Peaking low and Peaking high, what's the difference
Started Dec 27, 2019 | Discussions
Brisn5757 Veteran Member • Posts: 4,540
I have a Panasonic G7 camera which has a setting for the peaking (focus paid).
I have tried the peaking low level and the peaking high level setting but can see no difference between these setting.
I'm hoping that someone can tell me the difference and which is the best setting to use for focus peaking.
Brian
 Brisn5757's gear list:Brisn5757's gear list
Olympus SP-570 UZ Sony Cyber-shot DSC-WX70 Sony Cyber-shot DSC-HX200V Sony RX100 IV Canon EOS 300D +9 more
Panasonic Lumix DMC-G7
Gnine Senior Member • Posts: 4,108
Re: Peaking low and Peaking high, what's the difference
Peaking high only picks up high contrast edges. Yeah, counter intuitive, as it's not high sensitivity.
Peaking low picks up on lower contrast edges, so is actually more sensitive than the high setting.
I leave my Panny on low, & find the blue highlighting the best for all round usage in a wide range of situations. Hope this helps.
OP Brisn5757 Veteran Member • Posts: 4,540
Thanks Gnine.
That's useful information.
Brian
alcelc
alcelc Forum Pro • Posts: 19,006
+1 (nt)
Albert
Re: +1 (nt)
alcelc wrote:
I don't understand what you mean by +1 (nt).
Brian
R Liewenberger Senior Member • Posts: 1,824
Re: +1 (nt)
alcelc
Re: +1 (nt)
+1 means agreed with Gnine's opinion.
(nt) means No Text of the posting.
Albert
Bernard de Clairvaux Senior Member • Posts: 1,337
Peaking Duck setting works best with
Birds in Flight???
Best Regards,
Bernard
JMftrnr
JMftrnr Regular Member • Posts: 100
Many thanks for this clarification, I should have thought to that. I was puzzled as I was taking high as high sensitivity, but the outcome was not convincing and was using low!
Jean-Michel
 JMftrnr's gear list:JMftrnr's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital ED 60mm F2.8 Macro +7 more
