020 | Discussions
Mike Mulaw Forum Member • Posts: 70
I have an EOS R and several RF lenses.  I love the system for the most part, how fast and accurate focusing is.  The camera could use a bit better ergonomics, but I've gotten used to it.  Anyhow, it's not causing me any issues, but I'm curious - all of my lenses exhibit a "humming" noise when the camera is on, regardless of whether the IS is on or off.  It's hard to hear unless I put my ear up to the lens.  I'm curious what this is - if it's not the IS, then what would it be?  To be clear - the lens is not actively auto-focusing, and the noise continues while the camera is on until it is switched off.
R. Slaughter Senior Member • Posts: 1,291
Re: RF Lens Humming noise
Mike Mulaw wrote:
<To be clear - the lens is not actively auto-focusing, >
Are you certain that Continuous AF is switched Off in the menu?
R. Slaughter
Always Simplicate, Never Complify
EOS R, RF24-105
EOS 7D,7Dii,6D,5Div L glass: 50/1.2;100 Mac;300f4;17-40;24-105ii;70-200/4;70-300;100-400ii;150-600 Bigma + tse90
http://www.pbase.com/nufsed/galleries
OP Mike Mulaw Forum Member • Posts: 70
yes, even with the camera in one shot focus mode with single photo drive mode, I hear a faint humming from all RF lenses even when not in IS mode.
Helen
Helen Veteran Member • Posts: 7,606
It'll still be the OIS, even if it's turned off, because most OIS systems including Canon's (as far as I know) use an electromagnetic suspension system for the elements that perform OIS.  Therefore, even when OIS is not running (but the camera is turned on), it is still active simply to hold the elements at a fixed position (instead of actively moving them around when it is activated).  When the camera is turned off, the OIS elements are free to slop around and clunk gently.
Interesting - this must be unique to the RF lens system as my EF lenses do not do this, either mounted on my EOS 5D Mk III or mounted on my EOS R.  When the IS is turned of on the EF glass, I hear a pronounced "parking" noise, then nothing.  With the RF glass, after the IS is switched off there is no audible difference in "humm".   I guess this contributes to the less-than-stellar battery life I get with my R compared to my 5D.
Andy01 Veteran Member • Posts: 5,188
Isn't Continuous AF a different setting to One Shot AF or Single shot drive mode ? It is where the lens continues to focus even when the shutter button is not depressed. It is a menu setting, not a camera setting from a button.
It could be AF which operates continuously on both RF and EF-M systems.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
Helen
Possibly, although the main contributor is of course that a mirrorless camera is running live view full time - most DSLRs would have a much lower battery life if you left them permanently in their live view mode.
Colin
yes I misunderstood - but i just checked and continuous AF is also set to disabled. Based on other comments it seems it is Probably the IS system running in non IS mode to keep the optics centered  strange they do this differently with RF than EF. Hopefully there is probably a good reason For that
Agreed, but lens manuals normally warn you against keeping IS on all the time due to battery usage so interesting choice by Canon.
Zeee Forum Pro • Posts: 25,627
Check this thread out. I did several tests on how RF and EF lenses perform.
https://www.dpreview.com/forums/post/62814201
I feel even more confident that soon things will have a wonderful conclusion
 Zeee's gear list:Zeee's gear list
Canon EOS R7 Canon EOS R6 Mark II Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +1 more
Colin
I have been trying to find that answer.
lawny13 Veteran Member • Posts: 3,132
Colin
The IS on my 100L is loud. So is focusing. That goes for many EF lenses.
RF lenses are noticeably quieter, they are also smoother when focusing. So I definitely prefer nano USM over regular USM. Things change and technology advances. Canon likely uses a newer/better IS system than what they were using in the EF lenses. You mention battery... but I have not noticed any noticeable difference in battery live shooting a 50 stm lens mounted compared to the RF 24-105. The always on LCD or EVF draws way more power than IS. IS is like a drop in a bucket compared to the power drawing by those screens.
Yes IS does continue to run on an RF lens even if you shut the lens IS switch off. It does not stabilize but it does continue to run. So is this slopping around OK?
The only way to shut IS off with and FR lens is turn the camera off or wait for it to time out. First Display off has to cycle through followed by Auto Power off. The combined minimum is 45 seconds but the IS does shut off completely.
lawny13 wrote:
Colin
Yeah I agree - I don't think they'd do it if it were significantly contributing to battery consumption.  Maybe there is some optical benefit to having it run all the time - perhaps the alignment is better than mechanically locking it in place?
Mike Mulaw wrote:
lawny13 wrote:
Colin
We would have to have a closer looked at the design. "parking" electro-magnetic systems isn't as straight forward as many believe. Take the sony IBIS for example. The sensor floats due to the electro magnets. There is no moving part that comes up and touches the sensor. So parking the sensor means that the EM system is off, and since no mechanical part actuates towards it, that means that the sensor moves to position against something. That would imply that with the EM system completely off the sensor would no longer be in its intended focal plane. So when the IBIS of a sony body is off, the EM system no longer corrects for instabilities but it is still on keeping the sensor in the correct location along the optical axis.
I am not sure how the IS systems work in the lenses, but imagine what mechanically parking it entails. You can't move it along the optical axis since it would impair the image, by shifting focus for example. You can't push it off axis towards a mechanical component since this is the same as de-centering. So what then? 3 pins actuate towards the IS housing to hold it in place? Or perhaps an aperture like bladed construction narrows and clamps the housing in place? As you can see from my little thought experiment it isn't trivial. It also introduces additional complication and or mechanical systems thus introducing something else that can go wrong. From tear downs we also see that lenses are extremely cramped.
If leaving the IS group floating doesn't drain any noticeable amount of power simply letting them float instead of coming up with a mechanical way to park it is the more elegant way.
Mind you... I don't know how they park IS in EF lenses. I am curious to know.
RDM5546
RDM5546 Senior Member • Posts: 3,654
Your thought experiment of IBIS got me thinking. I have love the Canon optical stabilization and it has served me well for nearly twenty years for creating hundreds of thousands of images . Initially I was afraid of the possible leaks and fatigue failure in the liquid lenses under rough handling use in hostile environments through wide temperature and shock and vibration ranges. However, they have been used a lot jungles, desert, arctic and war-zone conditions with rough treatment with good success. I have two pairs of Canon stabilized high power binoculars that simply rugged and wonderful in operation as well. So I am convinced optical stabilization simply works well.
IBIS though seems a lot more delicate and I would not think the typical 1DX user have confidence in the robustness of IBIS stabilized bodies without a lot of similarly rugged field experience. I am not sure I want to be the first to test IBIS stabilized cameras in nasty hostile environments. Is IBIS as rugged as optical stabilization in the current cameras that are pushed to the environmental extremes? I might guess that extremes of shock, humidity and temperature could be very bad for an IBIS system. It is a miracle and somewhat beyond belief what some the existing optically lens stabilized systems have survived through.
I have EF stabilized lenses and five of them are RF lenses. But not
Many
Many of the RF lenses are already stabilized to 5 stops. I have a bunch of EF lenses that are not stabilized. IBIS might be nice for me it is not essential. At least at the moment I do not have an urgent need.
I would not like to add to body design if makes the mirrorless body more delicate or if it causes the body  to perform worse in auto focusing.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
