HELP! New EOS R + RF 24-105 displaying f00
Started Dec 20, 2019 | Discussions
Erin Schrad Forum Member • Posts: 89
I just opened a brand new EOS R + RF 24-105 kit and am kinda losing my mind because the 24-105 is displaying f00.  I have tried using a microfiber cloth to clean the contacts.  I tried taking it off, putting it back on, over and over.  I was going to try updating the lens firmware, but as the camera does not detect the lens at all, I can't update the lens firmware.  I tried an EF lens on the camera with the RF adapter... it worked.  So it's some issue with the RF lens.
Anything I haven't tried?  Do I exchange the whole kit for a new one?  I am so crushed!
PMUK
PMUK Senior Member • Posts: 2,999
Re: HELP! New EOS R + RF 24-105 displaying f00
Hi Erin,
Sorry to hear this, doesn’t sound too good for ‘out of the box’.  Error codes... Here
Possible ‘quick fixes’ include cleaning the lens contacts with a swab/ pencil eraser.
If all of the obvious things fail I’d definitely pursue an immediate return/ swap-out.
It should just work.
Phil
ZX11
ZX11 Veteran Member • Posts: 6,156
Charge the battery?
A shot in the dark,...try charging the battery.  It could be that the RF lens needs more power or higher voltage on those contacts to start up its electronics.
Battery could be at a pretty low voltage if it was on the self for a long time.
"Very funny, Scotty! Now beam me down my clothes."
"He's dead, Jim! You grab his tri-corder. I'll get his wallet."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
Steven Blackwood Senior Member • Posts: 2,210
The very first time I put a lens on this camera, I had a similar problem. I had not rotated the lens far enough. The lens mount felt stiff.
failing that you will need to figure out whether the problem is the lens or the camera. Ideally you should use  another RF lens. Do you have anasapter and an EF lens?
Steve
stevenblackwood1950@gmail.com
Milwaukee WI
 Steven Blackwood's gear list:Steven Blackwood's gear list
Canon EOS R Canon EOS R6 Sigma 100-400mm F5-6.3 Canon EF 70-200 F4 II Canon RF 35mm F1.8 IS STM Macro +2 more
OP Erin Schrad Forum Member • Posts: 89
Re: Charge the battery?
I was using a charged battery from my 5D Mark III (LP-E6) while the EOS R's battery (LP-E6N) charged.  Both can be used, but I did try the LP-E6N... no change.
Yes, it did feel very stiff.  I've since taken it off and put it back on numerous times hoping to dislodge whatever might be sticking.  No luck.
I did try my EF 85/1.8 with the RF adapter and it worked on the camera.  So it's something with the 24-105.
I've emailed B&H about the issue for possible exchange.
I tried a microfiber lens wrap and then an eraser.  No change.
Well, I’m sorry this had to be your introduction to the R because it’s a great camera with some annoying flaws. Hopefully BH will get you a replacement pronto.
Steve
Milwaukee WI
Thanks.  In all my years of buying gear, this is a first!
Hsd1965 Regular Member • Posts: 158
When I bought this combo the sensor of my EOS R died within an hour. These things happen.
MAC Forum Pro • Posts: 18,487
It is always something...
A working RF 24-105 L is a great lens.  Best wishes on the replacement
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
MannyV
MannyV Senior Member • Posts: 1,055
Sorry to hear that. BH Photo customer service is usually top notch so hopefully you get a replacement set soon.
(unknown member) Regular Member • Posts: 438
Are you able to update firmware on the lens? 2.0.1 came out December 6…
Thank you
didn't know this
updated mine to 2.0.1
ZX11
MAC wrote:
Thank you
didn't know this
I hate this.  I look at my coffee cup and know one day, I will be doing firmware updates on my new cup.  New RF 11-400mm f/2 lens hacked and my savings account wiped out the same day I put it on my camera?
I didn't update my RF 24-105mm but now wonder what I am missing.
shawnphoto Senior Member • Posts: 1,307
ZX11 wrote:
MAC wrote:
Thank you
didn't know this
You hate free improvements to your gear?
 shawnphoto's gear list:shawnphoto's gear list
Canon EOS R Canon EOS RP Canon EOS R5 Canon EF 24-105mm F4L IS II USM Canon RF 28-70mm F2L USM +4 more
