Is there a problem With the fuji x-t100 hotshoe?
Started Dec 23, 2019 | Discussions
Phil BH Senior Member • Posts: 1,043
Re: Is there a problem With the fuji x-t100 hotshoe?
Mrfrumps wrote:
i wouldn't trying again honestly would i be resetting "set up reset" or "shooting menu reset"?
The first setup menu, not the shooting menu. Just a thought. I saw where someone else had the problem and they did that.
Good luck.
Phil
OP Mrfrumps New Member • Posts: 11
yes! ty! I've done this before but it didn't work but now it does! thank you so much! it saves  me the trouble of having to send it back!
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
Does the built-in flash work?
Mrfrumps wrote:
yeah the sound&flash is on and bracketing is on single i believe. still nothing
If the built in flash works, then a flash on the hotshoe should work.
If the built in flash does not work, the camera is probably in silent mode.
Tom Schum
Copper: Mankind's favorite electrical conductor
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
sshapiro Senior Member • Posts: 1,018
A nice Christmas present for you!
So happy that worked for you!
Phil
