If you could have only 1 UWA
Started Jan 11, 2020 | Discussions
burritosandbeer Regular Member • Posts: 314
So I want to fill a gap in my lens selection, but my budget isn't allowing for a plethora of options.  Currently the widest lens I have is the 14-42 kit zoom from my G7.
I want an ultra wide-angle lens.
I want it for landscape
I want it for astro
I want it for interior/real-estate photography
I want it for architectural photography
I am likely to do environmental portraits with it as well
The current two contenders are
A used Panasonic 7-14 mm f/4
A new or used Laowa 7.5 mm f/2
My normal tendency would be to get the zoom, as it will give me a better chance to frame the shot from my position than a prime, and later get the prime if I still want it, but the difference in aperture is significant enough that for astro I don't know if the 7-14 will do the job.
Any one have both? If you could only have one what would be your choice?
The pro UWA zooms are out of the budget, I'm sure a 7-14 mm f/2.8 would probably solve both problems, but this is a fairly limited section of what I shoot, so while that may be true, the price difference places it too far out of reach for just a toy lens for me.
 burritosandbeer's gear list:burritosandbeer's gear list
Olympus PEN E-PL6 Panasonic Lumix DMC-G7 Panasonic G95 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS +7 more
3dwag
3dwag Veteran Member • Posts: 4,674
Re: If you could have only 1 UWA
I want it for astro
Perhaps you will find some ideas in this recent thread: https://www.dpreview.com/forums/post/63474954
-Dennis W.
Austin, Texas
¯\_|’_’|_/¯
http://www.pbase.com/3dwag/image/97156660.jpg
 3dwag's gear list:3dwag's gear list
Fujifilm FinePix Real 3D W3 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-GM5 OM-1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +19 more
DLBlack Forum Pro • Posts: 15,865
The Panasonic 7-14/f4.0 is too slow for astrophotography.   This will leave the Loawa 7.7/f2.0 lens.
Then again why did the Panasonic 8-18/f2.8-4.0  notl make your final list.
 DLBlack's gear list:DLBlack's gear list
Pentax K-7 Pentax K-5 Olympus E-M5 II Olympus PEN-F Olympus E-M1 II +46 more
Skeeterbytes Forum Pro • Posts: 23,186
Two stops is a lot while the zoom range convenience can't be replicated by a prime. Certain types of shooting favor autofocus and the workflow of open-focus-stop down-shoot is not for everybody.
Ultimately, your main uses can hopefully inform your choice. Astrophotography is probably the Laowa's trump card, because f4 is awfully slow for that.
Rick
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
If you are doing alot with uwa go zoom
if you are not doing a lot with uwa then prime should be ok.
if you need a wide aperture and zoom the 8-18 from panasonic may be a better choice.
for me I bought the f4 8mm from SLR magic, am happy with it due to low usage.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
OP burritosandbeer Regular Member • Posts: 314
In a word price... from the original post
"The pro UWA zooms are out of the budget, I'm sure a 7-14 mm f/2.8 would probably solve both problems, but this is a fairly limited section of what I shoot, so while that may be true, the price difference places it too far out of reach for just a toy lens for me."
john isaacs Veteran Member • Posts: 8,444
I want it for astro
If you want it for astro, get the Laowa.  If you want it for anything else, get the zoom
7.5mm is certainly wide, but for most of what you want to do, it's too wide.  I don't like going wider than 9mm for real-estate, most landscape, and definitely not portraits.  And you only have 16mp to work with, so you can't crop much.
So how much time do you spend doing astro?  You can always shoot stacks and merge them in post.
I would get the zoom and save for the astro.
Albert Valentino Veteran Member • Posts: 9,770
Huge difference between the two. Fast vs slower, prime vs zoom. I’m a zoom man myself and I also want a lens that is filter friendly for shooting things like water at long shutter speeds. So I went with the PL 8-18 and love it. I had to wait a year for the first sale, $200 off. Glad I did. It was a nice upgrade from my Oly 9-18  😃
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
Glen Barrington
Glen Barrington Forum Pro • Posts: 22,535
Could you expand a bit on why it was a nice upgrade?  I have the DSLR version of the 9-18, but will likely replace it with a native m43s lens.
 Glen Barrington's gear list:Glen Barrington's gear list
Olympus OM-D E-M10 II Olympus E-M5 III Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +11 more
epozar
epozar Senior Member • Posts: 1,969
PL 8-18!
great for a real estate but so far I haven't tried it for astro
 epozar's gear list:epozar's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Lumix DC-G9 OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 +10 more
The 9-18 is not renowned for sharpness, but it's still pretty good if you stop it down a bit. It is also the most portable UWA.
