Sharp, nice bokeh -- great lens!
Started Dec 27, 2019 | User reviews
medon78
medon78 Contributing Member • Posts: 697
This is the kit-lens for my RP. So far I like it quite a lot - it is sharp already at f/1.8, only getting better when stopped down.
Bokeh is nice, has a little bit of character, but so far I did not in a single shot see something that had to be described as "busy" or wishing me to re-take the shot with different aperture or focusing distance.
Focus is not super-snappy as with USM-lenses, but that's OK with me. It is still plenty fast.
Some testers say, this lens would exhibit extreme vignetting. Well, looking at the example below (far from scientific, true!) I can see a 1.5EV difference in the corners between f/1.8 and f/5.6 in the RAW file. That does not bother me too much, since in-camera correction reduces this even further.
Price: in the kit with an RP or so the lens is reasonably priced. The stand-alone list price of ~500-550 EUR as of late 2019 seems a little high, though.
 medon78's gear list:medon78's gear list
Fujifilm FinePix X100 Canon PowerShot S110 Olympus E-M1 II Nikon Z6 II Olympus M.Zuiko Digital 45mm F1.8 +11 more
Canon RF 35mm F1.8 IS STM Macro
Macro prime lens • Canon RF
Announced: Sep 5, 2018
medon78's score
4.5
Average community score
4.5
J A C S
J A C S Forum Pro • Posts: 20,521
Re: Sharp, nice bokeh -- great lens!
You are comparing different exposures and different ISOs... Optical Limits measured 3.8 EV vignetting, which is pretty extreme. I checked their numbers of other lenses (I do not own the RF 35) in RAW, and their numbers are quite close to mine. DPP measures extreme vignetting as well.
medon78
OP medon78 Contributing Member • Posts: 697
Yes you are right, the ISO were different in the real world snapshot.
I re-checked with fixed ISO against my white ceiling, with 4 variations -- lens corrections turned ON/OFF, focus set to infinity vs. focus at 0.5m.
Seems the both variables "focus" and "lens corrections" do not affect vignetting, maybe the focusing distance changes corner exposure by ~0.2 EV. Not too significant.
Result: Yes, vignetting is stronger compared to my initial 1.5EV statement; now it is close to 2.0EV.
I am sure the guys at Optical Limits have more sophisticated measurement methods and tools at hand, though. OR -- maybe the R and RP exhibit different vignetting thanks to different micro lens design. Don't have an EOS R at hand, though.
Cheers!
J A C S
Cheers!
This is interesting. Would you share that RAW file with me? I can share some RAWs of my 50L with the R and the 5D4 if you want.
I found it tricky to measure (and even define) vignetting. It depends how directional your source is. Walls/ceilings are good targets but they can be a bit too directional. I tried putting a napkin over the lens and when I point it to a light source, for example, I still see a hot spot.
I measured about 2.2 stops for my 50L. If I choose the center to be strictly the center, and measure the corners in the extreme corners with a small box, I get a bit more.
medon78
... sure, let me know what your results are!
Cheers, Medon
https://www.dropbox.com/sh/uqd1pqbh82tq8c6/AAA5V2d8HQDZj_vU_ZxLE73ha?dl=0
J A C S
Cheers, Medon
Thanks. I will post my findings. I may start a new thread in the PST forum with a link here.
ZX11
ZX11 Veteran Member • Posts: 6,156
I think it is a good lens.  It seems to be thrown in with the camera a lot (my case) so harder to say it is good value or not.  Fun to play with for the money, for me.
But it does follow the demands that Canon produce some cheap RF primes in the f/1.8 range.  A 35mm f/1.2 IS L would be intolerable due to it's $2k price, size, weight.  A 35mm f/1.8 would be intolerable for some other reason (non-L level IQ?).  Fun.
It works well on a gimbal putting the EOS R focus mode on wide.  It is very light weight and sorta short.
"Very funny, Scotty! Now beam me down my clothes."
"He's dead, Jim! You grab his tri-corder. I'll get his wallet."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
J A C S
Here is a curve derived from one of you RAW files:
It goes to -2.1 or -2.2 in the extreme corners.
