75-300 is horrible
Started Jan 6, 2020 | Discussions
Gary from Seattle Veteran Member • Posts: 7,852
Re: 75-300 is horrible - there is a reason you are terrible
Terrible Photographer wrote:
Totally, the 75-300 Oly is a disaster. Honestly I can’t believe they even approved its release based on its slow 6.3 aperture in combination with its unacceptable image quality.
worst part is when it was released, it was something like $900......
Show images you have taken with this lens at a high file size. Back up your words.
 Gary from Seattle's gear list:Gary from Seattle's gear list
Olympus E-M1 Olympus E-M1 II Olympus OM-D E-M1X Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 +7 more
JimH123 Veteran Member • Posts: 3,886
Re: 75-300 is horrible -- Actually images had a lot of noise
I have been reading the other posts with speculation that there was a problem with technique or some other reason that the images were not as good as expected.  From what I see, there was no deficiency in technique.  There was not a problem with camera shake nor a problem with focus.  The main issue I see is noise, plus a little CA in the bald eagle image which was correctable.
If this had been taken with the 300mm f4, the f4 aperture would have allowed more light for the image and likely would have solved the noise problem.  The 75-300mm lens had noise because the light situation was not optimal and it is a slower lens.  Probably overcast that day.
I really don't think the OP was doing anything wrong.
 JimH123's gear list:JimH123's gear list
Nikon Coolpix P1000 Sony RX100 VII Olympus E-M5 II Sony a6300 Olympus E-M1 II +2 more
Re: 300mm f4 better than 75mm 1.8 even
BWfoto wrote:
When I pick up the 300mm f4 I will go back out and shoot the eagles again. It will be interesting to see the difference. I absolutely love what my 75mm f1.8 gives me IQ wise and the reviews I see of the 300mm f4 are saying it is even sharper.
Could you possibly post the otiginal RAW images.  One easy way to do this is to use www.wetransfer.com and have it email the link back to yourself,  Then paste the returned link into a reply.  Wetransfer keeps the files for 7 days and then purges them.  Allows up to 2GB to be sent free,
I would like to see what DxO Prime can do with these images.
Re: 75-300 is not horrible
NCV wrote:
The fact that some people manage to get lovely sharp pictures with this lens tells me that most of the poor results are a user error problem.
Exactly. I originally owned the 100-300 V1 and thought there was no way I could shoot birds in flight, so I switched to the 75-300 and it was about the same. I got pretty poor results….but sometimes got a very sharp one. The lens is as good as the best image from that lens; the rest is user error. You have to be astute in handholding, and at selection of ISO, aperture, and SS, as well as of exposure. I am still not. But I am much better than when I first tried birds. The other way user error shows up is that if I shoot several shots, they vary in IQ. That is not the lens.
My Panasonic 100-300 gives me superb results when I am careful with my technique.
The 100-300 v2 as I understand it used with a Panasonic body would have better stabilization. But, my new EM-1 II is much better at focusing and IBIS than my old EM-1 I.
EZGritz
EZGritz Senior Member • Posts: 6,285
It needs a lot of light. In bright light it can produce an image surprisingly close to my 40-150PRO. For motorsports on sunny days, its a good lens.
For low contrast, mediocre light outdoors in the Pacific Northwest on gloomy/rainy days in winter - no. Not good for that.
 EZGritz's gear list:EZGritz's gear list
Olympus E-M5 III OM-1 Olympus Body Cap Lens 15mm F8.0 Olympus M.Zuiko Digital 17mm F1.8 Olympus M.Zuiko Digital 25mm F1.8 +7 more
EZGritz
You will be pleasantly surprised when you can shoot f/4 vs. f/6.7 at the same FL on a gloomy day. It will enable you to shoot a faster shutter speed/lower ISO in our poor PNW light. Makes a huge difference for what you are doing.
The speed of the lens makes all the difference.
F/4 is pretty sweet on MFT I find when I use the 1.4X on the 40-150PRO, but I have to say for gloomy/rainy days f/2.8 is noticeably better.
