GX85+14-45 vs E-P5+14-42(ii r) comparison
Started Dec 30, 2019 | Discussions
Boss of Sony Senior Member • Posts: 2,425
This is just for fun. GX85 with a very old Panasonic 14-45mm kit lens vs E-P5 with the Olympus 14-42mm ii kit lens. I shot both lenses at their wide and long ends, then also tried each lens on the other body to see if there are any impacts on IQ from using a different body. All settings were as standard as I could manage, with sharpness and noise reduction set to zero on both cameras (I think; not completely familiar with Olympus menus), and ISO 100. I focused on the white building in the centre. I tried to make exposure about the same.
First the Olympus E-P5 shots using both lenses:
Then GX85 shots using both lenses:
My conclusion is that the Panasonic 14-45mm is the sharper lens at both ends, although the Olympus 14-42 is not too bad at the wide lens, and that both lenses seem slightly sharper on the Panasonic body (although this is subjective and there is not much in it). And the Olympus colours are slightly nicer.
To turn NR off on the E-P5, I went to the custom menu, then Exp/.../ISO, then Noise Reduction: off. I assume this is the way to do it?
 Boss of Sony's gear list:Boss of Sony's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 9mm F8 Fish-Eye Body Cap Lens
Olympus PEN E-P5 Panasonic Lumix DMC-GX85
JaKing
JaKing Veteran Member • Posts: 6,300
Re: GX85+14-45 vs E-P5+14-42(ii r) comparison
No, it's not ...
In Olympus land, 'noise reduction' refers to dark frame subtraction after long exposures.
You need to adjust 'noise filter' via the same menu as you used - set to 'low' or 'off'.
br, john, from you know where
My gear list and sordid past are here: https://www.dpreview.com/members/1558378718/overview
Gallery: https://www.canopuscomputing.com.au/zen2/page/gallery/
 JaKing's gear list:JaKing's gear list
Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Olympus 12-100mm F4.0 Olympus E-1 +29 more
OP Boss of Sony Senior Member • Posts: 2,425
sorry, here are the Olympus shots. With the 14-45mm lens:
With the 14-42mm lens:
JaKing wrote:
No, it's not ...
Thanks, wish I'd known that before I did the test. It was set to standard.
JaKing
Boss of Sony wrote:
JaKing wrote:
No, it's not ...
Bugger ... .
Like all JPEG NF/NR, it is too aggressive at the default setting. Can smear detail badly, depending on subject.
If shooting only JPEGs, I would set this to OFF. As I shoot RAW + LSF JPEG, and use the two file types for different purposes, I set mine to NF = Low.
alcelc
alcelc Forum Pro • Posts: 19,006
As I am on my phone, can't judge on the result.
However as far as to me, 14~45 is old, but still one of the best standard kit zoom of M43. Its IQ is highly comparable to 12~35 f/2.8, slightly better than my copy of 12~32 and 14~42 PZ.
Sadly it is not DUAL IS compatible which making it harder to compete with its younger siblings on recent Panny DUAL IS compatible bodies.
Regarding the color, Standard mode of GX85 at 0ev exposure is sort of flat and noiser than it should be. Add +1/3~2/3ev when zebra appears will give its SOOC output a totally new look. For SOOC jpg shooter, Vivid is the best for non portrait shooting. All could break away from default of Panny output.
My 2 cents.
Albert
Tech Head
Tech Head Regular Member • Posts: 225
Big difference in the lenses at the long end. Olympus has yet to make a decent, small kit lens.
JaKing
Please pardon me for disagreeing ...
Hopefully you read the part where he mucked up the noise filter, unfortunately.
buratino
buratino Contributing Member • Posts: 929
alcelc wrote:
...14~45 is old, but still one of the best standard kit zoom of M43. Its IQ is highly comparable to 12~35 f/2.8, slightly better than my copy of 12~32 and 14~42 PZ.
And what about Pana 12-42 II? Could you comment?
 buratino's gear list:buratino's gear list
Panasonic Lumix DMC-GF7 Panasonic Lumix DMC-GX85 Panasonic GX850 Olympus M.Zuiko Digital 45mm F1.8 Rokinon 7.5mm F3.5 UMC Fisheye CS +9 more
What on earth kind of logic is this? Did you see the part where I tried both lenses on both cameras and you can even compare the shots for yourself?
