Brickmaking beside the church of San Isidro de Iruya
Started Dec 19, 2019 | Photos
noisebeam Senior Member • Posts: 2,849
 noisebeam's gear list:noisebeam's gear list
Sony RX100 II Canon EOS 30D Canon EF 100mm f/2.8 Macro USM Sigma 15mm F2.8 EX DG Diagonal Fisheye Sigma 30mm F1.4 EX DC HSM +8 more
Comment & critique:
(unknown member) Veteran Member • Posts: 6,221
Re: Brickmaking beside the church of San Isidro de Iruya
I think this is a lovely study of contrasts, forms, and textures. Well done!
Tweaks I would consider (at least today -- tomorrow might be a different story):
  • set white point on the building - I used 245.245.245 to avoid any clipping
  • slightly increase contrast on the stone wall and bricks, and also on the background mountains
  • add a slight gradient to the sky so it isn't quite so flat
OP noisebeam Senior Member • Posts: 2,849
Thank you very much. I like those improvements. These are mostly beyond my editing capabilities as I use Capture One to develop from RAW with global setting only and no other SW although I understand how to do them if I had the patience to figure out how to mask.
I also did not like how the sky was so dark, but I needed it that way to contrast with the mountains. However adding the sky gradient solved that issue. Something I can consider for future similar issue.
As to the white point I purposely kept it lower as there were highlights around the edges that were blowing out.  I was not sure how to increase the WP without further blowing them.  I do agree it looks better brighter.
I also played (more than considered carefully) with the color channels in B/W conversion, maybe on some a bit aggressively so there may be more to work with from the original.
Prufroc Regular Member • Posts: 225
Nice photo. I love the composition.
 Prufroc's gear list:Prufroc's gear list
Sony a6300 Sony E 55-210mm F4.5-6.3 OSS Sony E 35mm F1.8 OSS Sigma 16mm F1.4 DC DN (E/EF-M mounts) Sigma 56mm F1.4 DC DN +2 more
Yes. I forgot to mention that the composition is impeccable.
Thank you both very much. I appreciate positive feedback as much as critical.
gavin
gavin Veteran Member • Posts: 7,788
Nice B&W.
 gavin's gear list:gavin's gear list
Sony RX100 III Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
Updated version
I attempted to take some of those suggestions using global adjustments. The WP was easy.. I still prefer your gradient sky and more local contrast in the mountains, but will leave that for later when I am patient to learn how.  I also cropped it a bit tighter on the right to remove some edge jitter.
Re: Updated version
Yes, move beyond global adjustments and learn how to make local adjustments (with layers and masks). It is well worth the time and effort to learn.
Re: Updated version
I can and have used layers and basic masks sometimes with hand drawn various sizes of fat blurry brushes to simulate dodging/burning, occasionally contrast or other and also rarely used basic gradients across parts or all of image. It is the detailed masks and those that follow contours I need to take the step to figure out. I can't hand draw them effectively and not sure if or what what extent the editor I use can automatically find edges and of what type to help me get a clean edge where needed.
I did notice in your edit that there is an artifact of a dark line on the mountain top edge against the sky top left and a few other places. Perhaps due to a quick edit and/or too small to affect image. Are these hand drawn? I use a mouse which is also a hindrance.
Re: Updated version
Yes, I made that mask quickly using the quick select tool, just to illustrate the effect. On a high res image I would refine that edge to eliminate the dark line. The fact that you spotted it shows that you have a good eye for detail. You should be able to make very clean masks/edits with a little practice.
Dorotich Forum Member • Posts: 89
Re: Updated version
Thank you noisebeam and sabrina81 for the respectful exchange of ideas. This is the type of critique and response that can make the forum flourish. I hope more members emulate your approach.
And I agree with sabrina, this is a beautifully composed image and an excellent use of B&W.