I have to say, with respect to filters, I have adapters for using filters on my UWA lenses (both Panasonic and Olympus).  I only use UV and ND filters on my UWA lenses, and I have adapters and filters for both of those lenses.  I only use filters for video and if I'm shooting in an environmentally challenged location (especially near waterfalls).  That said, if you think an adapter and filter would be needed, then the 8-18 is definitely worth considering. But it's costly, and you seem to be cost constrained.
First, it is wider and as with most ultra wide zooms we tend to use the wide end more. Converse is true with long zooms, they tend to get used more at the long end. Do not think of it as simply 1mm wider, think in terms if FOV and it is 9/8 percent wider which is noticeable. Second, the Oly 9-18 is pretty sharp at the wide end but just okay at the long end. PL is sharp across the range. Third, the Oly is slower and needs to be stopped down to get the edges sharp. So if you want sharp edges at 12mm you need to shoot at f/5.6. Lastly, I love to make sunstars when conditions are right and the Oly 9-18 renders terrible sunstars, not worth even trying. So in summary, the PL is faster, sharper across the range and edges, wider, and renders good sunstars. Laowa 7.5 prime does even better at sunstars.
Here is a thread I posted few weeks ago showing the PL 8-18 in NY city, 10 shots in the first post and a few more added in later posts. Many are at 8mm, and several are stopped way down to render sunstars, which softens a bit but that is the trade off. Judge for yourself, a picture worth a 1,000 words 😃
https://www.dpreview.com/forums/thread/4452931
Barry Twycross Veteran Member • Posts: 4,780
I did go for the 7-14, I rather like it. I was tempted by the Laowa, but I've decided I like autofocus.
For astro, the extra aperture would probably help, and the focus is not so much of an issue. For everything else, I'd go for the 7-14.
 Barry Twycross's gear list:Barry Twycross's gear list
Olympus E-PL7 Fujifilm GFX 50R Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Fujifilm GF 110mm F2 Venus Laowa 7.5mm F2 MFT +11 more
Gnine Senior Member • Posts: 4,108
Do it once, do it right. Buy the 7-14 2.8 or PL 8-18 & be happy. It's only a couple of hundred bucks. A few extra weeks of saving.
Kszchopstix Contributing Member • Posts: 527
Olympus fish eye 8mm f 1.8
If you ever upgrade to the latest Olympus bodies there is in body fish eye correction which lands you 7mm to 10 mm correction. Or just defacto fish eye 8mm which is wider than the 7.5mm
 Kszchopstix's gear list:Kszchopstix's gear list
Panasonic LX100 II Olympus E-M1 II Pentax KP Pentax smc DA 15mm F4 ED AL Limited Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II +12 more
929406 Regular Member • Posts: 285
I bought the Loawa 7.5 to compliment my existing 12-40 & 12-100 as I only use it occasionally when I want to go wide but 80% of the time for what I do, 12mm is wide enough.  The Loawa seems good and is so small I don't feel it when carrying it around
 929406's gear list:929406's gear list
Fujifilm X-Pro1 Panasonic Lumix DC-G9 Panasonic S1 Sony a7S III Sony a7C +18 more
Doom Scythe Regular Member • Posts: 286
Yup, a good option. The defish is a nice touch, but I am upset with the fact that Olympus does not extend the fish eye correction to older bodies like the E-M5 Mark II. Are they trying to say owners of older bodies won't buy the Fisheye lens?
 Doom Scythe's gear list:Doom Scythe's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 +5 more
Great Bustard Forum Pro • Posts: 45,641
Just throwing this out there, but...
I want it for astro
...what about a Sigma 14 / 1.8A? Use the bare lens (with an adapter) and you get a 14 / 1.8. Use it with a 0.7x FR, and you get a 10 / 1.3. It's a beast of a lens, no AF, and not inexpensive, but it's sharp and fast as hell.  It has a lot of distortion on FF, though, but when the bare lens is used, since you're cropping out the middle 25% of the image circle, it should be OK.  But when used with the 0.7x FR, that might be an issue.  Might correct really well in software, though.
Messier Object Forum Pro • Posts: 12,724
Re: Just throwing this out there, but...
I want it for astro
why no AF, doesn’t it work with a Viltrox or Metabones adapter  ?
Peter
 Messier Object's gear list:Messier Object's gear list
Nikon Coolpix 990 Olympus C-5050 Zoom Olympus E-300 Olympus E-330 Olympus E-30 +31 more
I want it for astro
I most likely misspoke -- I don't know it can AF with the adapter. It's an AF lens, so I suppose it should, right?  Anyway, given that it does AF, that would definitely strengthen my recommendation!