In the example - see how wet the leaf is and how much this is cropped. Very gloomy/rainy day. With this much detail after so much crop I wonder if 40-150PRO at f/2.8 cropped to match field of view will produce as good an image as the 300f/4? It will not produce as good a big print would be a guess. I'd rather frame it bigger anyway so I can see what I'm photographing. Lower ISO = more detail every time I tried it as long as shutter speed is high enough.
Faster glass and lower ISO is usually better in my experience. That is the benefit of PRO lenses I see.
This photo shot in the rain/gloom as you can see, 1/80 to keep the ISO to 200. Dual IS will be even better with the 300 f/4 PRO and an EM-1.2 or 1MX. If you can stay at ISO500 or better.
EZGritz
5
Not always horrible. Gloomy day. 75-300 at 300/6.7 ISO2000, wide open.
EZGritz
A good photo from the 75-300 on a gloomy/rainy PNW day. Not too terrible.
EZGritz
Re: Sample variation
I've had good luck with this lens at f/6.7, 1/80 and max extension with light low enough to require ISO2000. Images are sharp. Posted one in this thread. IBIS on EM-1.2 good enough for that at 300mm with 75-300.
With 40-150PRO, same light = 1/125 and ISO200. Crop 100% = similar IQ to 75-300 but lower resolution with 40-150PRO.
For monitors and prints up to 13X19 = results very similar at photo/monitor viewing distance.
75-300 can be surprisingly good on an EM-1 MKII with firmware 3.0 because higher ISO can compensate for slower aperture. In bright light even closer when both lenses are shot at the same aperture.
I think its a matter of settings to make this lens perform.
EZGritz
Re: 75-300 is horrible - not
Me too. That's why I hesitate to replace the 75-300 with the 2XTC.
EZGritz
Yes for wildlife better when you can get close, but for motorsports in good light, 75-300 is very good at long distance. 50-100yds it works very well for me.
HRC2016 Veteran Member • Posts: 6,874
Pleased with my 75-300
This is false. Bad copies are an issue in lenses, including this one presumably (given it's price point).
I have this lens and it's very good in the right circumstances and conditions. Well worth its price to me.
Trying to diagnose a problem online is very challenging. I think to attribute problems with a non-Pro lens solely to fieldcraft is an insult to the photographer.
I believe in science, evolution and light. All opinions are my own. I'm not compensated for any of my posts. Can you honestly say that?
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
mchnz
mchnz Senior Member • Posts: 1,949
cangopluto wrote:
mchnz wrote:
I find my 75-300 appears to be in the same ballpark as my 40-150 f/2.8 with the MC-20.
I get plenty of misses due to shake and movement from all my 300 mm lenses, the 75-300, to 40-150+MC-20, and the 300 f/4. Of course there are likely to be bad copies of lenses out there, but hand held 300 mm in m43 is a challenge.
good examples, but you shoot close. People that often complain, often shoot big birds afar. Zoom with the feet.
Shooting at longer distances multiplies small amounts of shake and movement.  If attempting a severe crop at long distances, that acts as a second multiplier.   Combined these multipliers act not only on shake/movement, but also on focus/depth-of-field accuracy.  The result being that results at longer distances are often mush.  If you look at many long distance captures, either still or BIF, people are often posting at around 1280x720 or less, that helps to hide the mush.
A decent tripod and gimbal might help with long distance shots.  That's what non-m43 people seem to do.
Hand held, if you can't get close, don't bother, or shoot for luck and memories.
john isaacs Veteran Member • Posts: 8,440
You may have a horrible copy.  Generally, the lens is soft at 300mm, but is better below 250.  Where it is actually good needs to be tested for each particular lens.
Also, the lens is generally soft wide open.  Which means shooting at f/7.1 or f/8.  Not very flexible, and ISO and shutter speed have to be used to control exposure.
Most reports I've read encourage use of electronic shutter.  I do.
Shadowfixer Senior Member • Posts: 1,769
In my experience the lens is a pretty decent lens. I do however back it off to about 270 mm when shooting. I hade to do the same with my old Nikon 80-400. I always shot it at about 350mm. One can be stubborn and insist on shooting it at 300mm because by golly that's what the bought or they can do the wise thing and back it off a hair and get some darn good images. Some here have their minds made up about this lens being horrible so it's pointless to argue with them. I just know that I get some pretty good results with this lens.
