RF 70-200 f/2.8 makes rattling sound when being shaken
Started Dec 24, 2019 | Questions
Luyu Cheng New Member • Posts: 5
Yesterday my RF 70-200 f/2.8 arrived. When I took it from the box, I found it made rattling sound when I gently shook it. Looks like the floating lens element for IS are movable even when it's disconnected from the camera.
I know some rather old lenses with IS do make rattling noise when being shaken, but I'm not sure this is true on this newly released lens.
So for anyone who also have this lens, is this reproducible on your copy? I'd appreciate if you can tell me.
BTW, I haven't put it on my camera because my EOS R is still on its way.
 Luyu Cheng's gear list:Luyu Cheng's gear list
Sony a7R III Canon EOS R Sony FE 24-70mm F2.8 GM Canon RF 70-200mm F2.8L IS USM Apple iPhone 11 Pro
MayaTlab0 Senior Member • Posts: 2,985
Re: RF 70-200 f/2.8 makes rattling sound when being shaken
It is also possible that it's caused by the AF design. I believe that Nano USM is similar to most other brands' linear motors and that these need power to fix the elements in place.
shawnphoto Senior Member • Posts: 1,307
Better question is why are you shaking your lens around?
 shawnphoto's gear list:shawnphoto's gear list
Canon EOS R Canon EOS RP Canon EOS R5 Canon EF 24-105mm F4L IS II USM Canon RF 28-70mm F2L USM +4 more
JPAlbert Senior Member • Posts: 1,296
Problem:
"RF 70-200 f/2.8 makes rattling sound when being shaken"
Solution:
Don't shake it.
davel33 Senior Member • Posts: 2,974
What I have found is on some larger zooms that if you remove the lens from the body while power is on, you can get a rattle.  SO turn off the camera before removing the lens.
"Just one more Lens, I promise....."
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
gimp_dad Senior Member • Posts: 2,692
Mine doesn't rattle
I just checked mine. In the closed position I did not notice any rattling at all. I didn't vigorously shake it but did move it up and down as well as flipping it over a few times.
However, I  usually remember to turn off my camera before removing the lens so it was probably shut down correctly. You might want to put the lens in the camera and make sure it's functioning and then turn it off and remove it to see if that changes things.
OP Luyu Cheng New Member • Posts: 5
I didn't shake it intentionally first. I just opened the box and took out the lens, and I felt some parts of the lens was trembling. I wondered if any component is movable so I gently shook it. Then found the problem.
Of course I know this. But the point is that I found the problem before I got the body.
Yesterday my EOS R arrived. To make sure that this problem is not caused by improperly shutdown in the factory. I put it on my camera, turned on the camera, took some photos, shut down the camera. The problem persists.
One more small point you have to wait at least 5-6 sec after you turn off the camera to dismount the lens.  The R keeps the IS on for 5 sec after you turn it off.
Dave
I did wait.
I just made contact with a local authorized store of Canon. They tried this on their sample copies and the problem also exists. The problem is reproducible when you hold the lens vertically with the front element facing up then gently shake the lens. But when it's placed horizontally, being gentle shake won't make any sound.
Hey guys. I found the "problem" can be reproduced on sample copies in my local store. And most importantly, it doesn't affect my use. So I'm not going to call it a problem. Thanks you guys' responses.
N-VB Regular Member • Posts: 192
Just a generral rule, reminded in every manual: lenses with IS, you have to turn off the camera before unmounting , it will lock IS motors
 N-VB's gear list:N-VB's gear list
Canon 6D Mark II Canon EOS R Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM +32 more
hunk
hunk Veteran Member • Posts: 3,409
Re: Mine doesn't rattle
I just shook mine. It does make some noise and you can see the floating IS element wobble around. I tried to shake it really hard (like while running with the lens in a backpack) and the noises stay the same. Doesn't sound alarming to me. It must be designed to do this and last for decades. When I turn the camera on the sound and movement is less as the IS unit is powered.
 hunk's gear list:hunk's gear list
Olympus Stylus 725 SW Canon EOS 5D Mark IV Panasonic GH5 Canon EOS R Canon EOS R5 +10 more
R. Slaughter Senior Member • Posts: 1,291
Don't Shake an EF100 L Macro (!)
If this tendency to rattle troubles you, don't try shake-checking all lenses.
My EF 100 L Macro sounds terrible, as do other examples of the lens that I've checked (four or five) but the ability to make noise does NOT effect its ability to make images...
A long-time Camera shop owner tells me that the 100L is one of the few L lenses in which the "stabilizer doesn't 'park".  I'm not certain if that's accurate, I'm just repeating the claim. Maybe your new lens is the same design?
R. Slaughter
'DEMOCRACY' is two wolves and a lamb voting on lunch.
'LIBERTY' is a well-armed lamb denying enforcement of the vote.
C+54.772256^2Z
http://www.pbase.com/nufsed/galleries
ZX11
ZX11 Veteran Member • Posts: 6,156
Turn off IS and camera for storage
I heard that Canon said to turn off the IS on the lens to park the moving IS parts.  That this should be done prior to long term storage or for shipping.  Rumor?
"Very funny, Scotty! Now beam me down my clothes."
"He's dead, Jim! You grab his tri-corder. I'll get his wallet."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
Caseydc Forum Member • Posts: 98
Re: Don't Shake an EF100 L Macro (!)
Exactly!! The 100 Macro is scary sounding. I have detached it without turning the camera off while the IS is still whirling. That even makes things more loose and rattly. If you let IS come to a stop things get a little more solid sounding, but I thought it was broken when I first got it. One noisy lens.
hunk
Re: Turn off IS and camera for storage
With the RF70-200 it doesn't seem to make a difference, I don't believe it has a P
