75-300 is horrible
Started Jan 6, 2020 | Discussions
Max5150 Senior Member • Posts: 1,055
Re: 75-300 is horrible
I'd say your sparrow shots are better than what I normally get from my PL50-200
ChrisWal Contributing Member • Posts: 538
Phocal wrote:
I will end this with a photograph that made me a believer in the dual IS, something I wasn't excited about when I got the 300/4.
Handheld at 1/50 is something not possible without dual IS, especially at an effective 600mm focal length.
my 2 copper pieces,
Phocal
Thanks Phocal for the tutorial and examples. Hopefully they will help me to get better results next time I venture out with my 75-300.
Chris
 ChrisWal's gear list:ChrisWal's gear list
Olympus OM-D E-M10 II Olympus E-M1 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +11 more
Phocal
Phocal Veteran Member • Posts: 3,528
my 2 copper pieces,
Phocal
Chris
Glad you found it helpful.  If you have any other questions don't hesitate to ask.
 Phocal's gear list:Phocal's gear list
Olympus Zuiko Digital ED 150mm 1:2.0 Olympus M.Zuiko 300mm F4 IS Pro Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake +6 more
tedolf
tedolf Forum Pro • Posts: 29,547
Re: Also oversharpened....
MannyV wrote:
tedolf wrote:
MannyV wrote:
I now have the Panasonic 100-400. Before that my primary lens for telephoto was the 75-300. I did not sell that lens. It more than met my needs. Some lower res photos from my archives from 4 years ago. I am not sure whether the exif details are preserved. Later I will post some images captured at 300mm when I find them in my archives.
I have still kept this lens as a lightweight backup option. To be honest though - since the 100-400, I have almost never picked up the lens as the extra of the Panasonic lens makes it worth carrying. Having said that I will not sell my Olympus 75-300mm.
This one also shows sever sharpening artifacts. I am wondering if there is some in camera processing that is done with this particular lens that causes this problem.
I am not seeing it as much in the other shots so I am baffled.
tEdolph
Could it be you are pixel peeping a low res photo?
Dunno, you tell me!
tEolph
 tedolf's gear list:tedolf's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Samyang 7.5mm F3.5 Fisheye +9 more
Messier Object Forum Pro • Posts: 12,721
Re: I disagree
EZGritz wrote:
If I look at something through my binoculars 20 yards away the subject moves a lot less than the subject I look at 100 yards away.
I still think distance is part of the formula.
What are you looking at ?
If the  subject takes up only a small portion of the field of  view it will seem to be moving a lot more, eg a seagull on the water 50 yards away compared with an ocean liner 1/2 mile away.
How about a soccer ball 20 yards away compared with the moon - about the same angular size. Does the moon jump around wildly in the view through your binoculars compared to the ball ?
Peter
 Messier Object's gear list:Messier Object's gear list
Nikon Coolpix 990 Olympus C-5050 Zoom Olympus E-300 Olympus E-330 Olympus E-30 +31 more
EZGritz
EZGritz Senior Member • Posts: 6,285
Re: I disagree
The lettering on a mailbox 25 yards away moves an inch or two. The lettering on a pole 100 yards away moves a foot.
Looks to me stabilization is more demanding for lettering on the poll so if camera stabilization is the same shutter speed has to be higher.
I posted examples of a hummingbird shot at 1/50 from a few yards away. I needed 1/250 to shoot a woodpecker 50 yards away.
Same camera, same lens. EM-1 MKII 75-300.
A real world example, not a theory. I think distance is part of the formula.
 EZGritz's gear list:EZGritz's gear list
Olympus E-M5 III OM-1 Olympus Body Cap Lens 15mm F8.0 Olympus M.Zuiko Digital 17mm F1.8 Olympus M.Zuiko Digital 25mm F1.8 +7 more
TomFid Veteran Member • Posts: 3,999
Re: Subject distance and blur
EZGritz wrote:
I think you are right I took a lot of these that day because the hummer cooperated. It liked that branch, perched there for a long time had no fear of me standing a few yards away.
I like that shot a lot.
Looking through them, shutter speed did not seem to matter a great deal even at 1/320. The weird effect is still in the images taken with the 75-300. It is not in the images taken with the 40-150PRO and the 1.4XTC.
The two lenses are treating the background out of focus objects differently. Any idea why? Just a difference in bokeh?
There's a useful article about tech origins of bokeh differences here:
https://www.imaging-resource.com/news/2018/02/14/new-bokeh-champs-olympus-cracks-code-beautiful-bokeh-m-zuiko-f1.2-pro-prime
Re: I disagree
The angular size of a foot at 100 yards is the same as 3 inches at 25 yards, so these may actually be identical behaviors.
