75-300 is horrible
Started Jan 6, 2020 | Discussions
Phocal
Phocal Veteran Member • Posts: 3,528
Re: E-M1 Mark II : AF Focus adj
HowdC wrote:
I found the 75-300mm F/4.8-6.7 II soft at 300mm & used AF focus adjust that’s provided on the Olympus E-M1 MKII.
When I first got the lens I checked the focus in manual mode using a tripod targeting at different distances. Close too it was ok but above 280mm it became unsharp.
Fortunately with the E-M1 Mark II its possible to adjust for this deficiency.
AF Focus Adjust found at menu * A3 - 4
I had to adjust mine to +2 for it to be very sharp at 300mm.
You do know that the adjustment is only applied to CAF.  In SAF it has zero effect.
Also I use the largest jpeg image possible which is LSF mode (5184 x 3888) pixels when not using RAW.
This critter refused to move round the tree into the sunshine but nevertheless the feather detail is ok even in the shade.
 Phocal's gear list:Phocal's gear list
Olympus Zuiko Digital ED 150mm 1:2.0 Olympus M.Zuiko 300mm F4 IS Pro Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake +6 more
mchnz
mchnz Senior Member • Posts: 1,949
Re: 75-300 is horrible - not
17
I find my 75-300 appears to be in the same ballpark as my 40-150 f/2.8 with the MC-20.
One out of the camera
100% crop (and through a window).
I get plenty of misses due to shake and movement from all my 300 mm lenses, the 75-300, to 40-150+MC-20, and the 300 f/4.  Of course there are likely to be bad copies of lenses out there, but hand held 300 mm in m43 is a challenge.
Chris R-UK Forum Pro • Posts: 22,843
Sample variation
Mark Ransom wrote:
When I see results like yours, I wonder what's wrong with my 75-300? My experience is more similar to the OP's.
Does this lens have more sample-to-sample variance than most others?
I think that it does.  Threads like this one are much more common for the 75-300mm than, say, for the Panasonic 100-300mm.
I certainly had a bad copy of a 75-300mm which, after a lot of grief, I finally put on a tripod and tested very thorough at a bird reserve.  It was excellent up to 200mm but very poor indeed between 250-300mm.  Many other owners have posted very sharp images from the longer end, so I think that this lens does have a lot of sample variation.
Chris R
 Chris R-UK's gear list:Chris R-UK's gear list
OM-1 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +4 more
Phocal
BWfoto wrote:
I really have come to despise this lens. Especially zoomed out where I always shoot it. Took these today and the lens is so soft. I will fix that in a couple weeks when I drive to Seattle I will pick the 300 f4 up while there .
I don't think you will see much improvement in your images.
These two shots where from today and I have cropped in post. Also adjusted the shadows and color saturation. Raw file edited in IPad Pro Lightroom
tpani
tpani Regular Member • Posts: 332
8
You need enough light.
I had the Pana 45-200mm, the Pana 45-150mm, and I still have the Oly 40-150mm f/4-5.6. I just bought the Oly 75-300mm. Wide open (f/6.7) at 300mm it is much sharper than my 45-200mm Panasonic was, and it is at least as good or better than the other f/4-5.6 telezooms I have tried.
I bought the lens because I wanted a long one (much longer than the small 35-100mm I was using for non-nature photography in the last two years), and a small one, and this is currently the only long tele that is "small" by some standards. (My next biggest lenses that I regularly use are the tiny 35-100mm and the 9-18mm, both of which are much much smaller. In comparison to those lenses this lens is huge.)
I was trying to be very "realistic" about the potential of the lens (I paid 370 euros for it new), and managed to be positively surprised. Of course, it is not as sharp as a sharp (short) prime or an expensive tele, but it is quite good (given enough light.)
This is a spotted dove I photographed in Jakarta one week a ago. I like the result. This is very close to the OOC JPEG from GX85. The corrections with SilkyPix is mostly just white balance (and crop: I shot it first at 16:9 aspect ratio, missing the tail of the bird.)
 tpani's gear list:tpani's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G6 Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 +11 more
(unknown member) Forum Pro • Posts: 11,837
Re: 75-300 is not horrible
17
The fact that some people manage to get lovely sharp  pictures with this lens tells me that most of the poor results are a user error problem.
My Panasonic 100-300 gives me superb results when I am careful with my technique.
pannumon Veteran Member • Posts: 4,130
Re: Sample variation
I think that most 75-300mm users use Olympus, which means IBIS-only. IBIS loses it's efficiency at such very long focal lengths. At very long focal lengths, there are all kinds of unpredictable micro-vibrations. These can be related to specific camera bodies as well (not to mention the effect of camera grips).
Panasonic 100-300mm was also complained to be soft at 200-300mm. Then a tripod mount came out (out: http://www.roesch-feinmechanik.de/29701.html) and people started getting better results, even if they were using a tripod before! I think the 100-400mm lens fits so tight to the bayonette, because this way the lens and the camera won't have separate vibrations (this would be tricky to fix with IS).
When I got my G7, I started shooting with electronic shutter with my 100-300mm and was became pretty happy with the lens (unfortunately I don't have that lens anymore).
