75-300 is horrible
Started Jan 6, 2020 | Discussions
BWfoto
BWfoto Regular Member • Posts: 322
75-300 is horrible
I really have come to despise this lens. Especially zoomed out where I always shoot it. Took these today and the lens is so soft. I will fix that in a couple weeks when I drive to Seattle  I will pick the 300 f4 up while there . These two shots where from today and I have cropped in post. Also adjusted the shadows and color saturation. Raw file edited in IPad Pro Lightroom
Go ahead shoot...... film
jh2bh Contributing Member • Posts: 830
Re: 75-300 is horrible
11
Perhaps you are expecting too much from that lens, and from IBIS.
Many zoom lenses lose some sharpness at maximum focal length.  Shoot some at about 275-280mm and see if that doesn't improve your results.    Also try increasing your ISO setting to the point where your shutter speed is twice, or more, than the focal length.
JosephScha Veteran Member • Posts: 7,249
I have the Panasonic 100-300mm and although it will not challenge the 300mm f/4 in sharpness or brightness at 300mm, I agree with your assessment: those pictures are noticeably soft.  If you do go for the 300mm f/4 I suspect it will make you happier.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
Gintaras B. Senior Member • Posts: 1,263
75-300 is a very sharp lens
18
I do use my E-M1 II and mostly for planespotting. And I'm very satisfied with as being just an amateur photo enthusiast. Once another planespotter, who shoots with Canon told me once: "Olympus lenses are known as very sharp from long ago". Camera division is not main business for Olympus. Medical equipment is and Olympus lenses might be very sharp because Olympus produces very good Microscopes. I'm waiting for Olympus 100-400 to come out
Mark Ransom
Mark Ransom Veteran Member • Posts: 8,214
Re: 75-300 is a very sharp lens
When I see results like yours, I wonder what's wrong with my 75-300?  My experience is more similar to the OP's.
Does this lens have more sample-to-sample variance than most others?
 Mark Ransom's gear list:Mark Ransom's gear list
Pentax K-7 Pentax K-01 Olympus E-M5 II Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +6 more
RSTP14 Veteran Member • Posts: 6,368
18
Technique? The OPs photos were all taken at 300mm, and 1/300sec or less and relatively high ISO, and guessing (but could be wrong) hand held with only body stabilization. I would have been surprised if they were sharp, not forgeting that it is a cheap consumer grade hyper-zoom lens. Surely can't compare that to the 300mm pro lens that is 6x the cost or photos taken at nearly 3-8x the speed.
Roger
 RSTP14's gear list:RSTP14's gear list
OM-1 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-45mm F4 Pro +4 more
Dennis1972 Regular Member • Posts: 481
7
Not seeing what you are seeing.
Even at tiny web sized "thumbnail" they all look watercoloured.
It's clear heavy noise reduction has been applied in an attempt to hide the obvious softness.
Unimpressed at all.
 Dennis1972's gear list:Dennis1972's gear list
Olympus OM-D E-M10 III Canon EOS R Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 25mm F1.8 +2 more
Raucous Raven
Raucous Raven Forum Member • Posts: 79
That was my experience with the lens as well. I've seen people get sharp photos from it but the one that I briefly had performed more like yours. It was very clearly optically inferior even to the inexpensive Olympus 40-150mm F4-5.6 R that I tested it against. I think, as others have speculated, that there's a lot of variability in this lens.
I ended up with the Panasonic 100-400 instead. It was vastly superior from an optical standpoint. It was a bit less exciting from a financial and weight perspective and I was not always happy with the focusing performance at the long end. I don't know how much of that last was the lens and how much was the older body (E-M1) that I used with it.
I hope that the 300 f/4 works out for you!
 Raucous Raven's gear list:Raucous Raven's gear list
Canon EOS R Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 100mm F2.8L
Mark Ransom
8
Unimpressed at all.
You realize that DPReview destroys the pictures it displays in-line in the thread?  You need to click on the image and display it at 100% to see it as intended.
Unimpressed at all.
Of course I did?
I call them "thumbnail" because they aren't in full res and are all < 5mb.
Even so it's clear they are watercoloured.
6
Of course I did?