I tested my EF 50L on the R a bit unscrewed and screwed (with fewer samples).
Yellow curve: unscrewed (the camera cannot recognize the lens). The red curve: the camera recognizes the lens and "cheats".
medon78
OK! Thank you very much. So... no -3EV or more as the Optical Limits guys sampled. Then there must be either something wrong with my uncalibrated ceiling ;)... hmmm.
If you would like to compare other lenses, I would have the EF 85/1.8 and EF 50/1.4 at hand.
Regard, Medon
J A C S
I do not think that you can make the vignetting weaker by doing a bad test, this is very hard. On the other hand, a poor test can easily make it look stronger, if the light is more directional than one would think. Taking a shot of a wall pained with a glossy paint is an example. This is especially tricky with wide lenses.
Since I have the spreadsheet ready, yes, please. You can try to unscrew the lens a bit so that the camera does not cheat. You need to tell the camera to take shots without a lens first (it is somewhere in the menu).
You can see my thread in the PST forum as well, where I tried to catch my R cheating.
forpetessake
forpetessake Veteran Member • Posts: 5,172
Vignetting is not much different from 35/2 IS lens. I used the latter profile in LR and it looks reasonable.
https://www.the-digital-picture.com/Reviews/Lens-Vignetting-Test-Results.aspx?FLI=0&API=0&FLIComp=0&APIComp=0&Lens=1224&Camera=1221&LensComp=824
medon78
In
https://www.dpreview.com/forums/post/63469698
... J A C S analyzed some RAW files. Somehow it is hard to reproduce those -3EV results.
Overall, as you say, vignetting in real life use seems not to be excessive.
forpetessake
In
I don't know the reason, most sites measured over 3 stops. Could it be possible that vignetting is corrected in RAW?
J A C S
forpetessake wrote:
In
No, I tested for this in the other thread.
MayaTlab0 Senior Member • Posts: 2,985
Are there methodologies that can eliminate focusing distance or colour profiles as a variable when expressing vignetting in EV ? Differences between various websites' results in EV may just come from that, no ?
J A C S
One usually tests with focusing distance infinity.
I measure RAW files. Most websites however (except DXO, I guess) measure JPEGs, and the tone curve would affect what they report.
One thing I like with Photographylife's tests is that they do it at two focusing distances.
I'm not sure that all lens testing websites are quite rigorous enough to bother with that or many other variables though.
I mean, this is Les Numériques's latest chart concerning the Nikon 58 0.95 :
According to them, the vignetting actually increases past f2 when closing the lens down... ???
Gotcha.
That could be where some of the differences are seen, no ? Tone curves can dramatically affect pictures.
DXO might be evaluating raw files, but sometimes they still managed to produce some strange results :
A lot has been said about the way they aggregate their data into meaningless scores, but sometimes the data itself - or at least the way it's presented - looks a bit weird.
Honestly these days, as far as vignetting is concerned, I find its expression in EV at infinity, provided it's actually properly done (and I don't trust a lot of websites in that regard), quite insufficient to actually describe how a lens is affected by vignetting.
J A C S
All I care is how it is affected the way I use my lenses. I never focus wide open too close.
Anyway, I will do more tests when I have the time. I can also shoot a short video with varying the focal plane. I pretty much determined that the camera does not correct for vignetting unless it is told so, so the video would be informative. I will run RAW tests as well.
medon78
... maybe differences between bodies / sensors.
Most sites test RF lenses with the EOS R, my data come from the EOS RP. Microlens design...?
tdbmd Senior Member • Posts: 1,546
Just purchased this lens last week so not a lot of time spent with it yet but so far it is really turning in some nice images on my R6.  I can see that this will probably become the basic lens on the camera.  I was using a EF 50mm f1.8 STM as the walk around lens but I think this 35mm is better.  I like the FOV better and it seems to focus a bit faster.
 tdbmd's gear list:tdbmd's gear list
Canon EOS 7D Mark II Canon EOS Rebel T8i (EOS 850D) Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF-S 17-55mm f/2.8 IS USM +11 more
