To consider without hesitation
Started Dec 31, 2019 | User reviews
RTJR
RTJR New Member • Posts: 14
Very compact lens that fits well with the logic of a compact system (weight and size). The focal length and its 1: 2 magnification ratio is more than enough for most macro needs, and is an excellent portrait lens.
Pros:
Construction quality
Image quality and sharpness from f / 2.4 (peaks at f / 5.6)
Metal lens hood
Cons (annoying points):
I would like an opening ring with slightly tighter notches
39mm thread is not standard
The electric focus system which does not allow you to stay locked when you turn off the camera (returns to its nominal position).
An excellent lens to consider without hesitation
 RTJR's gear list:RTJR's gear list
Panasonic Lumix DMC-GF2 Fujifilm X-T2 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 50-140mm F2.8 +1 more
Telephoto macro prime lens • Fujifilm X • 16240767
Announced: Jan 9, 2012
RTJR's score
4.5
Average community score
4.4
RTJR
OP RTJR New Member • Posts: 14
Re: To consider without hesitation
a_c_skinner Forum Pro • Posts: 13,047
I assume you mean aperture ring by opening ring?
You are correct it is a very good lens if the focal length suits you.  People often say the AF is sluggish.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
dark13star
dark13star Senior Member • Posts: 2,045
While I agree that it is optically great, it is also a bit frustrating so I sold mine yesterday and ordered the 80mm on sale. My issue with the 60mm is not so much slow focus, but that when it hunts, it hunts through its entire range to acquire focus. I'm hoping the focus limiter switch on the 80mm will help a lot. It is too soon to know, since the lens is arriving tomorrow.
If you don't need autofocus on close-up moving subjects, the 60mm is a great lens.
Rich
"I would be an historian as Herodotus was." -Charles Olson
http://photos.herodot.us
 dark13star's gear list:dark13star's gear list
Fujifilm X100S Olympus Tough TG-4 Olympus TG-5 Fujifilm X-E1 Fujifilm X-T3 +14 more
Mine was much better on a more modern body compared with the X-M1 I first used it on.
I sold it having bought the 80mm; I've now got a Zeiss 50mm macro too as the 80mm is big and heavy.
Andrew Skinner
yardcoyote Forum Pro • Posts: 15,754
I am very fond of mine, in spite of its quirks. It makes an ideal companion lens for the 35mm f/1.4, being only fractionally larger. I replaced the hood that came with my 60 with a second copy of the handsome square hood from the 35, which fits perfectly. This pair currently shares an X-T10, but I may buy them an X-T2 eventually.
Instagram: @yardcoyote
 yardcoyote's gear list:yardcoyote's gear list
Fujifilm X10 Fujifilm X100T Fujifilm X-Pro1 Pentax K-5 IIs Fujifilm X-M1 +20 more
Yannis1976
Yannis1976 Veteran Member • Posts: 6,308
Re: My main problem with that lens..
,,,is that I cant find one at a reasonable price in the used market
Happy New Year to all!!!
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Rod McD Veteran Member • Posts: 8,589
Hi,
If you can live with the fact that it has first gen AF, it's a great lens - perhaps under-rated in this forum.  Pretty much everyone agrees that it should have had a limiter, because it will indeed hunt through the entire range if it doesn't lock on focus.  Most people switch to MF with a macro lens anyway for higher magnifications.
I hope Fuji develop a Mark II with a limiter, improved AF and sealing.  I'd be perfectly happy if they leave the optics the same.
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
cantanima bis Contributing Member • Posts: 920
RTJR wrote:
Some samples:
https://www.flickr.com/photos/rtjr/40838633753/in/album-72157711582521337/
https://www.flickr.com/photos/rtjr/48737904796/in/album-72157711582521337/
https://www.flickr.com/photos/rtjr/49147124618/in/album-72157711582521337/
For the second, you have some notes in Flickr that say, "sharp corner," but it's a 1x1 crop of the original, and it may even be downsampled (in Flickr at least). Are those really the corners?
 cantanima bis's gear list:cantanima bis's gear list
Fujifilm X-S1 Fujifilm X-Pro1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +2 more