Original, not edited photo
LoneTree1
LoneTree1 Senior Member • Posts: 2,801
It's an adequate lens for its cost. Non-pro zooms always inexplicably seem soft on the long end where most people use them.   In truth, a cheaper 300mm f/4.0 than one they have now might be more useful for some people but two f/4.0 lenses isn't going to happen.
7
Unimpressed at all.
Most of the time I shoot at ISO100...A heavy Noise Reduction would soften image, not sharpen unless you use "sharpen" in Noise Reduction. I Use Neat Image and when shoot at ISO100, I do use very very little softening - Noise Reduction....
And why you don't show your "thumbnails", maybe huge photos that's not "watercolored"?
20'x30' prints made on Kodak Endura Metallic paper at Adoramapix from my "thumbnails"....Who saw prints - said that it looks nice...uploaded "thumbnails" of course don't show it all....
Unimpressed at all.
Of course I did?
Why don't you post you pictures with some explanations - "WHY".....
LoneTree1
Unimpressed at all.
I've seen bargain-basement, template-built sites with better display capabilities.
Terrible Photographer
Terrible Photographer Senior Member • Posts: 1,454
Totally, the 75-300 Oly is a disaster. Honestly I can’t believe they even approved its release based on its slow 6.3 aperture in combination with its unacceptable image quality.
worst part is when it was released, it was something like $900......
 Terrible Photographer's gear list:Terrible Photographer's gear list
Nikon Z6 Nikon Z9 Nikon Z30 Nikon PC-E Micro-Nikkor 85mm f/2.8D Nikon Z 50mm F1.8 +8 more
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
Could be focus, shutter shock, motion blur...
5
The first image is taken at 1/100s at 300mm. That's asking a lot from your steady hand plus image stabilization. But I notice a bit of a double edge at the feathers which to me suggests shutter shock. The second image has a bit faster shutter speed but still seems to suffer from some motion blur to me. The way in which parts of the image are soft seems "directional" which makes me suspect motion blur. At 300mm you need to be very careful about keeping the camera and lens steady and not cause blur from pressing the shutter button in order to get sharp results.
I only have a few images that could possibly compare to what you tried. Here is one, with a much smaller bird (also cropped a bit). 1/1500s and f/8 are key to getting a bit of sharpness here.
Here a different type of bird and not all the way at 300mm (1/500s, f/8):
But it can also go wrong, as shown here (1/200s, f/8), shot taken seconds before the sharp one:
If the lens can do what the sharp image shows then clearly I would say the blurred (last) image is due to user error (shutter speed too slow plus motion blur).
Getting to know the Olympus OM-D E-M5 II.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
doady Senior Member • Posts: 1,840
8
I see a kind of double image of all of the lichen in the first picture, which suggests to me some kind of shake or vibration from the camera.
 doady's gear list:doady's gear list
Olympus C-7070 Wide Zoom Olympus E-M1 II Olympus 12-100mm F4.0 Phase One Capture One Pro
martinhb Contributing Member • Posts: 800
E-M1 Mark II : AF Focus adj
I found the 75-300mm F/4.8-6.7 II soft at 300mm & used AF focus adjust that’s provided on the Olympus E-M1 MKII.
When I first got the lens I checked the focus in manual mode using a tripod targeting at different distances. Close too it was ok but above 280mm it became unsharp.
Fortunately with the E-M1 Mark II its possible to adjust for this deficiency.
AF Focus Adjust found at menu * A3 - 4
I had to adjust mine to +2 for it to be very sharp at 300mm.
Also I use the largest jpeg image possible which is LSF mode (5184 x 3888) pixels when not using RAW.
This critter refused to move round the tree into the sunshine but nevertheless the feather detail is ok even in the shade.
 martinhb's gear list:martinhb's gear list
Canon PowerShot G1 X Panasonic Lumix DMC-G3 Olympus E-M1 II Panasonic Leica D Vario-Elmar 14-150mm F3.5-5.6 Asph Mega OIS Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +3 more
kalisti
kalisti Senior Member • Posts: 1,181
really nice pics, and those prints!!! very nice
check that guys posting history, you may be wasting your breath, though I wont complain if you post more images
 kalisti's gear list:kalisti's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 14mm F2.5 II ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +3 more