 Shadowfixer's gear list:Shadowfixer's gear list
Olympus E-M1 II Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Pro Olympus 9mm F8 Fish-Eye Body Cap Lens +1 more
Walt_A Senior Member • Posts: 2,136
Re: 75-300 examples
Hi, I've used the 75-300 mkii quite a lot for wildlife over the years on EM10, EM10 mkii and EM1. Using the EM10, both versions, I've really enjoyed the lens and have some good results. When used on the EM1 it's so variable, I've tried as many options as possible, electronic shutter, fast shutter speed etc but I get quite a few rejects like yours. However I still get some sharp, IMHO, ones as below:
This is an uncropped raw converted to jpeg using no sharpening or pp at all
Here's the above cropped
The above cropped and lightly sharpened
I gave up trying to get consistently sharp shots with it on the EM1 and now only use it on the EM10 mk ii or Panasonic G9 an example of it here:
I have never used the EM1 mkii but just thought I'd add my experiences to this thread.
TomFid Veteran Member • Posts: 3,999
Chris R-UK wrote:
Mark Ransom wrote:
When I see results like yours, I wonder what's wrong with my 75-300? My experience is more similar to the OP's.
Does this lens have more sample-to-sample variance than most others?
I think that it does. Threads like this one are much more common for the 75-300mm than, say, for the Panasonic 100-300mm.
I'm not sure you can read too much into that, given differences in ownership.
I certainly had a bad copy of a 75-300mm which, after a lot of grief, I finally put on a tripod and tested very thorough at a bird reserve.
I think this is what the OP needs to do. I get sharp images from the long end of mine (and previously, from the 100-300) if I'm careful. So I look at these samples and immediately suspect a combination of tough lighting and operator error. If the OP sticks the lens on a tripod with e-shutter in good light at ISO 200 and still gets fuzzy shots, then I'd blame sample variation.
mchnz
BWfoto wrote:
Yes when you add the adapter which makes the 40-150 images worse you might be able to compare the two. Try it without the converter and see which provides a better image. It will be interesting to see how the 300mm f4 with its own stabilization combined with the EM1.2 IBIS and faster Aperture works.
Agreed, the 40-150 f/2.8 without any teleconverters is at a different level, and it's much the way I prefer to use it. Because this forces me to closer the sharper results are also often very cropable (not only due to sharpness, but also due to less magnified shake).
The 300 f/4 definitely delivers more detail than other 300mm solutions. I still think it requires excellent hand holding technique. At longer distances I'm still mostly seeing results that are more mushy than I would find acceptable - I normally like to crop and resize to at least 1600x1200. Early days though. It would be interesting to try a tripod/monopod.
At closer distances 300 f/4 (at f/4) requires a more careful selection of focus targets, it is no longer acceptable to focus on the birds body, I must target the eye. I suspect I should default it to f/8. Very sharp and contrasty results.
I bought a second hand 300 f/4. The retail price on the 300 f/4 is a step too far for me.  Otherwise I would have stuck with the 40-150 f/2.8 (without TC) and the 75-300.
I wonder whether a Panasonic 200 mm solution might be the sweet spot for people having trouble with hand holding 300?
mchnz
Yes Electronic Shutter is an absolute must, it does really seem to lift the keeper rate.
n3eg
n3eg Veteran Member • Posts: 3,316
Re: 75-300 is adequate
Most of the problems I have are because it is f/6.7 - and I saw diffraction after f/5.6 with my 16 MP sensors.  Probably slightly worse on the E-M1 II and E-M5 III at 20 MP.  Now that I have a 4/3 70-300, I'll have to compare the two - although I still got adequate sharpness with the 70-300 and a 1.4x TC at f/7.9.
It ain't easy being me, but someone's gotta do it.
 n3eg's gear list:n3eg's gear list
Kodak DCS Pro 14n Olympus PEN E-PL5 Panasonic Lumix DMC-GM1 Kodak Pixpro S-1 OM System OM-5 +73 more
