Three lens kit
Started Dec 24, 2019 | Discussions
Bassam Guy Veteran Member • Posts: 4,885
I take a lot in little space
Sometimes I go extra lightwith my Thinktank Mirrorless Mover 10 with 1 body and 3 primes.
Sometimes I go light with my Domke F-5XB (is the B for Black?) with a body and 1-2 zooms plus 4-5 primes, maybe the FL-600R flash.
But I usually carry my small and overly padded Kata Gearpack-60 DL, it holds all I need.
Kata Gearpack-60 DL
Top zippered compartments left to right:
  • Left zippered compartment
    • Filter pack (cord secures it to to back pack (I nearly dropped it once over a cliff)
      • 4 polarizers
      • Neutral Density ND 64 fits all my primes except the 45 1.8
    • Cord with clips to secure camera/tripod in precarious locations
  • Right zippered compartment
    • Cable release
    • 2 spare batteries
    • Spare sd card
  • Main compartment
    • Top row
      • Olympus 17 1.8
      • Olympus 60 2.8 Macro
      • Space for padding and E-M5 II (but haven't done this yet)
    • Middle row
      • Olympus 45 1.8
      • Olympus 12 2.0
      • E-M5 III + Olympus 50 1.8
    • Bottom row
      • Olympus 12-40 2.8
      • Lumix 7-14 4.0
      • Olympus 40-150 4/5.6
  • Outer compartment (bottom photo)
    • Flash, FL-600R
    • Flash, FL-LM3 (kit)
    • Spare AAs for FL-600R
    • Lens cleaning fluid
    • Snacks (not shown)
  • Outer bag (incedentally photographed)
    • mini bungee cord to secure tripod
    • pouched silk lens cloth clipped to zipper
    • more clips and hooks
I don't know how much the fully packed Kata weighs but it is no heavier than a notebook computer. The only MFT lens I have that doesn't go in this bag is the 17 2.8 that I took the above photos with. Hence, this bag is also where I store everything at home.
I hike and bike a lot as I live in an excellent area along the Potomac river for both. You could easily argue that the 12-40 obviates the primes it overlaps. First, my only ND filter does not fit the 12-40, so if I want to use it (often), I need the 12, 17, 25, or 60 (gotta get a step down ring for the 45). Second, the primes are 1-1/3 stops faster; not a lot but helpful in low light. I could keep the weather resistant 12-40 at home but what if it rains?
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Just for fun, my 6 lens kit.
Can't see the lenses of course as all pointing down, but no more pesky lens changing to do......
CW from top left - P5-P5-P3-PL1-PL5-PL5
As I said, assembled just for fun some time back, now of course can add one more as a cheap E-M10 Mk2 has also joined the pack.
Regards..... Guy
MOD Tom Caldwell Forum Pro • Posts: 46,352
Re: Obsolete but not forgotten
Gnine wrote:
Tom Caldwell wrote:
The idea of one camera and multiple lenses dies hard.
I like three GM camera bodies each with a lens attached.
The only thing that’s dying, are your GM camera’s. It seems that these days, if people want small, they’ll just use their phones. The only way a lot of people would consider lugging multiple bodies around, with the associated costs involved, are those that are being paid to do so. At this point in time, I can’t see a single, competent body, and a selection of small, light and excellent lenses being replaced efficiently and economically any time soon. That’s where m4/3 really kicks goals
Yes with a competent small GM5 camera - made in the M4/3 tradition - compact - there is no way that a larger sensor camera body can rival this size and competency.
Even the GM5 with 4/3 sensor was just right sized as a heat sink and maybe it would be impossible to make a camera so small with a larger sensor and keep it cool.  Think the new Sigma fp which has all sorts of arrangements to get the sensor heat out of the body.
M4/3 trumpets smaller lenses and buys camera bodies as large as FF camera bodies.  Then complains because exotic capability M4/3 lenses are not that small.
The GM5 has failed because M4/3 users have not realised that very small camera bodies can also be capable systems cameras.  So we are doomed to see small bodies as necessarily cheap and therefore deficient (like mobile phone cameras) and only larger bodies approaching FF camera bodies in size are the only ones with enough user conveniences to justify the amount that we are willing to spend.
