OutsideTheMatrix wrote:
Helen wrote:
Yes, the E-PL8 is the same camera as the E-PL7, albeit in a totally restyled body shell. The only functional/software differences are a tiny layout change in the icons when the screen is facing forwards in selfie mode only, and maybe one extra Art Filter (I forget - I could go and look, but...).
However, the E-PL7/8 are VERY different from the E-PL6. You can get a good insight into it here:
https://www.imaging-resource.com/PRODS/olympus-e-pl7/olympus-e-pl7A.HTM
The reviewer draws some comparisons between (and shows side by side) the E-PL5 and E-PL7. Of course the E-PL5 lacked a few nice software additions that your E-PL6 has and these were carried over to the E-PL7 and 8. In a nutshell, the new, very slightly larger body of the E-PL7 (and 8) incorporates a higher-resolution, 3:2 aspect ratio LCD which makes it much roomier in use than the constrained 16:9 screen of the previous models. The somewhat "ticklish" (if it succumbs to oxidation of the contacts) rotating ring around the 4-way controller is replaced by a metal control wheel around the shutter release, various controls are re-arranged, the monitor flips downwards to face the front instead of upwards, and most importantly, the in-body stabilisation is the 3-axis levitating type from the E-M10 original model, which is massively more effective than the 2-axis mechanical type used on the previous E-PL models. As you mention, the E-PL7 and 8 have the 0-second Anti-Shock option for the shutter (effectively this gives them a form of EFCS - electronic first-curtain operation) and it is very beneficial at certain shutter speeds for eradicating the possibility of shutter shock affecting your shots. As AllFlawed mentioned, they don't have a silent shutter option as this only arrived (in a terribly hampered fashion) in the E-PL9, to be corrected in the E-PL10, but both of those lost compatibility with the add-on EVFs and had huge configuration cuts due to the ill-advised severe shortening of the menu system in PASM modes.
There are many other changes from the E-PL6 to the 7/8 covered in that review I linked to. The E-PL8 is still quite easy to find new. Incidentally, the operation of the auto-display switch eye sensor on the VF-4 EVF is much quicker and more responsive on the E-PL7 and E-PL8 than it was on the E-PL6 (which was of course far better than the E-PL5, which couldn't use the eye sensor!).
That change with the rotating dial is good news because I have some problems with it since I use manual exposure mode an awful lot. Does the rotating ring on the E-PL6 stop working with time?
I have found that the models with the ring around the 4-way controller (E-PL2, 3, 5, and 6, plus the E-PM1 and E-PM2) can develop an issue whereby the ring becomes hyper-sensitive and tends to jump around as if it's being turned a fair way in either direction, randomly, when all you did was press it once. I think it's oxidised contacts probably, and could therefore more come from long periods of rest and the type of atmosphere it's stored in. Energetic exercise of the ring can help rectify it for a while. Having said that, my E-PL6 hasn't done it, so maybe they changed a component about then.
The much heftier metal control dial around the shutter release on the E-PL7 and E-PL8 is of course still the only rotating control on those models, but it does seem to benefit from being purely a control dial, and not having to double up as the 4-way controller (which remains on the back and is just the 4-way keys, with no rotating element (still with the OK button at its centre of course). I haven't had any trouble with that new design and not having to avoid pressing the compass points makes it easier to operate fast, too. I like that its design is friendly for index finger use, though it is possible to use it with the thumb too, if desired. It's still used on the E-PL9 and E-PL10, but those cameras as discussed before tread a different path, going for a more beginner-friendly simplicity by dropping lots of the configuration options to simplify the menus, as well as dropping the EVF port (though a built in flash is back after a long absence - last seen on the E-PL2). The bodies on the 9 and 10 are polycarbonate, rather than the metal of their predecessors since the E-PL3 (the E-PL1 and 2 had metal fronts and polycarbonate rears and rims, as did the E-PM2 [but not the E-PM1, which was all-metal like the E-PL3, aside from the E-PM1's large Perspex panel surrounding the rear LCD and encompassing the buttons).
Also, are you aware of any trade in program that Olympus has in going from the E-PL6 to the E-PL8? I do that sometimes when upgrading cameras (and paying a fee plus the trade in).
