RF 35mm F1.8 IS STM Hood - EW-52 vs ES-52 for EF 40mm F2.8 STM
Started Jan 4, 2020 | Discussions
Steve W Veteran Member • Posts: 6,998
So the hood, EW-52, for the RF 35mm f/1.8 IS STM Macro is not quite the same as the one for EF 40mm f/2.8 STM which is the ES-52 hood but they are both small plastic screw-on rings. So why is the new RF hood $41 vs  the $8-12 for the older one?
Also, is there really any difference? I have the 40mm and its ES-52 hood. If anyone has the EW-52 can you measure the diameter of the hole and share it hear. I will have to measure the other one so we can compare them.
Seems like Canon is simply out of touch with what this should cost. Also its hard to understand why they don't include it. Stupid moves like this push people to Sony, Fujifilm, and other vendors.  Sony and Fuji both have lenses at the same price and lower that include a hood and some cases its actually a real hood.
Just a rant but just felt the need to make a statement even though I know Canon is deaf to this kind of thing and has been for years.
Two things are infinite: the universe and human stupidity; and I’m not sure about the universe! - Words to live by. Albert Einstein
 Steve W's gear list:Steve W's gear list
Fujifilm X-E3 Canon EOS R5 Sony a1 Sony a7 IV Sony a7R V +49 more
Sittatunga Veteran Member • Posts: 5,406
Re: RF 35mm F1.8 IS STM Hood - EW-52 vs ES-52 for EF 40mm F2.8 STM
Steve W wrote:
So the hood, EW-52, for the RF 35mm f/1.8 IS STM Macro is not quite the same as the one for EF 40mm f/2.8 STM which is the ES-52 hood but they are both small plastic screw-on rings. So wey is the new RF hood $41 vs the $8-12 for the older one?
The RF hood is £25 from the UK canon website including 20% sales tax. The sell the ES-52 hood for £23. When I couldn't afford not to fix my own car I found that there were three different prices for the same engine component depending on whether it was for a Range Rover, a Rover car or a Sherpa van. It's basic economics to charge what the market will bear.
You could probably file a nice, efficient rectangular hole in the ES-52 hood if you weren't going to use it outside a rotating filter, in which case it would have to be round. Long ago I carved myself a petal hood for my 28mm FD lens out of a standard lens hood - both cheaper and more efficient. It was a lot easier to do by eye for an SLR though.
SJK065 Regular Member • Posts: 145
I just sold my RF 35 but when I had the lens I found that the metal Nikon HN3 lens hood worked great for that lens.  Paid $15.00 for it on ebay.  Might look at that as an option.
 SJK065's gear list:SJK065's gear list
Leica Q2 Sony a7R III Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.2L II USM +8 more
OP Steve W Veteran Member • Posts: 6,998
Thanks, Actually own a HN3 hood from my Nikon film lens so I will try it out.
davel33 Senior Member • Posts: 2,974
For as long as I can remember Canon only ships a hood with L lenses.
I use a "B+W 52mm 900 Collapsible Rubber Lens Hood" hood for 3 reasons.
The hood screws into the lens barrel that moves with focus so you want to protect it and a rubber hood is better than metal and its cheap $20 at Amazon and $15 at B&H.
"Just one more Lens, I promise....."
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
Probably the best idea for this lens. Thanks.
BaldEgo Regular Member • Posts: 296
JJC makes a compatible hood (LH-EW52) for a much more reasonable price. I picked up mine for less than $20.00 Cdn on Amazon Canada a few months ago. It looks and functions just like Canon’s version.
Dan W Senior Member • Posts: 1,154
There is also aftermarket versions of that hood for on the cheap. I also looked at that hood and thought WTH! I personally believe in using lens hoods for both protection and preventing flair, but I don't see the point of that little screw on... BTW, canon does not include lens hoods with non L lenses but it does on all the L series lenses.
 Dan W's gear list:Dan W's gear list
Canon EOS R5 Canon RF 50mm F1.2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 70-200mm F2.8L IS USM +3 more
Thank you for the info. I will follow up on it.
Been buying Canon gear for 25 years so I know that their non-L glass has never included a hood so I was not surprised by this. What surprised me was the HUGE cost differential for the EW-52 when the ES-52 was 1/3 to 1/4 its cost. Also what bothered me was what appears to be a completely useless creation, similar to the the one for the 40mm STM but I assumed that was because it was a pancake lens and had a real motivation to keep it very, very small.
Looks like JJC does make an alternative but wondering if its better to buy that one or one of the flexible rubber B+W ones. Or even one of the Nikon screw on or clip on hoods that works with a 52mm filter thread. All have been suggested here now.
The Nikon HN-3 is a metal screw on hood made for all the older Nikon AI-S 35mm lenses and remembered that  I owned it and it screws on fine.  There is also a HS-12 that I also have that is a snap on made originally for a 50mm that fits fine.
The key question is how well do any of these deal with lens flare since its hard to tell how their extension and angle map to the field of view of a 35mm given where any of the elements are in the lens itself.
Thanks to all for responding. Now I just need to try some of them out to how well the work.
Calimero1 New Member • Posts: 12
When I first saw the EW-52 I thought it was a joke. The hood looks like an ordinary filter ring. I am afraid that it has very little efficiency in blocking the side light.
I also think about what hood to buy on my RF 35mm. I feel much better about design and size of Nikon HN-3.
 Calimero1's gear list:Calimero1's gear list
Canon G3 X Canon EOS RP Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3
mtillitt New Member • Posts: 24
If you can get  ahold of an old EW-65 or ES-65 clip on hood they will attach over the main barrel with the use of a small o ring. Not my original idea. It came from  an earlier thread on this forum. Great protection  from  flare and impact damage
So where do you place the O ring? I don't see it here in the photo. Is it inside the hood?
The o ring goes in the little groove around the front of the main barrel.  I think I used about 3/32 x 2 inch diameter. If you use 3/32 size, going to a larger overall diameter will make it stretch  less and be a tighter fit for the hood. It may take a little  trial and error to get just the right fit.  Mine is pretty snug to take off but it won't get bumped off either.  Only bummer is the overall diameter of the hood isn't large enough to reverse over the lens. The one in the picture is the ES-65. EW-65 is a little shorter. Neither vignettes.
quiquae Senior Member • Posts: 2,265
That’s what you would think, right?
Wrong. The pancake hood actually works better than the HN-3 for blocking stray light.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
Thank you