I did think that that there is a certain convenience in being able to simply swap camera bodies instead of juggling lens changes in conditions where doing so are not always condusive to allowing this to happen.
In the case of the GM5 the sheer lack of size of the camera body makes lugging multiple bodies much more do-able. Unless you have actually seen a GM5 attached to a lens it is hard to imagine a camera body just a pack of cards larger than the lens it is attached to that M4/3 systems lens.  As noted 3x GM5 bodies are not really larger than one G9 camera body and the GM5 camera has all the basic controls necessary to function as a proper camera.  Furthermore in its hey-day the GM5 had the current issue 16mp 4/3 sensor on board. Still not a sensor that can be sniffed at.
But of course the forked stick is that tiny camera bodies tend to be expensive if they are any good and buying a few GM5 bodies could be more expensive than buying just one top-line M4/3 body and just swapping lenses as needed.
It is not that I am arguing that everyone should use multiple GM5 cameras, just that it is a pity that the tiny very capable GM5 type of camera is not longer made.  The reality is that it was not the size that was the issue but lack of “user conveniences” that had to be sacrificed   to obtain the size objective. ... and of course the furphy that small camera bodies are only good for small camera lenses and compete directly with mobile phone cameras (and are not even pocketable (!) )
One of the beauties of M4/3 has been its variety of body styles and sizes.  The lack of the GM class has just been one less body style bracketed.
Unlike a mobile phone the GM5 will not baulk when fitted with a Nocticron 42.5/1.2 or even a Panasonic 200/2.8 with TC fitted if anyone cared to use it that way.
Tom Caldwell
spike29 Senior Member • Posts: 2,471
Re: Just for fun, my 6 lens kit.
Gosh! And i am waiting on dying of my fz200 before i decide which body i add.
G90 or gx80/90.  😁
I like to have a small rangefinder for 15mmprime and my 14-140mm so my g80 can handle the bigger one's.
But but, i am restraining myself no GAS weakness.  First the dead of my fz200, so i lent i to my kids....😁
Regards..... Guy
knowledge is addictive, every time i get some i want more.....
(If i can remember 1/1000 of everything i learned/read in the past i will be happy as a monky with........)
 spike29's gear list:spike29's gear list
Fujifilm FinePix F70EXR Panasonic Lumix DMC-FZ200 Panasonic G85 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH +2 more
Day Hiker Forum Pro • Posts: 10,829
I defy anyone and everyone...
rocklin wrote:
I have to say my Oly 12-40 2.8 is my "fail safe" lens, which covers most subjects I want to photograph.
It teams well with the 75 1.8 or 60 mm macro. If I know I'll need the extra reach, I'll swap one of these lenses for the Oly 70-300 zoom
Thanks for the reminder. I've been known to use my Pen F with the 3-lens kit:
  1. 8mm f/1.8 Pro fisheye
  2. 12-40mm f/2.8 Pro
  3. M.Zuiko 75mm f/1.8
Wow. Such an excellent kit. I defy anyone with a larger sensor to match this kit.
Jim Pilcher
Summit County, Colorado, USA
Don't trust anyone under 9100 feet
Albert Valentino Veteran Member • Posts: 9,770
My two lens kit
My two lens kit is my EM1.2 with...
  • Oly 12-100
  • PL 8-18
I own other lenses but they are more specialized, like a 60mm macro, Rokinon fisheye, 45mm f1.8, Oly 40-150, both the Pro and cheap version. However, I could easily get by, and often do, with just the two above. Last week I was in New York City and only used/needed my PL 8-18 😃
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
gary0319
gary0319 Forum Pro • Posts: 10,540
Re: Three lens kit...Now 2 lens
With the addition of the E-M5 III, I've now begun to use my 14-150 as my standard mount. So now my usual kit includes the 5.3, the 14-150, and the Olympus 8mm FE Pro for the wide stuff (the 5.3 now has in-camera lens correction to give me a 5mm rectilinear view).
All in a little Mirrorless Mover 20 bag...
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
gary0319
From today with the 14-150, #9 from a 12 shot Hi Sequential burst at 30fps. (All 12 were in focus on the birds eye)
With the 8mm FE with in-camera correction..