Afraid not, though that's not to say there isn't one, as I strongly suspect you're in the US and as you might have spotted from some of my spelling above, I'm in the UK.
Thanks, Helen, when did you get your EPL6? I got mine in January 2016.
I bought it brand new, ordered on 29 September 2014 - it was available in the UK before it made it over to the US, but here it was still considerably after its initial marketing in Japan and nearby territories (initially exclusively there). It's a black one - I wanted to get a version that was different to the E-PL5 versions (it has a matte black crackle finish and orange-red metallic highlight rings here and there, versus the smooth black anodised E-PL5 - though as it happens, my E-PL5 is a white one! In the case of the white versions, only the removable grip and the matching little thumb piece on the back are different - beige on the E-PL5, white on the E-PL6). Yes, I have a trivial mind and a terrifically compulsive personality....
Yes, I'm in New York, and Olympus offered me a trade in plan for my old E-520 but rather than take that I bought my EPL6 and kept my E-520 also!
I read the EPL7 review you linked me to, and it seems they think the EPL5 is a little better in terms of preserving detail at higher ISO, but I suppose this wouldn't matter for most users?
https://www.imaging-resource.com/PRODS/olympus-e-pl7/olympus-e-pl7-image-quality.htm#print-quality
It'll be very subtle if it's there at all - though it could be down to differences in the version of the image processing engine, it's just as likely down to a different noise filter setting, different shooting conditions, or even simply sample variation. The E-PL7's much better 3-axis floating IBIS and the 0-sec Anti Shock setting (which is a virtual electronic first curtain shutter option) both mean that more resolution is actually possible in my experience - not that I've tested it hugely, I have to admit (sorry!). But I can say for sure that those two features eradicate issues I sometimes had with the E-PL6 and its immediate predecessors due to issues with vibration from the shutter and how it interacted with their earlier-design 2-axis mechanical IBIS.
For usage on a tripod and with the self-timer, would you still recommend the IS be turned off?
Opinions vary; there is the S-IS Auto mode which is supposed to sense the situation the camera is in. I've actually never seen any artefacts caused by having IS on with the tripod, but I don't shoot on a tripod all that often.
Also, in RAW mode, the output should be identical for all the cameras, regardless of TruePic version?
Quite probably. I'm a lazy photographer, I'm afraid, and tend to shoot in jpg only as I hate working on images in post for some reason (probably a lifetime of working too long in front of a computer, but also I'm indecisive yet invariably like the original shot best!!).
Is floating IS also more durable than mechanical IS? My camera makes a grinding sound at start up I've been worried about.
My 2-axis cameras such as the E-PL6 tend to make a 1/4 sec or so grind on turning off, rather than when starting up. Despite its floating nature (and on some bodies you can actually hear the sensor clunk whilst the power is off!) the 3- and 5-axis IBIS systems seem reliable and they are definitely a lot more effective than the mechanical 2-axis type. They don't grind (it's amusing to hear the E-PL6 doing a 2 second exposure - sounds like a coffee grinder!) but they do make a hissing, whooshing noise all the time (even with IBIS off, as the system then needs to hold the sensor at a centred position) and they have an option to ramp up the system fully during a half-press of the shutter release to stabilize live view, and this is louder still (on the E-PL9 and 10 this is non-optional - it always gets louder on half-press). All versions of IBIS, even the 2-axis of your E-PL6, will actually flash an icon (I think some of it is red - thankfully I've yet to see it - if the IBIS is malfunctioning).
And the issues you mentioned about the dial on the back of the EPL-6, do they also happen when you just use it as a four way controller or are they issues when turning it only?
Well, my E-PL6 is fine so far but the earlier models with this (E-PL3 and E-PL5, which is mechanically identical to the E-PL6) do, and it's a massive, directional-erratic oversensitivity, so it happens on turning or pressing - when it often thinks it's been turned. In both cases, it will often assume that turn is for far more clicks than it was, and it will randomly decide the direction of the "turns" itself! However, bear in mind that my house is on the cool side and tends to be slightly damp as a result (little I can do about it - silica gel, dehumidifiers and of course heating only help to a limited extent) so this probably explains why my E-PL3 and 5 have tetchy dials, if it's a contact oxidising issue.
Thanks!
