Is there a problem With the fuji x-t100 hotshoe?
Started Dec 23, 2019 | Discussions
Mrfrumps New Member • Posts: 11
I've tried searching all over the web and couldn't find much other than the fact i need to have my sound on & Mechanical Shutter and all the other minor troubleshooting advice but all of my third party wireless and wired hot shoe adapters  dont fire my flashes the test button on my transmitter is fire the flashes but not when connected to the hot shoe..i literally just got my camera  a week ago from amazon and just now got to play with my camera in the studio.. any help would be appreciated!
Morris0
Morris0 Forum Pro • Posts: 32,175
Re: Is there a problem With the fuji x-t100 hotshoe?
Try wiggling your transmitter.  Fit is a problem on many hot shoes.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
OP Mrfrumps New Member • Posts: 11
I’ve tried wiggling it and pressing it down to try and get it to trigger still nothing.
Morris0
Are your transmitters Fuji and/or Canon compatible?  They use the same pinout.  Dose the flash camera's flash menu show a flash is attached?
Morris
It’s a single pin third party transmitter.it fires my canon 5d mkiii but not my Fuji x t-100 to tell you the truth non of my transmitters work All Of them third party though if I were to buy a canon transmitter specifically and it not work is there a possible problem with my hot shoe. Let me test if it shows a flash attached when I get a chance.
No it doesn’t show there is anything attached to the hot shoe although I’m not sure where it should be showing that I do have something attached
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
When I owned a X-T100 I used it routinely with a Fuji EF-42 flash.  No problems.
If you have a camera store anywhere near you, maybe it would be worthwhile to go there and try a Fuji flash on it.  Tell them you're interested in buying the flash and want to try it first.  Maybe that will be a true statement after ten minutes (always a hazard).
If it doesn't work, you have a problem with your camera.
Tom Schum
Copper: Mankind's favorite electrical conductor
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
sshapiro Senior Member • Posts: 1,018
I have an X-T100 and some Flashpoint/Godox equipment (two flashes and a remote trigger) I can test with. I will let you know the results within a couple of days.
Well, I got to this quicker than I thought I would. I was able to use a Godox TT350 on the hotshoe of my X-T100. I was also able to mount a Flashpoint R2Pro (Fujifilm version) on the hotshoe and trigger the TT350 remotely.
thank you all for the help i'll see about going to a camera shop after the holidays was also thinking of getting a external flash system anyways too so i could do either before i sent it to get fixed or refunded for another one! thank y'all so much!
johnbandry Senior Member • Posts: 2,938
You have quiet mode off? Not in continuous shooting mode?
Flash mode set correctly (try forced flash)?
John Bandry
“Reason is poor propaganda when opposed by the yammering, unceasing lies of ... self-serving men” - Robert A. Heinlein
 johnbandry's gear list:johnbandry's gear list
Canon EOS 5D Fujifilm X-Pro1 Canon TS-E 24mm f/3.5L II Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +3 more
yes silent mode meaning (sound on) & i tried all flash modes also yes the camera is in single shooting mode
Phil BH Senior Member • Posts: 1,043
Sound on, is not really the same as turning off silent mode. Silent mode also turns off the flash and the focus assist lamp. You may know this, but in case you are confused by Fuji's name, "silent mode," hold down the Disp/Back button for a second. All sounds are turned off, flash is disabled, and the focus-assist lamp is turned off. It stays in silent mode until you press the button again.
Phil
holding the disp/back button does is take me to FN settings
Ah, perhaps they removed that function.
*shrugs* perhaps i searched high and low and cant find a silent option anywhere in the settings
Did you go to Menu- setup1, and set sound & flash to on?
http://fujifilm-dsc.com/en/manual/x-t100/menu_setup/setup_menu1/index.html#sound_flash
The only other thing I can think of is Bracketing is on, or Continuous shooting, but I think that's been covered already.
yeah the sound&flash is on and bracketing is on single i believe. still nothing
Have you tried a setup menu 1 reset?
i wouldn't trying again honestly would i be resetting "set up reset" or "shooting menu reset"?
