GX9 - is it normal that the IBIS "rattles" when camera is off and you move it?
Started Dec 20, 2019 | Questions
Jamajuel Contributing Member • Posts: 917
Hi there,
I just upgraded my trusty old GX7 to a GX9. I did not expect this to be such a big jump to be honest, but 5m into using it, I knew I was going to keep it.
When I open the box and handled the body, I could immediately hear that something was rattling inside. When turning it on, it goes away. When I take of the lens now, you can actually see why: the IBIS stops and you can actually see how the sensor starts to wiggle around. So if you move or shake slightly the body, you can hear it clunking around.
My question: Is that normal? Do others have the same?
The GX7 only had rudimentary IBIS, so I cannot compare. However, my Lumix S1 has excellent IBIS and nothing rattles whatsoever when off.
I haven't noticed anything off in handling whatsoever tbh. Focus and IBIS works fine, also in conjunction with stabilized lenses. Just trying to reassure myself that I don't have to send it back to Amazon for replacement.
Thanks!
 Jamajuel's gear list:Jamajuel's gear list
Panasonic S1 Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic S Pro 70-200mm F4 OIS Sigma 85mm F1.4 DG GN Panasonic Lumix DMC-GX7 +4 more
Panasonic Lumix DC-GX9 Panasonic Lumix DMC-GX7
MaxAMS Forum Member • Posts: 78
Re: GX9 - is it normal that the IBIS "rattles" when camera is off and you move it?
Can't speak for the GX9, but my GX80 also rattles when off. Turning the camera on powers up IBIS (I suppose) and the rattle is gone.
 MaxAMS's gear list:MaxAMS's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +10 more
OP Jamajuel Contributing Member • Posts: 917
Yup, same. Thanks!
evetsf Senior Member • Posts: 1,707
Jamajuel wrote:
Hi there,
Thanks!
Both my GX9 and G9 do this. Seems to be normal.
Steve
 evetsf's gear list:evetsf's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH Panasonic 12-60mm F3.5-5.6 OIS +3 more
epozar
epozar Senior Member • Posts: 1,969
The greatest "rattler" is a Sigma 60/2.8 mft lens
 epozar's gear list:epozar's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Lumix DC-G9 OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 +10 more
6 X 17 Feind Senior Member • Posts: 1,048
The sensor is just loose in there till powered up and then a series of electro magnets pull it into its static operating position. nothing to worry about.
6 X 17 Feind
 6 X 17 Feind's gear list:6 X 17 Feind's gear list
Nikon D800 Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 Panasonic G85 Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF +9 more
I figured, I just didn't notice the same on the S1, which left me wondering. Thank you!
Dice_Box Forum Member • Posts: 74
Page 13 of the G9 manual says this, so I think you have nothing to worry about:
"If you shake the camera while it is turned off, its sensors may move or a rattling sound may be heard. The sound is caused by the In-Body Image Stabilizer, and this is not a malfunction."
(unknown member) Senior Member • Posts: 1,455
With these more expensive models they probably can put in systems to hold things steady when off as these rattles do alarm people. Stabilisation buzz, aperture clack all cause panic. The cheap sigma lenses I have had with their linear focusing just seem to run free on the sliders when off and can make a massive rattle without any apparent harm, but the more expensive stuff probably locks up.
AndyH44
AndyH44 Veteran Member • Posts: 3,110
WHAT??? Read the Manual???
What a novel idea!  It's a shame so many ask questions rather than find answers themselves!
"The world doesn't exist to satisfy our expectations."
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Re: WHAT??? Read the Manual???
"When all else fails, RTFM". Some (most?) people really feel that looking into the manual is the absolute last-ditch effort.
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