Setting aside macro, where lateral motion matters, the blur you see is due to the distance a point of light traverses across the sensor during the exposure. That is proportional to the exposure time and angular velocity of the camera/lens. Distance doesn't enter into it.
However, if you're talking about the same object at 10 yards or 100 yards, then the size of the motion blur relative to the size of the object will be 10x larger at 100 yards, simply because the object is smaller.
Similarly, if you zoom in to make the more distant object appear as large as the near one, the stabilization problem gets harder. The minimum viable shutter speed will inevitably go up.  The number of stops of improvement provided by stabilization may not change much, because the unstabilized minimum viable shutter speed also goes up (i.e. the 1/FL rule).
EZGritz
Thanks I'll read the article.
JaKing
JaKing Veteran Member • Posts: 6,300
It's very well worth reading. I've just read it again.
I suspect, but don't know, that Olympus might have used the 12-100 as a test bed for these designs. It also has beautiful focus transitions.
Prunus blossom - f/4 12-100 at f/11 and 35mm
br, john, from you know where
My gear list and sordid past are here: https://www.dpreview.com/members/1558378718/overview
Gallery: https://www.canopuscomputing.com.au/zen2/page/gallery/
 JaKing's gear list:JaKing's gear list
Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Olympus 12-100mm F4.0 Olympus E-1 +29 more
EZGritz
Another reason I suppose the 12-100 is so highly regarded. I find f/4 a sweet spot in the M43 system. Most of the time its fast and bright enough.
This lens is a little heavy for me to spend a day with on an OMD body, but the EM5.3 makes it possible.
EZGritz
Re: I disagree
Where was I? 3 yards from the bird, 5 yards form the branch? How does that translate for you?
JaKing
Agree.
Awe, come on now ...
I'm old, and just about completely f****d, but even I can carry my E-M1 MkII + 12-100 around all day ...
EZGritz
I'm 68 135lbs, yeah I can do it but I don't want to. If I go for an all day hike, no fun and don't need it.12-40PRO long enough. 12-60 Panny fast enough and way lighter.
A motorsports event in the desert, 4 days of hiking 5 miles a day up and down hills in 90 degree heat and full sun, nope. Not long enough. 12-40PRO, 40-150PRO + 1.4XTC, maybe 2XTC one day, 75-300, 45 and 75 optional.
I can shoot the entire event with the 40-150PRO and the TC. Backup camera has the 12-40PRO or the Panny 12-32 or 12-60, rarely used, just to lighten up for a while so I'm not shooting the 40-150PRO all day.
12-40 or 12-60 or a prime for street photography.
The 12-100 doesn't fit my needs. Longer than I need most of the time, too short for motorsports, not good for hiking.
For general vacation travel I like the 14-150. Not as good a lens, not as bright. I take the 17 f/1.8, or the 17 f/2.8, a more comfortable carry. Pretty light on a PL/7 or EM-5.2 with or without the grip.
EZGritz
I see what you mean.
EZGritz
I might like a 12-45 f/4
Boss of Sony Senior Member • Posts: 2,425
BWfoto wrote:
I really have come to despise this lens. Especially zoomed out where I always shoot it. Took these today and the lens is so soft. I will fix that in a couple weeks when I drive to Seattle I will pick the 300 f4 up while there . These two shots where from today and I have cropped in post. Also adjusted the shadows and color saturation. Raw file edited in IPad Pro Lightroom
1. When shooting at 300mm, always shoot at f7.1, not f6.7.
2. 1/100 is pushing it even with IBIS. I would try to stay 1/200 or above.
3. Edit your RAW files with DXO Photolab. The prime noise reduction combined with the lens sharpness profile will give you much more detail.
 Boss of Sony's gear list:Boss of Sony's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 9mm F8 Fish-Eye Body Cap Lens
rsf3127 Regular Member • Posts: 413
NO.
I have already showed you it is not.
500 meters away. Windy weather. AF-c + Tr. Heavily cropped.
 rsf3127's gear list:rsf3127's gear list
Sony Alpha DSLR-A700 Olympus Air Olympus OM-D E-M10 II Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
traveler_101 Senior Member • Posts: 2,203
Raucous Raven wrote:
That was my experience with the lens as well. I've seen people get sharp photos from it but the one that I briefly had performed more like yours. It was very clearly optically inferior even to the inexpensive Olympus 40-150mm F4-5.6 R that I tested it against. I think, as others have speculated, that there's a lot of variability in this lens.
Complaints about this lens go back for years. Higher ISO to achieve faster shutter speed helps at the cost of a bit more noise, but . . .
 traveler_101's gear list:traveler_101's gear list
Olympus PEN E-P1 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
JosephScha Veteran Member • Posts: 7,249
Re: NO.
Only 11 more messages to go after this one before this thread is full.  I am looking forward to that.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