Gary, when you use the in-camera correction to get 5mm FOV, is the file still 20mp? If not, how big, and does that mean the two other rectilinear settings are also smaller, but less small respectively?
MickeyVee
MickeyVee Regular Member • Posts: 445
Re: My two lens kit
Pretty much the same kit and covers everything for my type of shooting.  As a third lens, I'll add the PL15 F1.7.
Lately, for city shooting, it's just my EM10 III & PL 8-18.
  • Oly 12-100
  • PL 8-18
 MickeyVee's gear list:MickeyVee's gear list
Olympus E-M1 III Olympus 12-100mm F4.0 Olympus PEN-F Olympus E-M5 III Olympus M.Zuiko Digital 17mm F1.8 +2 more
gary0319
I only do the widest setting and the rectilinear JPEG is 5184 x 3888. The Fisheye is the same.
sounfanz Regular Member • Posts: 175
Re: Three lens kit
I have 2 "Three Lens Kit" set-ups.
For street:
Olympus Pen F with Olympus 17mm 1.8, Olympus 45mm 1.8 and Olympus 75mm 1.8
All carried in a Wotancraft Trooper S bag.
Main kit:
Olympus EM1 MK II with Olympus 17mm Pro 1.2, Olympus 45mm Pro 1.2, and Olympus 40-150mm Pro 2.8 (with MC 14 teleconverter)
Carried in a Wotancraft Trooper M bag.
 sounfanz's gear list:sounfanz's gear list
Olympus 45mm F1.2 Pro Olympus PEN-F Olympus E-M1 II Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Pro +5 more
Thanks. Does it also do/defish raw files or just jpg?
gary0319
The raw files will be fisheye straight out of the camera. I use Olympus Workspace and it will defish the raw to give an almost exact match to the JPEG file. The gallery image I posted was most likely defished in WS, although I often use the JPEG, so not sure which I used, they look exactly the same.
Thanks, Good to know that a fisheye capture can be defished as a raw file or jpg and still be a 20mp file. I figured the defishing would also involve cropping and reduce the resolution. I assume that it cannot produce a defished raw file in the camera to be processed in another raw converter, but that is fine by me. Amazing that the virtues and firsts of the Olympus system exist yet still tend to get little respect. For myself, the system is king and has never made me yearn for anything else 😃
techie takes pics Senior Member • Posts: 1,730
Re: Three lens Vintage kit
In your setup I miss two lenses.
A vintage 135mm. It was always my portrait-lens on 35mm film.  On M4/3 it's a cheap tele-lens ... and it still does portraits.
And since you're into manual lenses, I would pack the Helios-44. If you're going manual, you might as well get something the perfect AF lenses will never offer: swirley image distortion at $45.
 techie takes pics's gear list:techie takes pics's gear list
Olympus PEN E-P5 Olympus OM-D E-M10 II Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS +8 more
jeffharris
jeffharris Forum Pro • Posts: 11,409
When a fisheye image is “corrected” you do indeed lose information as the image is stretched to make it appear “normal”, to make curved lines straight.
If you’re going to shoot fisheye, why not work with and celebrate the fishiness of the images instead of trying to make them something they’re not. Drag queen photography… 😜
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
I agree 100%. I do shoot fisheye for the virtues of fisheye, and have been for almost fifteen years over three systems. I was just inquiring for the perk of having more versatility with an Olympus fisheye vs my Rokinon fisheye, especially getting the 5.5mm FOV and the potential to someday shoot astrophotography with a faster lens. Since the Olympus fisheye is not cheap, I would need to be able to do more to justify the cost 😃
gary0319
5
Having used Olympus cameras now for about 5 years, I've come to realize that the true power of Olympus is not just doing what Canon or Nikon do in a smaller and lighter format, but doing the things that Canon and Nikon and Sony don't do.
However, too many people on this forum seem reluctant, or unable, to even explore the features they have at their fingertips.....and then complain about how Olympus fails to live up o the competition.
stateit
stateit Senior Member • Posts: 1,741
Re: My three lens kit ATM
Asla wrote:
Hi!
Seems my three lens kit is tad bigger...
In Manfrotto Messenger bag...
A s l a
Good to see you've got a Footprint wrist strap. They're the bee's knees.