In conclusion, at 300mm focal length (equivalent of 600mm), many other factors than lens optics can make the photos soft.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
magnesus3 Contributing Member • Posts: 642
As long as you use electronic shutter the IBIS in newer Olympus bodies is enough even at 300mm. Usually subject movement (birds rarely stay still) is a problem sooner than IBIS not being able to keep up.
martinhb Contributing Member • Posts: 800
Good point, thank you Phocal for making that clear.
 martinhb's gear list:martinhb's gear list
Canon PowerShot G1 X Panasonic Lumix DMC-G3 Olympus E-M1 II Panasonic Leica D Vario-Elmar 14-150mm F3.5-5.6 Asph Mega OIS Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +3 more
DavidBrother
DavidBrother Regular Member • Posts: 138
I had the same experience, and I sold it(very cheaply, as I didn't want to rip anyone off).
A bit after, I checked it out at DX0mark, and I found all the criticism is valid. Buy another lense, either heavier, or shorter focals to achieve more sharpness.
(anyone discussing this lens, should check out this sharpness diagram. 'Sharpness: 5' (out of20)
https://www.dxomark.com/Lenses/Olympus/Olympus-MZUIKO-DIGITAL-ED-75-300mm-48-67-mounted-on-Olympus-OM-D-E-M1-Mark-II---Measurements__1136
 DavidBrother's gear list:DavidBrother's gear list
Sony a7R II Sony a7 IV Canon EF 50mm f/1.2L USM Sigma 105mm F2.8 EX DG OS HSM Sigma 24mm F1.4 DG HSM Art +3 more
I tested my 75-300mm very thoroughly both on a tripod and hand held, electronic shutter and mechanical shutter and different focal lengths.  The image quality was excellent up to 200mm but deteriorated rapidly over 250mm.  At 300mm it was simply unacceptable.
I shot for three years with a Panasonic 100-300mm Mk1 on a GH2 and that was capable of producing extremely sharp images at 300mm.  The only problem was that it wasn't usable for BIF once because it didn't support AF-C at shooting rates above about 2.5 fps.  I now wish that I had kept it for single shot photography only
Chris R
(unknown member) Senior Member • Posts: 1,505
good examples, but you shoot close. People that often complain, often shoot big birds afar. Zoom with the feet.
kohinoor Senior Member • Posts: 1,774
Yes, at f22 the sharpness is 5 out of 20.
You bought the lens exclusively for macro work?
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
Correct: often it is user error
5
As I already showed in my earlier reply I too have wonderfully sharp pics and blurry ones, and the blurry ones are due to user error: shutter speed too low, no anti-shock used, panning not in sync with subject (in case it is moving), motion blur, etc.
Note that the lens only needs to give you one razor-sharp image to know it's not likely the lens that is at fault for the blurry images.
Getting to know the Olympus OM-D E-M5 II.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
JimH123 Veteran Member • Posts: 3,886
Re: 75-300 is horrible -- Actually images had a lot of noise
BWfoto wrote:
I really have come to despise this lens. Especially zoomed out where I always shoot it. Took these today and the lens is so soft. I will fix that in a couple weeks when I drive to Seattle I will pick the 300 f4 up while there . These two shots where from today and I have cropped in post. Also adjusted the shadows and color saturation. Raw file edited in IPad Pro Lightroom
I took a look at your two images and found that there was a lot of noise.  Also, the golden eagle did have some CA also.  I have taken both images and downloaded them and treated them with Topaz Denoise AI, and the look is entirely different.  If I had access to the originals, I suppose the fix could even be better, especially if they were taken in RAW.  And if RAW, I would have tried DxO Prime Noise Removal.
I also happen to have the Olympus EM1ii and the 75-300mm lens, and I also lust after the 300mm f4 lens.  But the 75-300mm images can be improved.  But in this case, there was considerable noise to contend with.
I also have a Sony A7iii, and if I were to use equivalent settings, there would have been less noise.  But with a m4/3 camera, noise is something we have to deal with.  A 300mm f4 with the same settings would also had the noise too.
 JimH123's gear list:JimH123's gear list
Nikon Coolpix P1000 Sony RX100 VII Olympus E-M5 II Sony a6300 Olympus E-M1 II +2 more
BWfoto
OP BWfoto Regular Member • Posts: 322
300mm f4 better than 75mm 1.8 even
When I pick up the 300mm f4 I will go back out and shoot the eagles again. It will be interesting to see the difference. I absolutely love what my 75mm f1.8 gives me IQ wise and the reviews I see of the 300mm f4 are saying it is even sharper.
Go ahead shoot...... film
BWfoto
It simply sucks at 300mm where I shoot it most. I have even put it on a tripod to make sure and it still sucks. I haven’t seen a photo yet from anyone that shows any different.
BWfoto
Yes when you add the adapter which makes the 40-150 images worse you might be able to compare the two. Try it without the converter and see which provides a better image. It will be interesting to see how the 300mm f4 with its own stabilization combined with the EM1.2 IBIS and faster Aperture works.
BWfoto
I am going to spend the money and pick up the 300mm f4. I love my Oly primes they have all been amazing and the 300 f4 is supposed to be better than my 75mm 1.8 . which I find incredible if true
Jerry_JMK Regular Member • Posts: 308
Re: 75-300 is horrible - do not think so...
I am quite satisfied with the results. Shot attached on the e-m1 mark II