Tech Head
He tried it on two cameras. Almost identical results.
alcelc
Don't have it, I have already too many 12/14~XX zoom lenses.
Read that it is also among the best of its class...
Albert
Tech Head
I would rank the 12-60 (f3.5 to f5.6), the 12-32, and the 14-45 as the best small, slow kit lenses.
I would rank the Pana14-42 II as just slightly behind the top 3.
Then I would rank any other slow kit lens for MFT to be behind the top 4, including all Olympus kit lenses.
buratino
Interestingly, in my experience, Pana 12-60mm was unimpressive at all, definitely worse than 12-32mm. At the same time, both copies of 12-32 I had were equally satisfying. Probably, I got a bad copy of 12-60mm.
Henry Richardson Forum Pro • Posts: 21,959
E-P5 photos missing?
I don't see any photos with the E-P5.
Henry Richardson
http://www.bakubo.com
alcelc
On contrary to your experience, might be I have a bad 12-32... ?
My copy of 12-32 is quite good (as a kit lens) under reasonable lighting condition. But it behaves weird when lighting condition going bad... Its inconsistent performance leads me to rate 14-45 a better all round player.
Albert
JaKing
Re: 😅
Albert, contrary to the opinions expressed by two people, I have found my 4 Olympus kit zooms in this range to be of better than acceptable quality.
Not in the same league as my FTs 11-22 and 14-54 MkII or 12-100, but good enough. Those latter lenses are also 4x to 6x the price, so they flaming well should be better, and are!
Same goes for Panasonic kit lenses.
The fatally flawed comparison done by the OP shows nothing that changes my view either way. There will also always be some sample variation - sometimes so obvious that a lens should be returned. I have never experienced such bad sample variation, however.
I also don't spend my time dissing Panasonic gear on the basis of a single image set taken under unknown conditions.
I DO know that Panasonic make generally excellent products.
Tech Head
Because different reviews give markedly (sometimes wildly) different results for these lenses and because sometimes people get bad copies, I looked first at Panasonic's theoretical MTF charts for the lenses. I also looked at the pro reviews and user opinions.
The top 3 lenses I gave are the ones Panasonic actually claims are the sharpest on the long end. I didn't feel the consensus of reviews refuted this ranking. And Panasonic rates the 12-60 (f/3.5 to f.5.6) as their sharpest of the slow kit lenses.
When comparing Olympus kit lenses to Panasonic, I'm pretty much just quoting what I've read on this forum many times from many different users. It seems to be a consensus.
I did compare the Oly 14-42 I to the 12-60 f/3.5, and the latter was clearly superior optically. I don't have the EZ or the mark II.
The 12-50, in virtually every pro review, was found to be optically weaker than the 12-32 and 12-60. It seems to be a consensus.
buratino
Tech Head wrote:
...Because different reviews give markedly (sometimes wildly) different results for these lenses and because sometimes people get bad copies, I looked first at Panasonic's theoretical MTF charts for the lenses. I also looked at the pro reviews and user opinions.
I am "bothered" with strong difference between M and S values in 12-60mm. I wonder if it could be a reason I did not like mine (I doubt it, though). 12-32 looks quite good! I expected better corners at 14mm in both 14-45 and 14-42 lenses.
Oly 12-40mm is below. For comparison, only S20/M20 values are common between the above and below. Oly has a very low difference between S20 and M20. And whatever values are there, I love my 12-40mm.
Tech Head
The 12-40 is clearly sharper than any of the above kit lenses. But the MTF values aren't comparable, mainly because you're comparing f/2.8 to f/5.6. You can fairly compare an f/2.8 lens to an f/2.8 lens, but not to an f/5.6 lens. The only way to be fair is to stop down the 12-40 to f/5.6, which may improve the MTF values.
Aside from that, I'm not sure manufacturer provided MTFs are generally comparable between brands, unless the comparisons were done by the same people.
I only use them to compare Panasonic lenses to other Panasonic lenses at the same aperture, or Olympus lenses to other Olympus lenses at the same aperture. In other words, which Panasonic lens is the sharpest, irrespective of other brand lenses.
