pannumon wrote:
Phocal wrote:
I also want to mention here since I have seen a few reference in this thread about IBIS not being effective at these long focal ranges. Olympus IBIS is fine at 300mm and even longer. Is it as good as dual IS? No, not even close but that is a different animal.
So how good is Oly IBIS at 300mm? You recommend around 1/600s shutter speed with IBIS at 300mm handheld. If "fine IBIS" would be worth of 4 stops, then without IS the requires shutter speed should be 1/9600.I
I believe that IBIS can stabilize the image in the viewfinder, but not handle 1/600s shutter speeds. This would explain why we time to time see sharp handheld shots at 300mm at 1/50s in this forum. This is well on the specified about 5 stop stabilization (even when assuming a safe 1/1200s shutter speed requirement without stabilization).
Ok...………………..
First off...…………………..
They are getting that initial number from the old (from film days) standard of 1/focal length? There are a lot of people out there (with some data to support) that believe the old formula doesn't apply to the new pixel dense sensors we have now. Which will require a higher shutter speed to handhold without IS/IBIS. I admit to not really digging into this, but in theory it makes sense. Which also brings up the sensor itself. If this idea is in fact true, than a m4/3 sensor which has a higher pixel density than a full frame sensor would require an even faster shutter speed for "the formula"
Oh, the formula…………………...
The entire 1/focal length was just a rough starting point. It has never been anything scientific. It was probably started by long time photographers who had skill and good technique to begin with. So it wouldn't apply to someone with no experience with cameras, especially with telephoto lenses.
Regardless, it is the formula they use in the standard. So at least you can somewhat compare the standard across a brands, to an extant.
Also...……………….
The standard used is CIPA DC-011-2015 if you want to dig into it.
But...………………………….
You also have to take into account the weight of the equipment when in actual use. The CIPA standard doesn't take this into account when testing. Because it does make a difference and I did mention this in my post. I guess you either missed it or need to work on your reading comprehension.
The 75-300 is extremely light, which makes it difficult to handhold. Weight serves the function of helping to stabilize you by not letting those micro movements (muscle or just from breathing) when standing there in the shooting position (camera or rifle) move the camera/rifle.
I have been a life long rifle shooter, use to compete but it has been a number of years since I do that (but I still shoot every chance I get). I have super steady hands and can handhold a lot slower shutter speeds than most. So my numbers are meaningless to most people on this forum as a reference.
But...……………...
I can handhold my 150/2 w/ EC-20 at significantly lower shutter speeds than the 75-300. Even the much heavier Sigma 50-500 is easier to handhold at 300mm than the 75-300. He11, it is even easier to handhold the Sigma at 500mm than the 75-300 at 300mm.
You can test yourself by getting multiple lenses that will get you to 300mm and shoot them side by side.
Finally...…………………..
The numbers I recommended are for people like the OP who are not use to shooting telephoto and have poor technique. With practice the number can go lower, but a person has to want to work on it and get better.
Oh...…………………………..
I didn't even get into how you press the shutter button, which makes a huge difference in the outcome. Especially at slower shutter speeds.
